YACS::ENGINE::PyXml Class Reference
#include <PythonXMLConv.hxx>
Inheritance diagram for YACS::ENGINE::PyXml:
Collaboration diagram for YACS::ENGINE::PyXml:
 PyXml (InputXmlPort *p)
 Convert a PyObject that is convertible to Xml::char * and send it to proxy port. More...
void put (PyObject *data)
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 32 of file PythonXMLConv.hxx.
◆ PyXml()
PyXml::PyXml ( InputXmlPort *  p)
Definition at line 33 of file PythonXMLConv.cxx.
34 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
35{
36}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void PyXml::put ( const void *  data)
data: PyObject object as a void * pointer
Definition at line 43 of file PythonXMLConv.cxx.
44{
45 put((PyObject *)data);
46}
References put().
Referenced by put().
◆ put() [2/2]
void PyXml::put ( PyObject *  data)
Definition at line 52 of file PythonXMLConv.cxx.
53{
54 DEBTRACE("PyXml::put" );
55 std::string sss = convertPyObjectXml(edGetType(),data);
57 ((InputXmlPort*)_port)->put((const char*)sss.c_str());
58}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Class for XML Input Ports.
Definition: XMLPorts.hxx:38
std::string convertPyObjectXml(const TypeCode *t, PyObject *data)
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertPyObjectXml(), DEBTRACE, and YACS::ENGINE::DataPort::edGetType().
