YACS::ENGINE::CorbaNeutral Class Reference
#include <CORBANeutralConv.hxx>
Inheritance diagram for YACS::ENGINE::CorbaNeutral:
Collaboration diagram for YACS::ENGINE::CorbaNeutral:
 CorbaNeutral (InputPort *p)
 Convert a CORBA::Any that is convertible to a YACS::ENGINE::Any * and send it to proxy port. More...
void put (CORBA::Any *data)
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 34 of file CORBANeutralConv.hxx.
◆ CorbaNeutral()
CorbaNeutral::CorbaNeutral ( InputPort *  p)
Definition at line 31 of file CORBANeutralConv.cxx.
32 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
33{
34}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void CorbaNeutral::put ( const void *  data)
data: CORBA::Any object as a void * pointer
Definition at line 41 of file CORBANeutralConv.cxx.
42{
43 put((CORBA::Any *)data);
44}
References put().
Referenced by put().
◆ put() [2/2]
void CorbaNeutral::put ( CORBA::Any *  data)
Definition at line 50 of file CORBANeutralConv.cxx.
51{
52 DEBTRACE( "CorbaNeutral::put" )
53 YACS::ENGINE::Any *ob;
55 DEBTRACE("before put refcnt: " << ob->getRefCnt())
57 _port->put(ob);
58 // ob has been created in convertCorbaNeutral. _port has normally called incRef
59 ob->decrRef();
60 DEBTRACE("after put refcnt: " << ob->getRefCnt())
61}
Definition: Any.hxx:79
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: DataPort.hxx:55
YACS::ENGINE::Any * convertCorbaNeutral(const TypeCode *t, CORBA::Any *data)
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertCorbaNeutral(), DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::RefCounter::getRefCnt(), and YACS::ENGINE::InputPort::put().
