YACS::ENGINE::OutputCorbaPort Class Reference
#include <CORBAPorts.hxx>
Inheritance diagram for YACS::ENGINE::OutputCorbaPort:
Collaboration diagram for YACS::ENGINE::OutputCorbaPort:
 OutputCorbaPort (const std::string &name, Node *node, TypeCode *type)
 OutputCorbaPort (const OutputCorbaPort &other, Node *newHelder)
virtual ~OutputCorbaPort ()
void put (CORBA::Any *data)
OutputPort * clone (Node *newHelder) const
virtual CORBA::Any * getAny ()
virtual CORBA::Any * getAnyOut ()
virtual PyObject * getPyObj ()
virtual std::string dump ()
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
CORBA::Any _data
CORBA::ORB_ptr _orb
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
YACS::BASES::Mutex _mutex
Friends
std::ostream & operator<< (std::ostream &os, const OutputCorbaPort &p)
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 80 of file CORBAPorts.hxx.
◆ OutputCorbaPort() [1/2]
OutputCorbaPort::OutputCorbaPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 292 of file CORBAPorts.cxx.
295 : OutputPort(name, node, type), DataPort(name, node, type), Port(node)
296{
298}
Definition: DataPort.cxx:41
OutputPort(const OutputPort &other, Node *newHelder)
Definition: OutputPort.cxx:38
Port(Node *node)
Definition: Port.cxx:34
CORBA::ORB_ptr getOrb() const
References _orb, YACS::ENGINE::RuntimeSALOME::getOrb(), and YACS::ENGINE::getSALOMERuntime().
Referenced by clone().
◆ OutputCorbaPort() [2/2]
OutputCorbaPort::OutputCorbaPort ( const OutputCorbaPort &  other,
Node *  newHelder
Definition at line 300 of file CORBAPorts.cxx.
300 :OutputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder)
301{
303}
◆ ~OutputCorbaPort()
OutputCorbaPort::~OutputCorbaPort ( )
Definition at line 305 of file CORBAPorts.cxx.
306{
307 DEBTRACE(getName());
308 // Release or not release : all GenericObj are deleted when the output port is deleted
310#ifdef REFCNT
311 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
312 DEBTRACE("refcount CORBA tc_double: " << ((omni::TypeCode_base*)CORBA::_tc_double)->pd_ref_count);
313#endif
314}
void releaseObj(CORBA::Any &data)
Definition: CORBAPorts.cxx:48
std::string getName() const
Definition: DataPort.hxx:55
References _data, DEBTRACE, YACS::ENGINE::DataPort::getName(), and releaseObj().
◆ clone()
OutputPort * OutputCorbaPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::OutputPort.
Definition at line 353 of file CORBAPorts.cxx.
354{
355 return new OutputCorbaPort(*this,newHelder);
356}
OutputCorbaPort(const std::string &name, Node *node, TypeCode *type)
Definition: CORBAPorts.cxx:292
References OutputCorbaPort().
◆ dump()
std::string OutputCorbaPort::dump ( )
Reimplemented from YACS::ENGINE::OutputPort.
Definition at line 450 of file CORBAPorts.cxx.
451{
452 CORBA::TypeCode_var tc=_data.type();
453 if (tc->equivalent(CORBA::_tc_null))
454 return "<value>nil</value>";
455 string xmldump = convertCorbaXml(edGetType(), &_data);
456 return xmldump;
457}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string convertCorbaXml(const TypeCode *t, CORBA::Any *data)
References _data, YACS::ENGINE::convertCorbaXml(), and YACS::ENGINE::DataPort::edGetType().
◆ getAny()
CORBA::Any * OutputCorbaPort::getAny ( )
Definition at line 358 of file CORBAPorts.cxx.
359{
360 // return a pointer to the internal any
361 return &_data;
362}
References _data.
Referenced by getPyObj().
◆ getAnyOut()
CORBA::Any * OutputCorbaPort::getAnyOut ( )
Definition at line 364 of file CORBAPorts.cxx.
365{
366 CORBA::Any* a=new CORBA::Any;
367 DynType kind=edGetType()->kind();
368 CORBA::TypeCode_var t;
369
370 if(kind == Int)
371 {
372 a->replace(CORBA::_tc_long, (void*) 0);
373 }
374 else if(kind == String)
375 {
376 a->replace(CORBA::_tc_string, (void*) 0);
377 }
378 else if(kind == Double)
379 {
380 a->replace(CORBA::_tc_double, (void*) 0);
381 }
382 else if(kind == Objref)
383 {
385 a->replace(t, (void*) 0);
386 }
387 else if(kind == Sequence)
388 {
390 a->replace(t, (void*) 0);
391 }
392 else if(kind == Struct)
393 {
395#ifdef REFCNT
396 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)t.in())->pd_ref_count);
397#endif
398 a->replace(t, (void*) 0);
399#ifdef REFCNT
400 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)t.in())->pd_ref_count);
401#endif
402 }
403 else if(kind == Bool)
404 {
405 a->replace(CORBA::_tc_boolean, (void*) 0);
406 }
407 else if(kind == NONE)
408 {
409 stringstream msg;
410 msg << "Cannot set Any Out for None" << __FILE__ << ":" << __LINE__;
411 throw Exception(msg.str());
412 }
413 else
414 {
415 stringstream msg;
416 msg << "Cannot set Any Out for unknown type" << __FILE__
417 << ":" << __LINE__;
418 throw Exception(msg.str());
419 }
420
421 DEBTRACE( "getAnyOut:a: " << a );
422#ifdef REFCNT
423 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)a->pd_tc.in())->pd_ref_count);
424#endif
425 return a;
426}
DynType kind() const
Definition: TypeCode.cxx:47
CORBA::TypeCode_ptr getCorbaTC(const TypeCode *t)
References gui.CONNECTOR::a, YACS::ENGINE::Bool, DEBTRACE, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::getCorbaTC(), YACS::ENGINE::Int, YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::NONE, YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, YACS::ENGINE::Struct, and gui.Appli::t.
