YACS::ENGINE::InputPresetPort Class Reference
Class for PRESET input Ports. More...
#include <PresetPorts.hxx>
Inheritance diagram for YACS::ENGINE::InputPresetPort:
Collaboration diagram for YACS::ENGINE::InputPresetPort:
 InputPresetPort (const std::string &name, Node *node, TypeCode *type)
 InputPresetPort (const InputPresetPort &other, Node *newHelder)
void setData (std::string data)
std::string getData ()
virtual std::string dump ()
virtual PyObject * getPyObj ()
- Public Member Functions inherited from YACS::ENGINE::InputXmlPort
 InputXmlPort (const std::string &name, Node *node, TypeCode *type)
 InputXmlPort (const InputXmlPort &other, Node *newHelder)
bool edIsManuallyInitialized () const
void edRemoveManInit ()
void put (const char *data)
void releaseData () override
virtual const char * getXml () const
void * get () const
bool isEmpty ()
virtual void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
virtual void exRestoreInit ()
 Restore the saved data value to current data value. More...
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
std::string _storeData
- Protected Attributes inherited from YACS::ENGINE::InputXmlPort
std::string _data
std::string _initData
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
OutNode
Definition at line 49 of file PresetPorts.hxx.
◆ InputPresetPort() [1/2]
InputPresetPort::InputPresetPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 155 of file PresetPorts.cxx.
156 : InputXmlPort(name, node, type),
157 DataPort(name, node, type),
158 Port(node)
159{
160}
Definition: DataPort.cxx:41
InputXmlPort(const std::string &name, Node *node, TypeCode *type)
Definition: XMLPorts.cxx:30
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ InputPresetPort() [2/2]
InputPresetPort::InputPresetPort ( const InputPresetPort &  other,
Node *  newHelder
Definition at line 162 of file PresetPorts.cxx.
163 : InputXmlPort(other,newHelder),
164 DataPort(other,newHelder),
165 Port(other,newHelder),_storeData(other._storeData)
166{
167}
◆ clone()
InputPort * InputPresetPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 169 of file PresetPorts.cxx.
170{
171 return new InputPresetPort(*this,newHelder);
172}
InputPresetPort(const std::string &name, Node *node, TypeCode *type)
References InputPresetPort().
◆ dump()
std::string InputPresetPort::dump ( )
Reimplemented from YACS::ENGINE::InputXmlPort.
Definition at line 187 of file PresetPorts.cxx.
188{
189 return _data;
190}
References YACS::ENGINE::InputXmlPort::_data.
Referenced by YACS::ENGINE::OutNode::dump(), and getPyObj().
◆ getAsString()
std::string InputPresetPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 204 of file PresetPorts.cxx.
205{
207 PyObject* ob=getPyObj();
208 DEBTRACE(PyObject_Str(ob));
209 std::string s=convertPyObjectToString(ob);
210 DEBTRACE(s);
211 Py_DECREF(ob);
212 return s;
213}
virtual PyObject * getPyObj()
std::string convertPyObjectToString(PyObject *ob)
References YACS::ENGINE::convertPyObjectToString(), DEBTRACE, and getPyObj().
◆ getData()
std::string InputPresetPort::getData ( )
Definition at line 181 of file PresetPorts.cxx.
182{
183 DEBTRACE("InputPresetPort::getData " << _storeData);
184 return _storeData;
185}
References _storeData, and DEBTRACE.
Referenced by YACS::ENGINE::OutNode::dump().
◆ getPyObj()
PyObject * InputPresetPort::getPyObj ( )
Definition at line 192 of file PresetPorts.cxx.
193{
194 DEBTRACE(dump());
195 if(_data=="")
196 {
197 Py_INCREF(Py_None);
198 return Py_None;
199 }
200 else
202}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual std::string dump()
PyObject * convertXmlStrPyObject(const TypeCode *t, std::string data)
References YACS::ENGINE::InputXmlPort::_data, YACS::ENGINE::convertXmlStrPyObject(), DEBTRACE, dump(), and YACS::ENGINE::DataPort::edGetType().
Referenced by getAsString().
◆ setData()
void InputPresetPort::setData ( std::string  data)
Definition at line 174 of file PresetPorts.cxx.
175{
176 _storeData = data;
177 DEBTRACE( "InputPresetPort::setData " << _storeData );
178 modified();
179}
void modified()
Definition: Port.cxx:53
References _storeData, DEBTRACE, and YACS::ENGINE::Port::modified().
Referenced by YACS::ENGINE::OutNode::setData().
◆ typeName()
virtual std::string YACS::ENGINE::InputPresetPort::typeName ( )
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 60 of file PresetPorts.hxx.
60{return "YACS__ENGINE__InputPresetPort";}
◆ _storeData
std::string YACS::ENGINE::InputPresetPort::_storeData
Definition at line 62 of file PresetPorts.hxx.
Referenced by getData(), and setData().
