YACS::ENGINE::CorbaXml Class Reference
#include <CORBAXMLConv.hxx>
Inheritance diagram for YACS::ENGINE::CorbaXml:
Collaboration diagram for YACS::ENGINE::CorbaXml:
 CorbaXml (InputXmlPort *p)
 Convert a CORBA::Any that is convertible to Xml::char * and send it to proxy port. More...
void put (CORBA::Any *data)
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 33 of file CORBAXMLConv.hxx.
◆ CorbaXml()
CorbaXml::CorbaXml ( InputXmlPort *  p)
Definition at line 31 of file CORBAXMLConv.cxx.
32 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
33{
34}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void CorbaXml::put ( const void *  data)
data: CORBA::Any object as a void * pointer
Definition at line 41 of file CORBAXMLConv.cxx.
42{
43 put((CORBA::Any *)data);
44}
References put().
Referenced by put().
◆ put() [2/2]
void CorbaXml::put ( CORBA::Any *  data)
Definition at line 50 of file CORBAXMLConv.cxx.
51{
52 DEBTRACE("CorbaXml::put" );
53 std::string sss = convertCorbaXml(edGetType(),data);
54 ((InputXmlPort*)_port)->put((const char*)sss.c_str());
55}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Class for XML Input Ports.
Definition: XMLPorts.hxx:38
std::string convertCorbaXml(const TypeCode *t, CORBA::Any *data)
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertCorbaXml(), DEBTRACE, and YACS::ENGINE::DataPort::edGetType().
