YACS::ENGINE::CppXml Class Reference
#include <CppXMLConv.hxx>
Inheritance diagram for YACS::ENGINE::CppXml:
Collaboration diagram for YACS::ENGINE::CppXml:
 CppXml (InputXmlPort *p)
 Convert a YACS::ENGINE::Any that is convertible to Xml::char * and send it to proxy port. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 31 of file CppXMLConv.hxx.
◆ CppXml()
YACS::ENGINE::CppXml::CppXml ( InputXmlPort *  p)
Definition at line 39 of file CppXMLConv.cxx.
40 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
41 {
42 DEBTRACE("proxy port from C++ to XML");
43 }
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
References DEBTRACE.
◆ put() [1/2]
void YACS::ENGINE::CppXml::put ( const void *  data)
data: YACS::ENGINE::Any object as a void * pointer
Definition at line 50 of file CppXMLConv.cxx.
51 {
52 put((YACS::ENGINE::Any *)data);
53 }
Definition: Any.hxx:79
Definition: CppXMLConv.cxx:50
References put().
Referenced by put().
◆ put() [2/2]
void YACS::ENGINE::CppXml::put ( YACS::ENGINE::Any *  data)
Definition at line 59 of file CppXMLConv.cxx.
60 {
61 DEBTRACE("CppXml::put");
62 std::string s = convertCppXml(edGetType(), data);
63 DEBTRACE(s);
65 ((InputXmlPort*)_port)->put(s.c_str());
66 DEBTRACE("End CppXml::put");
67 }
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string getName() const
Definition: DataPort.hxx:55
std::string convertCppXml(const TypeCode *t, void *ob)
Definition: CppXMLConv.cxx:34
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertCppXml(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::DataPort::getName().
