YACS::ENGINE::XmlPython Class Reference
#include <XMLPythonConv.hxx>
Inheritance diagram for YACS::ENGINE::XmlPython:
Collaboration diagram for YACS::ENGINE::XmlPython:
 XmlPython (InputPyPort *p)
void put (const char *data)
 Convert a XML (char *) to PyObject and push it into proxy port. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 31 of file XMLPythonConv.hxx.
◆ XmlPython()
XmlPython::XmlPython ( InputPyPort *  p)
Definition at line 33 of file XMLPythonConv.cxx.
34 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
35{
36}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void XmlPython::put ( const char *  data)
data: Xml::char *
Definition at line 49 of file XMLPythonConv.cxx.
50{
51 DEBTRACE(data);
52 xmlDocPtr doc;
53 xmlNodePtr cur;
54 PyObject *ob=NULL;
55{
57 doc = xmlParseMemory(data, strlen(data));
58 if (doc == NULL )
59 {
60 stringstream msg;
61 msg << "Problem in conversion: XML Document not parsed successfully ";
62 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
63 throw ConversionException(msg.str());
64 }
65 cur = xmlDocGetRootElement(doc);
66 if (cur == NULL)
67 {
68 xmlFreeDoc(doc);
69 stringstream msg;
70 msg << "Problem in conversion: empty XML Document";
71 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
72 throw ConversionException(msg.str());
73 }
74 while (cur != NULL)
75 {
76 if ((!xmlStrcmp(cur->name, (const xmlChar *)"value")))
77 {
79 break;
80 }
81 cur = cur->next;
82 }
83 xmlFreeDoc(doc);
84 if(ob==NULL)
85 {
86 stringstream msg;
87 msg << "Problem in conversion: incorrect XML value";
88 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
89 throw ConversionException(msg.str());
90 }
91// xmlCleanupParser();
92#ifdef _DEVDEBUG_
93 PyObject_Print(ob,stderr,Py_PRINT_RAW);
94 cerr << endl;
95#endif
96 _port->put(ob);
97 Py_XDECREF(ob);
98 DEBTRACE("ob refcnt: " << ob->ob_refcnt);
99 _port->setStringRef(data);
100}
101}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual void setStringRef(std::string strRef)
Definition: InputPort.cxx:169
static char doc[]
Definition: driver.cxx:63
PyObject * convertXmlPyObject(const TypeCode *t, xmlDocPtr doc, xmlNodePtr cur)
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertXmlPyObject(), DEBTRACE, doc, YACS::ENGINE::DataPort::edGetType(), testCppPluginInvokation::l, YACS::ENGINE::InputPort::put(), and YACS::ENGINE::InputPort::setStringRef().
◆ put() [2/2]
void XmlPython::put ( const void *  data)
Definition at line 38 of file XMLPythonConv.cxx.
39{
40 DEBTRACE((const char *)data);
41 put((const char *)data);
42}
References DEBTRACE, and put().
Referenced by put().
