CORBAPorts.cxx
20//#define REFCNT
22#ifdef REFCNT
23#define private public
24#define protected public
25#include <omniORB4/CORBA.h>
26#include <omniORB4/internal/typecode.h>
27#endif
28
29#include "RuntimeSALOME.hxx"
30#include "TypeConversions.hxx"
31#include "TypeCode.hxx"
32#include "AutoLocker.hxx"
33#include "CORBAPorts.hxx"
34#include "PythonPorts.hxx"
35#include "ServiceNode.hxx"
36#include "ComponentInstance.hxx"
37#include "SALOME_GenericObj.hh"
38
39#include <iostream>
40#include <sstream>
41
42//#define _DEVDEBUG_
43#include "YacsTrace.hxx"
44
45using namespace YACS::ENGINE;
46using namespace std;
47
48void releaseObj(CORBA::Any& data)
49{
50 CORBA::Object_var obj;
51 if(data >>= CORBA::Any::to_object(obj))
52 {
53 SALOME::GenericObj_var gobj;
54 try
55 {
56 gobj=SALOME::GenericObj::_narrow(obj);
57 }
58 catch(const CORBA::SystemException& )
59 {
60 return;
61 }
62 if(!CORBA::is_nil(gobj))
63 {
64 DEBTRACE("It's a SALOME::GenericObj");
65 gobj->UnRegister();
66 }
67 else
68 DEBTRACE("It's a CORBA::Object but not a SALOME::GenericObj");
69 }
70 else
71 DEBTRACE("It's not a CORBA::Object");
72}
73
74void registerObj(CORBA::Any& data)
75{
76 CORBA::Object_var obj;
77 if(data >>= CORBA::Any::to_object(obj))
78 {
79 SALOME::GenericObj_var gobj;
80 try
81 {
82 gobj=SALOME::GenericObj::_narrow(obj);
83 }
84 catch(const CORBA::SystemException& )
85 {
86 return;
87 }
88 if(!CORBA::is_nil(gobj))
89 {
90 DEBTRACE("It's a SALOME::GenericObj");
91 gobj->Register();
92 }
93 else
94 DEBTRACE("It's a CORBA::Object but not a SALOME::GenericObj");
95 }
96 else
97 DEBTRACE("It's not a CORBA::Object");
98}
99
100InputCorbaPort::InputCorbaPort(const std::string& name,
101 Node *node,
102 TypeCode * type)
103 : InputPort(name, node, type), DataPort(name, node, type), Port(node), _initData(0)
104{
106}
107
108InputCorbaPort::InputCorbaPort(const InputCorbaPort& other, Node *newHelder):InputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder),
109 _initData(0)
110{
112 if(other._initData)
113 {
114 _initData=new CORBA::Any;
115 *_initData=*(other._initData);
116 }
117 _data=other._data;
118}
119
121{
122 delete _initData;
123 // Release or not release : all GenericObj are deleted when the input port is deleted
125}
126
128{
129 return _initData!=0;
130}
131
133{
134 delete _initData;
135 _initData=0;
137}
138
139void InputCorbaPort::put(const void *data)
140{
141 put((CORBA::Any *)data);
142}
143
144void display(CORBA::Any* data)
145{
146 CORBA::TypeCode_var tc=data->type();
147 switch(tc->kind())
148 {
149 case CORBA::tk_double:
151 *data >>= d;
152 DEBTRACE( "Double: " << d );
153 break;
154 case CORBA::tk_long:
155 CORBA::Long l;
156 *data >>= l;
157 DEBTRACE( "Int: " << l );
158 break;
159 default:
160 break;
161 }
162}
163
165{//do nothing - to be implemented
166}
167
168void InputCorbaPort::put(CORBA::Any *data)
169{
170#ifdef REFCNT
171 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)data->pd_tc.in())->pd_ref_count);
172#endif
174#ifdef _DEVDEBUG_
175 display(data);
176#endif
177
179
180 // make a copy of the any (protect against deletion of any source)
181 _data=*data;
182 _stringRef="";
183
185
186#ifdef REFCNT
187 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
188#endif
189}
190
192{
193 return new InputCorbaPort(*this,newHelder);
194}
195
197{
198 return (void *)&_data;
199}
200
202{
203 CORBA::TypeCode_var tc=_data.type();
204 return tc->equivalent(CORBA::_tc_null);
205}
206
208{
209 // --- return a pointer to internal any
210 return &_data;
211}
212
214{
216 CORBA::TypeCode_var tc=getAny()->type();
217 if (!tc->equivalent(CORBA::_tc_null))
219 else
220 {
221 Py_INCREF(Py_None);
222 return Py_None;
223 }
224}
225
227{
229 PyObject* ob=getPyObj();
230 std::string s=convertPyObjectToString(ob);
231 Py_DECREF(ob);
232 return s;
233}
234
235
237
241{
242 if(_initData)
