YACS::ENGINE::PyCorbaObjref Class Reference
#include <PythonCORBAConv.hxx>
Inheritance diagram for YACS::ENGINE::PyCorbaObjref:
Collaboration diagram for YACS::ENGINE::PyCorbaObjref:
 PyCorbaObjref (InputCorbaPort *p)
 Class PyCorbaObjref is a proxy port that converts a PyObject object (of type objref) to a CORBA::Any object (of type objref) More...
 Convert a PyObject (Objref) to CORBA::Any (Objref) More...
void put (PyObject *data)
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
PyObject * _pyorb
CORBA::ORB_ptr _orb
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 70 of file PythonCORBAConv.hxx.
◆ PyCorbaObjref()
PyCorbaObjref::PyCorbaObjref ( InputCorbaPort *  p)
p: the input CORBA port to adapt to Python output port
Definition at line 168 of file PythonCORBAConv.cxx.
169 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
170{
173 // _dynFactory = getSALOMERuntime()->getDynFactory();
174}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
CORBA::ORB_ptr getOrb() const
Proc * p
Definition: driver.cxx:216
References _orb, _pyorb, YACS::ENGINE::RuntimeSALOME::getOrb(), YACS::ENGINE::RuntimeSALOME::getPyOrb(), and YACS::ENGINE::getSALOMERuntime().
◆ put() [1/2]
void PyCorbaObjref::put ( const void *  data)
data: python object
Definition at line 181 of file PythonCORBAConv.cxx.
182{
183 put((PyObject *)data);
184}
References put().
Referenced by put().
◆ put() [2/2]
void PyCorbaObjref::put ( PyObject *  data)
Definition at line 186 of file PythonCORBAConv.cxx.
187{
188 DEBTRACE("data refcnt: " << data->ob_refcnt);
189#ifdef _DEVDEBUG_
190 PyObject_Print(data,stderr,Py_PRINT_RAW);
191 std::cerr << std::endl;
192#endif
193 CORBA::Any *a= convertPyObjectCorba(_port->edGetType(),data);
195 _port->put(a);
196 delete a;
197}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
CORBA::Any * convertPyObjectCorba(const TypeCode *t, PyObject *data)
References YACS::ENGINE::ProxyPort::_port, gui.CONNECTOR::a, YACS::ENGINE::convertPyObjectCorba(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
◆ _orb
CORBA::ORB_ptr YACS::ENGINE::PyCorbaObjref::_orb
Definition at line 78 of file PythonCORBAConv.hxx.
Referenced by PyCorbaObjref().
◆ _pyorb
PyObject* YACS::ENGINE::PyCorbaObjref::_pyorb
Definition at line 77 of file PythonCORBAConv.hxx.
