YACS::ENGINE::PyCorbaStruct Class Reference
#include <PythonCORBAConv.hxx>
Inheritance diagram for YACS::ENGINE::PyCorbaStruct:
Collaboration diagram for YACS::ENGINE::PyCorbaStruct:
 PyCorbaStruct (InputCorbaPort *p)
 Class PyCorbaStruct is a proxy port that converts a PyObject object (of type struct) to a CORBA::Any object (of type struct) More...
void put (PyObject *data)
 Convert a PyObject (struct) to CORBA::Any (struct) More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 89 of file PythonCORBAConv.hxx.
◆ PyCorbaStruct()
PyCorbaStruct::PyCorbaStruct ( InputCorbaPort *  p)
p: the input CORBA port to adapt to Python output port
Definition at line 203 of file PythonCORBAConv.cxx.
204 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
205{
206}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void PyCorbaStruct::put ( const void *  data)
Definition at line 208 of file PythonCORBAConv.cxx.
209{
210 put((PyObject *)data);
211}
References put().
Referenced by put().
◆ put() [2/2]
void PyCorbaStruct::put ( PyObject *  data)
data: python object
Definition at line 217 of file PythonCORBAConv.cxx.
218{
219 DEBTRACE("data refcnt: " << data->ob_refcnt);
220#ifdef _DEVDEBUG_
221 PyObject_Print(data,stderr,Py_PRINT_RAW);
222 std::cerr << std::endl;
223#endif
224 CORBA::Any *a= convertPyObjectCorba(_port->edGetType(),data);
226 _port->put(a);
227#ifdef REFCNT
228 DEBTRACE("refcount CORBA structTC: " << ((omni::TypeCode_base*)a->pd_tc.in())->pd_ref_count);
229#endif
230 //delete Any that has been allocated by convertPyObjectCorba
231 delete a;
232#ifdef REFCNT
233 DEBTRACE("refcount CORBA structTC: " << ((omni::TypeCode_base*)((InputCorbaPort*)_port)->getAny()->pd_tc.in())->pd_ref_count);
234#endif
235}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Class for CORBA Input Ports.
Definition: CORBAPorts.hxx:45
CORBA::Any * convertPyObjectCorba(const TypeCode *t, PyObject *data)
References YACS::ENGINE::ProxyPort::_port, gui.CONNECTOR::a, YACS::ENGINE::convertPyObjectCorba(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
