YACS::ENGINE::InputStudyPort Class Reference
Class for Study input Ports. More...
#include <StudyPorts.hxx>
Inheritance diagram for YACS::ENGINE::InputStudyPort:
Collaboration diagram for YACS::ENGINE::InputStudyPort:
 InputStudyPort (const std::string &name, Node *node, TypeCode *type)
 InputStudyPort (const InputStudyPort &other, Node *newHelder)
void setData (const std::string &data)
std::string getData ()
virtual std::string getIOR ()
virtual std::string splitXML (const std::string &s)
virtual std::string dump ()
virtual std::string getPyObj ()
virtual void putDataInStudy (SALOMEDS::StudyBuilder_var aBuilder)
- Public Member Functions inherited from YACS::ENGINE::InputXmlPort
 InputXmlPort (const std::string &name, Node *node, TypeCode *type)
 InputXmlPort (const InputXmlPort &other, Node *newHelder)
bool edIsManuallyInitialized () const
void edRemoveManInit ()
void put (const char *data)
void releaseData () override
virtual const char * getXml () const
void * get () const
bool isEmpty ()
virtual void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
virtual void exRestoreInit ()
 Restore the saved data value to current data value. More...
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
std::string _storeData
- Protected Attributes inherited from YACS::ENGINE::InputXmlPort
std::string _data
std::string _initData
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
StudyOutNode
Definition at line 50 of file StudyPorts.hxx.
◆ InputStudyPort() [1/2]
YACS::ENGINE::InputStudyPort::InputStudyPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 275 of file StudyPorts.cxx.
276 : InputXmlPort(name, node, type),
277 DataPort(name, node, type),
278 Port(node)
279{
280}
Definition: DataPort.cxx:41
InputXmlPort(const std::string &name, Node *node, TypeCode *type)
Definition: XMLPorts.cxx:30
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ InputStudyPort() [2/2]
YACS::ENGINE::InputStudyPort::InputStudyPort ( const InputStudyPort &  other,
Node *  newHelder
Definition at line 282 of file StudyPorts.cxx.
283 : InputXmlPort(other,newHelder),
284 DataPort(other,newHelder),
285 Port(other,newHelder),_storeData(other._storeData)
286{
287}
◆ clone()
InputPort * YACS::ENGINE::InputStudyPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 289 of file StudyPorts.cxx.
290{
291 return new InputStudyPort(*this,newHelder);
292}
InputStudyPort(const std::string &name, Node *node, TypeCode *type)
Definition: StudyPorts.cxx:275
References InputStudyPort().
◆ dump()
std::string YACS::ENGINE::InputStudyPort::dump ( )
Reimplemented from YACS::ENGINE::InputXmlPort.
Definition at line 330 of file StudyPorts.cxx.
331{
332 DEBTRACE( "InputStudyPort::dump " << _storeData );
333 DEBTRACE( "InputStudyPort::dump " << _data );
334 //return "<value><string>"+_storeData+"</string></value>";
335 return _data;
336}
References YACS::ENGINE::InputXmlPort::_data, _storeData, and DEBTRACE.
Referenced by putDataInStudy().
◆ getAsString()
std::string YACS::ENGINE::InputStudyPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 341 of file StudyPorts.cxx.
342{
343 return getData();
344}
References getData().
Referenced by YACS::HMI::CommandSetInPortValue::localExecute(), and YACS::HMI::CommandSetInPortValue::localReverse().
◆ getData()
std::string YACS::ENGINE::InputStudyPort::getData ( )
◆ getIOR()
std::string YACS::ENGINE::InputStudyPort::getIOR ( )
Definition at line 307 of file StudyPorts.cxx.
308{
309 switch(edGetType()->kind())
310 {
311 case Objref:
312 return splitXML(_data);
313 default:
314 return _data;
315 }
316}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual std::string splitXML(const std::string &s)
Definition: StudyPorts.cxx:318
References YACS::ENGINE::InputXmlPort::_data, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::Objref, and splitXML().
◆ getPyObj()
std::string YACS::ENGINE::InputStudyPort::getPyObj ( )
Definition at line 337 of file StudyPorts.cxx.
338{
339 return getData();
340}
◆ putDataInStudy()
void YACS::ENGINE::InputStudyPort::putDataInStudy ( SALOMEDS::StudyBuilder_var  aBuilder)
Definition at line 346 of file StudyPorts.cxx.
