YACS::ENGINE::NeutralCorbaSequence Class Reference
#include <NeutralCORBAConv.hxx>
Inheritance diagram for YACS::ENGINE::NeutralCorbaSequence:
Collaboration diagram for YACS::ENGINE::NeutralCorbaSequence:
 NeutralCorbaSequence (InputCorbaPort *p)
 Convert a Neutral::Any sequence to CORBA::Any* Sequence. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 61 of file NeutralCORBAConv.hxx.
◆ NeutralCorbaSequence()
YACS::ENGINE::NeutralCorbaSequence::NeutralCorbaSequence ( InputCorbaPort *  p)
Definition at line 64 of file NeutralCORBAConv.hxx.
65 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode()) {}
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void NeutralCorbaSequence::put ( const void *  data)
Definition at line 85 of file NeutralCORBAConv.cxx.
86{
87 put((YACS::ENGINE::Any *)data);
88}
Definition: Any.hxx:79
References put().
Referenced by put().
◆ put() [2/2]
void NeutralCorbaSequence::put ( YACS::ENGINE::Any *  data)
data: Neutral::Any object
Definition at line 94 of file NeutralCORBAConv.cxx.
95{
96 CORBA::Any *a =convertNeutralCorba(edGetType(),data);
97 _port->put(a);
98 //delete Any that has been allocated by convertNeutralCorba
99 delete a;
100}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
CORBA::Any * convertNeutralCorba(const TypeCode *t, YACS::ENGINE::Any *data)
References YACS::ENGINE::ProxyPort::_port, gui.CONNECTOR::a, YACS::ENGINE::convertNeutralCorba(), YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