243 delete _initData;
244 _initData=new CORBA::Any;
246}
247
249
253{
254 if(!_initData)return;
255 put(_initData);
256}
257
259{
260 CORBA::TypeCode_var tc=_data.type();
261 if (tc->equivalent(CORBA::_tc_null))
262 return "<value>nil</value>";
263 if (edGetType()->kind() != YACS::ENGINE::Objref)
264 return convertCorbaXml(edGetType(), &_data);
265 if (! _stringRef.empty())
266 return _stringRef;
267 else
268 return convertCorbaXml(edGetType(), &_data);
269// {
270// stringstream msg;
271// msg << "Cannot retreive init string reference string for port " << _name
272// << " on node " << _node->getName();
273// throw Exception(msg.str());
274// }
275}
276
278{
279 int isString = PyBytes_Check(getPyObj());
280 PyObject *strPyObj = PyObject_Str(getPyObj());
281 string val = PyBytes_AsString(strPyObj);
282 if (isString)
283 val = "\"" + val + "\"";
284 Py_DECREF(strPyObj);
285 return val;
286}
287
288void InputCorbaPort::valFromStr(std::string valstr)
289{
290}
291
292OutputCorbaPort::OutputCorbaPort(const std::string& name,
293 Node *node,
294 TypeCode * type)
295 : OutputPort(name, node, type), DataPort(name, node, type), Port(node)
296{
298}
299
300OutputCorbaPort::OutputCorbaPort(const OutputCorbaPort& other, Node *newHelder):OutputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder)
301{
303}
304
306{
307 DEBTRACE(getName());
308 // Release or not release : all GenericObj are deleted when the output port is deleted
310#ifdef REFCNT
311 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
312 DEBTRACE("refcount CORBA tc_double: " << ((omni::TypeCode_base*)CORBA::_tc_double)->pd_ref_count);
313#endif
314}
315
316void OutputCorbaPort::put(const void *data)
317{
318 put((CORBA::Any *)data);
319}
320
321void OutputCorbaPort::put(CORBA::Any *data)
322{
323 InputPort *p;
324
325 {
327#ifdef REFCNT
328 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)data->pd_tc.in())->pd_ref_count);
329#endif
330#ifdef REFCNT
331 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
332#endif
333
335
336 _data=*data;
337
338 //no registerObj : we steal the output reference of the node
339 }
340
341#ifdef REFCNT
342 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
343#endif
344 OutputPort::put(data);
345#ifdef REFCNT
346 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)data->pd_tc.in())->pd_ref_count);
347#endif
348#ifdef REFCNT
349 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
350#endif
351}
352
354{
355 return new OutputCorbaPort(*this,newHelder);
356}
357
359{
360 // return a pointer to the internal any
361 return &_data;
362}
363
365{
366 CORBA::Any* a=new CORBA::Any;
367 DynType kind=edGetType()->kind();
368 CORBA::TypeCode_var t;
369
370 if(kind == Int)
371 {
372 a->replace(CORBA::_tc_long, (void*) 0);
373 }
374 else if(kind == String)
375 {
376 a->replace(CORBA::_tc_string, (void*) 0);
377 }
378 else if(kind == Double)
379 {
380 a->replace(CORBA::_tc_double, (void*) 0);
381 }
382 else if(kind == Objref)
383 {
385 a->replace(t, (void*) 0);
386 }
387 else if(kind == Sequence)
388 {
390 a->replace(t, (void*) 0);
391 }
392 else if(kind == Struct)
393 {
395#ifdef REFCNT
396 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)t.in())->pd_ref_count);
397#endif
398 a->replace(t, (void*) 0);
399#ifdef REFCNT
400 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)t.in())->pd_ref_count);
401#endif
402 }
403 else if(kind == Bool)
404 {
405 a->replace(CORBA::_tc_boolean, (void*) 0);
406 }
407 else if(kind == NONE)
408 {
409 stringstream msg;
410 msg << "Cannot set Any Out for None" << __FILE__ << ":" << __LINE__;
411 throw Exception(msg.str());
412 }
413 else
414 {
415 stringstream msg;
416 msg << "Cannot set Any Out for unknown type" << __FILE__
417 << ":" << __LINE__;
418 throw Exception(msg.str());
419 }
420
421 DEBTRACE( "getAnyOut:a: " << a );
422#ifdef REFCNT
