YACS::ENGINE::XmlCpp Class Reference
#include <XMLCppConv.hxx>
Inheritance diagram for YACS::ENGINE::XmlCpp:
Collaboration diagram for YACS::ENGINE::XmlCpp:
 XmlCpp (InputPort *p)
void put (const char *data)
 Convert received XML (char *) value to C++ (Any *) value and send it to proxy port. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 31 of file XMLCppConv.hxx.
◆ XmlCpp()
YACS::ENGINE::XmlCpp::XmlCpp ( InputPort *  p)
Definition at line 43 of file XMLCppConv.cxx.
44 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
45 {
46 }
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void YACS::ENGINE::XmlCpp::put ( const char *  data)
data: Xml::char *
Definition at line 59 of file XMLCppConv.cxx.
60 {
61 DEBTRACE("XmlCpp::put " << data);
62 xmlDocPtr doc;
63 xmlNodePtr cur;
64 Any *ob=NULL;
65 {
66 doc = xmlParseMemory(data, strlen(data));
67 if (doc == NULL )
68 {
69 stringstream msg;
70 msg << "Problem in conversion: XML Document not parsed successfully ";
71 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
72 throw ConversionException(msg.str());
73 }
74 cur = xmlDocGetRootElement(doc);
75 if (cur == NULL)
76 {
77 xmlFreeDoc(doc);
78 stringstream msg;
79 msg << "Problem in conversion: empty XML Document";
80 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
81 throw ConversionException(msg.str());
82 }
83 while (cur != NULL)
84 {
85 if ((!xmlStrcmp(cur->name, (const xmlChar *)"value")))
86 {
87 ob=convertXmlCpp(edGetType(),doc,cur);
88 break;
89 }
90 cur = cur->next;
91 }
92 xmlFreeDoc(doc);
93 if(ob==NULL)
94 {
95 stringstream msg;
96 msg << "Problem in conversion: incorrect XML value";
97 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
98 throw ConversionException(msg.str());
99 }
100 }
101 _port->put(ob);
102 ob->decrRef();
103 }
TypeCode * edGetType() const
Definition: DataPort.hxx:53
static char doc[]
Definition: driver.cxx:63
Any * convertXmlCpp(const TypeCode *t, xmlDocPtr doc, xmlNodePtr cur)
Definition: XMLCppConv.cxx:38
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertXmlCpp(), DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), doc, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
◆ put() [2/2]
void YACS::ENGINE::XmlCpp::put ( const void *  data)
Definition at line 48 of file XMLCppConv.cxx.
49 {
50 DEBTRACE(" XmlCpp::put(const void *data)");
51 put((const char *)data);
52 }
Definition: XMLCppConv.cxx:48
References DEBTRACE, and put().
Referenced by put().