347{
348 SALOMEDS::GenericAttribute_var aGAttr;
349 SALOMEDS::SObject_var aSO ;
350 SALOMEDS::AttributeName_var anAttr ;
351 SALOMEDS::AttributeIOR_var iorAttr ;
352 SALOMEDS::SComponent_var aFather;
353
354 std::string data = getData();
355 DEBTRACE("data: " << data );
356 //try to find an existing id (i:j:k...)
357 aSO = KERNEL::getStudyServant()->FindObjectID(data.c_str());
358 if(CORBA::is_nil(aSO))
359 {
360 // the id does not exist. Try to create it by id
361 aSO=KERNEL::getStudyServant()->CreateObjectID(data.c_str());
362 if(!CORBA::is_nil(aSO))
363 {
364 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeName");
365 anAttr = SALOMEDS::AttributeName::_narrow( aGAttr );
366 anAttr->SetValue(getName().c_str());
367 }
368 }
369
370 if(CORBA::is_nil(aSO))
371 {
372 //try to publish the object with a given path
373 std::string name; // the component instance name
374 std::string objname; // the object name (eventually with "/")
375 std::string::size_type begin = data.find_first_not_of("/");
376 std::string::size_type pos=data.find_first_of("/", begin);
377 if (pos != std::string::npos)
378 {
379 name=data.substr(begin,pos-begin);
380 objname=data.substr(pos+1);
381 }
382 else
383 {
384 name=data.substr(begin);
385 objname="";
386 }
387 std::string pname="/"+name;
388 DEBTRACE(pname);
389 DEBTRACE(objname);
390
391 Proc* proc=getNode()->getProc();
392 if(proc->componentInstanceMap.count(name)!=0)
393 {
394 // There is a component instance with this name. Is it a Salome component or not ?
395 ComponentInstance* compo=proc->componentInstanceMap[name];
396 if(SalomeComponent* scompo=dynamic_cast<SalomeComponent*>(compo))
397 {
398 //It's a Salome component, make it the right way : component name, component instance reference, ...
399 CORBA::Object_var compovar= scompo->getCompoPtr();
400 SALOMEDS::Driver_var aDriver = SALOMEDS::Driver::_narrow(compovar);
401 if ( !CORBA::is_nil( aDriver ) )
402 {
403 //It's a Salome component that implements the Driver interface. Use it to publish in study
404 CORBA::ORB_ptr orb;
405 CORBA::Object_var anObject;
406 try
407 {
409 anObject=orb->string_to_object(getIOR().c_str());
410 }
411 catch ( ... )
412 {
413 std::cerr << "Execution problem: can not get the object to publish" << std::endl;
414 return;
415 }
416 if ( aDriver->CanPublishInStudy( anObject ) )
417 {
418 //It's fine use the driver to publish
419 SALOMEDS::SObject_var aTmpSO; // initialized to nil
420 try
421 {
422 aTmpSO = aDriver->PublishInStudy(aTmpSO, anObject,objname.c_str() );
423 return;
424 }
425 catch ( ... )
426 {
427 std::cerr << "Execution problem: error in PublishInStudy" << std::endl;
428 return;
429 }
430 }
431 }
432 }
433 }
434
435 // Does component entry exist ?
436 aSO=KERNEL::getStudyServant()->FindObjectByPath(pname.c_str());
437 if(CORBA::is_nil(aSO))
438 {
439 // We have not been able to publish the object with Salome Driver, make it the light way
440 aFather=aBuilder->NewComponent(name.c_str());
441 if(CORBA::is_nil(aFather))
442 {
443 std::cerr << "Execution problem: can not create component: " + name << std::endl;
444 return;
445 }
446 aGAttr=aBuilder->FindOrCreateAttribute(aFather,"AttributeName");
447 anAttr = SALOMEDS::AttributeName::_narrow( aGAttr );
448 anAttr->SetValue(name.c_str());
449 aSO=KERNEL::getStudyServant()->FindObjectByPath(pname.c_str());
450 }
451
452 begin=data.find_first_not_of("/",pos);
453 while (begin != std::string::npos)
454 {
455 pos = data.find_first_of("/", begin);
456 if (pos != std::string::npos)
457 name=data.substr(begin,pos-begin);
458 else
459 name=data.substr(begin);
460 aSO=findOrCreateSoWithName(aBuilder,aSO,name);
461 begin=data.find_first_not_of("/",pos);
462 }
463 }
464
465 if(CORBA::is_nil(aSO))
466 {
467 std::cerr << "Execution problem: can not create id or path: " + data + " in study" << std::endl;
468 return;
469 }
470
471 std::string value;
472 SALOMEDS::AttributeComment_var commentAttr ;
473 SALOMEDS::AttributeReal_var realAttr ;