423 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)a->pd_tc.in())->pd_ref_count);
424#endif
425 return a;
426}
427
429{
431 CORBA::TypeCode_var tc=getAny()->type();
432 if (!tc->equivalent(CORBA::_tc_null))
434 else
435 {
436 Py_INCREF(Py_None);
437 return Py_None;
438 }
439}
440
442{
444 PyObject* ob=getPyObj();
445 std::string s=convertPyObjectToString(ob);
446 Py_DECREF(ob);
447 return s;
448}
449
451{
452 CORBA::TypeCode_var tc=_data.type();
453 if (tc->equivalent(CORBA::_tc_null))
454 return "<value>nil</value>";
455 string xmldump = convertCorbaXml(edGetType(), &_data);
456 return xmldump;
457}
458namespace YACS {
459 namespace ENGINE {
460 ostream& operator<<(ostream& os, const OutputCorbaPort& p)
461 {
463 p._data>>=l;
464 os << p._name << " : " << l ;
465 return os;
466 }
467 };
468};
469
471{
472 PyObject *strPyObj = PyObject_Str(getPyObj());
473 string val = PyBytes_AsString(strPyObj);
474 Py_DECREF(strPyObj);
475 return val;
476}
477
478void OutputCorbaPort::valFromStr(std::string valstr)
479{
480}
481
void display(CORBA::Any *data)
Definition: CORBAPorts.cxx:144
void registerObj(CORBA::Any &data)
Definition: CORBAPorts.cxx:74
void releaseObj(CORBA::Any &data)
Definition: CORBAPorts.cxx:48
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string getName() const
Definition: DataPort.hxx:55
Class for CORBA Input Ports.
Definition: CORBAPorts.hxx:45
Definition: CORBAPorts.cxx:226
virtual std::string valToStr()
Gives a string representation of the data, for user interfaces.
Definition: CORBAPorts.cxx:277
virtual void exRestoreInit()
Restore the saved data value to current data value.
Definition: CORBAPorts.cxx:252
void edRemoveManInit()
Removes eventually previous manual initialisation.
Definition: CORBAPorts.cxx:132
virtual std::string dump()
Definition: CORBAPorts.cxx:258
InputCorbaPort(const std::string &name, Node *node, TypeCode *type)
Definition: CORBAPorts.cxx:100
virtual void valFromStr(std::string valstr)
Allows to set data from a string representation used in user interface.
Definition: CORBAPorts.cxx:288
bool edIsManuallyInitialized() const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition: CORBAPorts.cxx:127
InputPort * clone(Node *newHelder) const
Definition: CORBAPorts.cxx:191
virtual CORBA::Any * getAny()
Definition: CORBAPorts.cxx:207
YACS::BASES::Mutex _mutex
Definition: CORBAPorts.hxx:72
Definition: CORBAPorts.cxx:139
virtual PyObject * getPyObj()
Definition: CORBAPorts.cxx:213
virtual void exSaveInit()
Save the current data value for further reinitialization of the port.
Definition: CORBAPorts.cxx:240
Base class for Input Ports.
Definition: InputPort.hxx:44
virtual void edRemoveManInit()
Definition: InputPort.cxx:140
std::string _stringRef
Definition: InputPort.hxx:90
Base class for all nodes.
Definition: Node.hxx:70
std::string _name
Definition: Node.hxx:89
Definition: CORBAPorts.cxx:450
OutputCorbaPort(const std::string &name, Node *node, TypeCode *type)
Definition: CORBAPorts.cxx:292
Definition: CORBAPorts.cxx:441
Definition: CORBAPorts.cxx:478
Definition: CORBAPorts.cxx:470
Definition: CORBAPorts.cxx:316
virtual CORBA::Any * getAnyOut()
Definition: CORBAPorts.cxx:364
Definition: CORBAPorts.hxx:103
OutputPort * clone(Node *newHelder) const
Definition: CORBAPorts.cxx:353
Definition: CORBAPorts.cxx:358
Definition: CORBAPorts.cxx:428
Definition: OutputPort.cxx:66
Base class for all ports.
Definition: Port.hxx:43
CORBA::ORB_ptr getOrb() const
Definition: TypeCode.hxx:68
DynType kind() const
Definition: TypeCode.cxx:47
Proc * p
Definition: driver.cxx:216
std::string convertPyObjectToString(PyObject *ob)
ostream & operator<<(ostream &os, const OutputCorbaPort &p)
Definition: CORBAPorts.cxx:460
CORBA::TypeCode_ptr getCorbaTC(const TypeCode *t)
PyObject * convertCorbaPyObject(const TypeCode *t, CORBA::Any *data)
std::string convertCorbaXml(const TypeCode *t, CORBA::Any *data)
