XMLCppConv.cxx
20#include "TypeConversions.hxx"
21#include "XMLCppConv.hxx"
23
24#include <libxml/parser.h>
25#include <iostream>
26#include <sstream>
27#include "Any.hxx"
28
29//#define _DEVDEBUG_
30#include "YacsTrace.hxx"
31
32using namespace std;
33
34namespace YACS
35{
36 namespace ENGINE
37 {
38 Any * convertXmlCpp(const TypeCode *t, xmlDocPtr doc, xmlNodePtr cur)
39 {
40 return convertXmlNeutral(t, doc, cur);
41 }
42
44 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
45 {
46 }
47
48 void XmlCpp::put(const void *data)
49 {
50 DEBTRACE(" XmlCpp::put(const void *data)");
51 put((const char *)data);
52 }
53
55
59 void XmlCpp::put(const char *data)
60 {
61 DEBTRACE("XmlCpp::put " << data);
62 xmlDocPtr doc;
63 xmlNodePtr cur;
64 Any *ob=NULL;
65 {
66 doc = xmlParseMemory(data, strlen(data));
67 if (doc == NULL )
68 {
69 stringstream msg;
70 msg << "Problem in conversion: XML Document not parsed successfully ";
71 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
72 throw ConversionException(msg.str());
73 }
74 cur = xmlDocGetRootElement(doc);
75 if (cur == NULL)
76 {
77 xmlFreeDoc(doc);
78 stringstream msg;
79 msg << "Problem in conversion: empty XML Document";
80 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
81 throw ConversionException(msg.str());
82 }
83 while (cur != NULL)
84 {
85 if ((!xmlStrcmp(cur->name, (const xmlChar *)"value")))
86 {
87 ob=convertXmlCpp(edGetType(),doc,cur);
88 break;
89 }
90 cur = cur->next;
91 }
92 xmlFreeDoc(doc);
93 if(ob==NULL)
94 {
95 stringstream msg;
96 msg << "Problem in conversion: incorrect XML value";
97 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
98 throw ConversionException(msg.str());
99 }
100 }
101 _port->put(ob);
102 ob->decrRef();
103 }
104
106 {
107 return isAdaptableNeutralXml(t1, t2);
108 }
109 }
110}
Definition: Any.hxx:79
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Base class for Input Ports.
Definition: InputPort.hxx:44
Base class for all ports.
Definition: Port.hxx:43
Base class for Proxy Input Ports.
Definition: InputPort.hxx:100
Definition: TypeCode.hxx:68
Definition: XMLCppConv.cxx:48
XmlCpp(InputPort *p)
Definition: XMLCppConv.cxx:43
Proc * p
Definition: driver.cxx:216
static char doc[]
Definition: driver.cxx:63
int isAdaptableCppXml(const TypeCode *t1, const TypeCode *t2)
Definition: XMLCppConv.cxx:105
Definition: XMLCppConv.cxx:38
int isAdaptableNeutralXml(const TypeCode *t1, const TypeCode *t2)
YACS::ENGINE::Any * convertXmlNeutral(const TypeCode *t, xmlDocPtr doc, xmlNodePtr cur)
static std::string t1[]
static std::string t2[]