◆ getAsString()
std::string OutputCorbaPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 441 of file CORBAPorts.cxx.
442{
444 PyObject* ob=getPyObj();
445 std::string s=convertPyObjectToString(ob);
446 Py_DECREF(ob);
447 return s;
448}
virtual PyObject * getPyObj()
Definition: CORBAPorts.cxx:428
std::string convertPyObjectToString(PyObject *ob)
References YACS::ENGINE::convertPyObjectToString(), and getPyObj().
◆ getPyObj()
PyObject * OutputCorbaPort::getPyObj ( )
Definition at line 428 of file CORBAPorts.cxx.
429{
431 CORBA::TypeCode_var tc=getAny()->type();
432 if (!tc->equivalent(CORBA::_tc_null))
434 else
435 {
436 Py_INCREF(Py_None);
437 return Py_None;
438 }
439}
Definition: CORBAPorts.hxx:103
virtual CORBA::Any * getAny()
Definition: CORBAPorts.cxx:358
PyObject * convertCorbaPyObject(const TypeCode *t, CORBA::Any *data)
References _mutex, YACS::ENGINE::convertCorbaPyObject(), YACS::ENGINE::DataPort::edGetType(), and getAny().
Referenced by getAsString(), and valToStr().
◆ put() [1/2]
void OutputCorbaPort::put ( const void *  data)
Definition at line 316 of file CORBAPorts.cxx.
317{
318 put((CORBA::Any *)data);
319}
Definition: CORBAPorts.cxx:316
References put().
Referenced by put().
◆ put() [2/2]
void OutputCorbaPort::put ( CORBA::Any *  data)
Definition at line 321 of file CORBAPorts.cxx.
322{
323 InputPort *p;
324
325 {
327#ifdef REFCNT
328 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)data->pd_tc.in())->pd_ref_count);
329#endif
330#ifdef REFCNT
331 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
332#endif
333
335
336 _data=*data;
337
338 //no registerObj : we steal the output reference of the node
339 }
340
341#ifdef REFCNT
342 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
343#endif
344 OutputPort::put(data);
345#ifdef REFCNT
346 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)data->pd_tc.in())->pd_ref_count);
347#endif
348#ifdef REFCNT
349 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
350#endif
351}
Base class for Input Ports.
Definition: InputPort.hxx:44
Definition: OutputPort.cxx:66
Proc * p
Definition: driver.cxx:216
References _data, _mutex, DEBTRACE, p, YACS::ENGINE::OutputPort::put(), and releaseObj().
◆ typeName()
virtual std::string YACS::ENGINE::OutputCorbaPort::typeName ( )
Definition at line 96 of file CORBAPorts.hxx.
96{return "YACS__ENGINE__OutputCorbaPort";}
◆ valFromStr()
void OutputCorbaPort::valFromStr ( std::string  valstr)
Allows to set data from a string representation used in user interface.
Implemented in derived classes, depending on runtime, to set the data from its user interface representation. Typical use, a Python string representation that can be used in edition or restitution.
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 478 of file CORBAPorts.cxx.
479{
480}
◆ valToStr()
std::string OutputCorbaPort::valToStr ( )
Gives a string representation of the data, for user interfaces.
Implemented in derived classes, depending on runtime, to provide the data representation for user interfaces. Typical use, a Python string representation that can be used in edition or restitution.
Definition at line 470 of file CORBAPorts.cxx.
471{
472 PyObject *strPyObj = PyObject_Str(getPyObj());
473 string val = PyBytes_AsString(strPyObj);
474 Py_DECREF(strPyObj);
475 return val;
476}
References getPyObj().
◆ operator<<
std::ostream & operator<< ( std::ostream &  os,
const OutputCorbaPort &  p
friend
◆ _data
CORBA::Any YACS::ENGINE::OutputCorbaPort::_data
Definition at line 100 of file CORBAPorts.hxx.
Referenced by dump(), getAny(), put(), and ~OutputCorbaPort().
◆ _mutex
YACS::BASES::Mutex YACS::ENGINE::OutputCorbaPort::_mutex
Definition at line 103 of file CORBAPorts.hxx.
Referenced by getPyObj(), and put().
◆ _orb
CORBA::ORB_ptr YACS::ENGINE::OutputCorbaPort::_orb
Definition at line 101 of file CORBAPorts.hxx.
Referenced by OutputCorbaPort().
