YACS::ENGINE::InputXmlPort Class Reference
Class for XML Input Ports. More...
#include <XMLPorts.hxx>
Inheritance diagram for YACS::ENGINE::InputXmlPort:
Collaboration diagram for YACS::ENGINE::InputXmlPort:
 InputXmlPort (const std::string &name, Node *node, TypeCode *type)
 InputXmlPort (const InputXmlPort &other, Node *newHelder)
bool edIsManuallyInitialized () const
void edRemoveManInit ()
void put (const char *data)
void releaseData () override
virtual const char * getXml () const
void * get () const
bool isEmpty ()
virtual void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
virtual void exRestoreInit ()
 Restore the saved data value to current data value. More...
virtual std::string dump ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
std::string _data
std::string _initData
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
XmlNode
Definition at line 37 of file XMLPorts.hxx.
◆ InputXmlPort() [1/2]
InputXmlPort::InputXmlPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 30 of file XMLPorts.cxx.
31 : InputPort(name, node, type), DataPort(name, node, type), Port(node), _initData(""), _data("")
32{
33}
Definition: DataPort.cxx:41
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ InputXmlPort() [2/2]
InputXmlPort::InputXmlPort ( const InputXmlPort &  other,
Node *  newHelder
Definition at line 35 of file XMLPorts.cxx.
35 :InputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder),_initData(other._initData),_data(other._data)
36{
37}
◆ clone()
InputPort * InputXmlPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 82 of file XMLPorts.cxx.
83{
84 return new InputXmlPort(*this,newHelder);
85}
InputXmlPort(const std::string &name, Node *node, TypeCode *type)
Definition: XMLPorts.cxx:30
References InputXmlPort().
◆ dump()
std::string InputXmlPort::dump ( )
Reimplemented from YACS::ENGINE::InputPort.
Reimplemented in YACS::ENGINE::InputPresetPort, and YACS::ENGINE::InputStudyPort.
Definition at line 106 of file XMLPorts.cxx.
107{
108 return _data;
109}
References _data.
◆ edIsManuallyInitialized()
bool InputXmlPort::edIsManuallyInitialized ( ) const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition at line 39 of file XMLPorts.cxx.
40{
41 return _initData != "";
42}
References _initData.
◆ edRemoveManInit()
void InputXmlPort::edRemoveManInit ( )
Removes eventually previous manual initialisation.
Definition at line 44 of file XMLPorts.cxx.
45{
46 _initData="";
48}
virtual void edRemoveManInit()
Definition: InputPort.cxx:140
References _initData, and YACS::ENGINE::InputPort::edRemoveManInit().
◆ exRestoreInit()
void InputXmlPort::exRestoreInit ( )
If no data has been saved (_initData == 0) don't restore
Definition at line 100 of file XMLPorts.cxx.
101{
102 if(_initData!="")return;
104}
References _data, and _initData.
◆ exSaveInit()
void InputXmlPort::exSaveInit ( )
Definition at line 91 of file XMLPorts.cxx.
92{
94}
◆ get()
void * InputXmlPort::get ( ) const
Definition at line 56 of file XMLPorts.cxx.
57{
58 return (void *) _data.c_str();
59}
References _data.
◆ getXml()
const char * InputXmlPort::getXml ( ) const
Definition at line 50 of file XMLPorts.cxx.
51{
53 return _data.c_str();
54}
References _data, and DEBTRACE.
◆ isEmpty()
bool InputXmlPort::isEmpty ( )
Definition at line 77 of file XMLPorts.cxx.
78{
79 return _data.empty();
80}
References _data.
◆ put() [1/2]
void InputXmlPort::put ( const char *  data)
Definition at line 67 of file XMLPorts.cxx.
68{
69 DEBTRACE(data);
70 _data = data;
71}
◆ put() [2/2]
void InputXmlPort::put ( const void *  data)
Definition at line 61 of file XMLPorts.cxx.
62{
63 DEBTRACE("put(void *)");
64 put((const char*)data);
65}
Definition: XMLPorts.cxx:61
References DEBTRACE, and put().
Referenced by put().
◆ releaseData()
void InputXmlPort::releaseData ( )
overridevirtual
Definition at line 73 of file XMLPorts.cxx.
74{//nothing because _data has no ref counter
75}
◆ valFromStr()
void InputXmlPort::valFromStr ( std::string  valstr)
Allows to set data from a string representation used in user interface.
Implemented in derived classes, depending on runtime, to set the data from its user interface representation. Typical use, a Python string representation that can be used in edition or restitution.
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 116 of file XMLPorts.cxx.
117{
118 _data = valstr;
119}
References _data.
◆ valToStr()
std::string InputXmlPort::valToStr ( )
Gives a string representation of the data, for user interfaces.
Implemented in derived classes, depending on runtime, to provide the data representation for user interfaces. Typical use, a Python string representation that can be used in edition or restitution.
Definition at line 111 of file XMLPorts.cxx.
112{
113 return _data;
114}
References _data.
◆ _data
◆ _initData
std::string YACS::ENGINE::InputXmlPort::_initData
Definition at line 58 of file XMLPorts.hxx.
Referenced by edIsManuallyInitialized(), edRemoveManInit(), exRestoreInit(), and exSaveInit().
