YACS::ENGINE::PyCorbaSequence Class Reference
#include <PythonCORBAConv.hxx>
Inheritance diagram for YACS::ENGINE::PyCorbaSequence:
Collaboration diagram for YACS::ENGINE::PyCorbaSequence:
 PyCorbaSequence (InputCorbaPort *p)
 Class PyCorbaSequence is a proxy port that converts a PyObject object (of type sequence) to a CORBA::Any object (of type sequence) More...
 Convert a PyObject (sequence) to CORBA::Any (sequence) More...
void put (PyObject *data)
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 81 of file PythonCORBAConv.hxx.
◆ PyCorbaSequence()
PyCorbaSequence::PyCorbaSequence ( InputCorbaPort *  p)
p: the input CORBA port to adapt to Python output port
Definition at line 129 of file PythonCORBAConv.cxx.
130 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
131{
132}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void PyCorbaSequence::put ( const void *  data)
data: python object
Definition at line 139 of file PythonCORBAConv.cxx.
140{
141 put((PyObject *)data);
142}
References put().
Referenced by put().
◆ put() [2/2]
void PyCorbaSequence::put ( PyObject *  data)
Definition at line 144 of file PythonCORBAConv.cxx.
145{
146 DEBTRACE("data refcnt: " << data->ob_refcnt);
147#ifdef _DEVDEBUG_
148 PyObject_Print(data,stderr,Py_PRINT_RAW);
149 std::cerr << std::endl;
150#endif
151 CORBA::Any *a= convertPyObjectCorba(_port->edGetType(),data);
153 _port->put(a);
154#ifdef REFCNT
155 DEBTRACE("refcount CORBA seqTC: " << ((omni::TypeCode_base*)a->pd_tc.in())->pd_ref_count);
156#endif
157 //delete Any that has been allocated by convertPyObjectCorba
158 delete a;
159#ifdef REFCNT
160 DEBTRACE("refcount CORBA seqTC: " << ((omni::TypeCode_base*)((InputCorbaPort*)_port)->getAny()->pd_tc.in())->pd_ref_count);
161#endif
162}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Class for CORBA Input Ports.
Definition: CORBAPorts.hxx:45
CORBA::Any * convertPyObjectCorba(const TypeCode *t, PyObject *data)
References YACS::ENGINE::ProxyPort::_port, gui.CONNECTOR::a, YACS::ENGINE::convertPyObjectCorba(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