474 SALOMEDS::AttributeInteger_var intAttr ;
475 SALOMEDS::AttributeString_var stringAttr ;
476 double d;
477 long v;
478 switch(edGetType()->kind())
479 {
480 case Objref:
481 value=getIOR();
482 DEBTRACE(value);
483 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeIOR");
484 iorAttr = SALOMEDS::AttributeIOR::_narrow( aGAttr );
485 iorAttr->SetValue(value.c_str());
486 break;
487 case Double:
488 value=splitXML(dump());
489 DEBTRACE(value);
490 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeReal");
491 realAttr = SALOMEDS::AttributeReal::_narrow( aGAttr );
492 d=atof(value.c_str());
493 realAttr->SetValue(d);
494 break;
495 case Int:
496 value=splitXML(dump());
497 DEBTRACE(value);
498 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeInteger");
499 intAttr = SALOMEDS::AttributeInteger::_narrow( aGAttr );
500 v=atol(value.c_str());
501 intAttr->SetValue(v);
502 break;
503 case String:
504 case Bool:
505 value=splitXML(dump());
506 DEBTRACE(value);
507 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeComment");
508 commentAttr = SALOMEDS::AttributeComment::_narrow( aGAttr );
509 commentAttr->SetValue(value.c_str());
510 break;
511 default:
512 value=dump();
513 DEBTRACE(value);
514 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeComment");
515 commentAttr = SALOMEDS::AttributeComment::_narrow( aGAttr );
516 commentAttr->SetValue(value.c_str());
517 }
518}
std::string getName() const
Definition: DataPort.hxx:55
virtual std::string dump()
Definition: StudyPorts.cxx:330
virtual std::string getIOR()
Definition: StudyPorts.cxx:307
virtual Proc * getProc()
Definition: Node.cxx:401
Node * getNode() const
Definition: Port.hxx:46
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
CORBA::ORB_ptr getOrb() const
SALOMEDS::SObject_ptr findOrCreateSoWithName(SALOMEDS::StudyBuilder_ptr builder, SALOMEDS::SObject_ptr sobj, const std::string &name)
Definition: StudyPorts.cxx:234
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
References YACS::ENGINE::Bool, YACS::ENGINE::Proc::componentInstanceMap, DEBTRACE, YACS::ENGINE::Double, dump(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::findOrCreateSoWithName(), getData(), getIOR(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Port::getNode(), YACS::ENGINE::RuntimeSALOME::getOrb(), YACS::ENGINE::Node::getProc(), YACS::ENGINE::getSALOMERuntime(), YACS::ENGINE::Int, YACS::ENGINE::Objref, orb, splitXML(), and YACS::ENGINE::String.
Referenced by YACS::ENGINE::StudyOutNode::execute().
◆ setData()
void YACS::ENGINE::InputStudyPort::setData ( const std::string &  data)
Definition at line 294 of file StudyPorts.cxx.
295{
296 _storeData = data;
297 DEBTRACE( "InputStudyPort::setData " << _storeData );
298 modified();
299}
void modified()
Definition: Port.cxx:53
References _storeData, DEBTRACE, and YACS::ENGINE::Port::modified().
Referenced by YACS::ENGINE::StudyOutNode::setData().
◆ splitXML()
std::string YACS::ENGINE::InputStudyPort::splitXML ( const std::string &  s)
Definition at line 318 of file StudyPorts.cxx.
319{
320 // <value><tag>content</tag></value>
321 std::string::size_type begin = s.find_first_of("<"); // <value>
322 begin = s.find_first_of(">",begin); // end of <value>
323 begin = s.find_first_of("<",begin); // beginning of <tag>
324 begin = s.find_first_of(">",begin); // end of <tag>
325 begin = s.find_first_not_of("> ",begin); // beginning of content
326 std::string::size_type last = s.find_first_of("<",begin); // beginning of </tag>
327 return s.substr(begin,last-begin);
328}
Referenced by getIOR(), and putDataInStudy().
◆ typeName()
virtual std::string YACS::ENGINE::InputStudyPort::typeName ( )
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 63 of file StudyPorts.hxx.
63{return "YACS__ENGINE__InputStudyPort";}
◆ _storeData
std::string YACS::ENGINE::InputStudyPort::_storeData
Definition at line 66 of file StudyPorts.hxx.
Referenced by dump(), getData(), and setData().
