YACS::ENGINE::NeutralCpp Class Reference
Class for conversion from Neutral Output port to Xml Input port. More...
#include <NeutralCppConv.hxx>
Inheritance diagram for YACS::ENGINE::NeutralCpp:
Collaboration diagram for YACS::ENGINE::NeutralCpp:
 NeutralCpp (InputCppPort *p)
 Convert a Any to a Any. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 36 of file NeutralCppConv.hxx.
◆ NeutralCpp()
YACS::ENGINE::NeutralCpp::NeutralCpp ( InputCppPort *  p)
Definition at line 40 of file NeutralCppConv.cxx.
41 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
42 {
43 }
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void YACS::ENGINE::NeutralCpp::put ( const void *  data)
transition method from const void* to Any*
data: const void * data
Definition at line 50 of file NeutralCppConv.cxx.
51 {
52 put((Any *)data);
53 }
References put().
Referenced by put().
◆ put() [2/2]
void YACS::ENGINE::NeutralCpp::put ( YACS::ENGINE::Any *  data)
data: Any object
Definition at line 59 of file NeutralCppConv.cxx.
60 {
61 Any *a = convertNeutralCpp(edGetType(),data);
62 DEBTRACE( "before put refcnt: " << a->getRefCnt() );
63 _port->put(a);
64 DEBTRACE( "after put refcnt: " << a->getRefCnt() );
65 //_port has called incRef
66 a->decrRef();
67 }
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Any * convertNeutralCpp(const TypeCode *t, Any *data)
References YACS::ENGINE::ProxyPort::_port, gui.CONNECTOR::a, YACS::ENGINE::convertNeutralCpp(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
