YACS::ENGINE::PyCpp Class Reference
#include <PythonCppConv.hxx>
Inheritance diagram for YACS::ENGINE::PyCpp:
Collaboration diagram for YACS::ENGINE::PyCpp:
 PyCpp (InputCppPort *p)
void put (PyObject *data)
 Convertit un PyObject de type entier en YACS::ENGINE::Any entier. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 32 of file PythonCppConv.hxx.
◆ PyCpp()
YACS::ENGINE::PyCpp::PyCpp ( InputCppPort *  p)
Definition at line 35 of file PythonCppConv.hxx.
36 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode()) {}
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void YACS::ENGINE::PyCpp::put ( const void *  data)
Definition at line 41 of file PythonCppConv.cxx.
42 {
43 put((PyObject *)data);
44 }
References put().
Referenced by put().
◆ put() [2/2]
void YACS::ENGINE::PyCpp::put ( PyObject *  data)
data: python object
Definition at line 51 of file PythonCppConv.cxx.
52 {
54 //Do not need to take the Python GIL as put is called from Python node
57 DEBTRACE( "before put refcnt: " << a->getRefCnt() );
58 _port->put(a);
59 //_port has called incRef
60 a->decrRef();
61 DEBTRACE( "after put refcnt: " << a->getRefCnt() );
62 }
Definition: Any.hxx:79
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Any * convertPyObjectCpp(const TypeCode *t, PyObject *data)
References YACS::ENGINE::ProxyPort::_port, gui.CONNECTOR::a, YACS::ENGINE::convertPyObjectCpp(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
