YACS::ENGINE::CppContainer Class Reference
#include <CppContainer.hxx>
Inheritance diagram for YACS::ENGINE::CppContainer:
Collaboration diagram for YACS::ENGINE::CppContainer:
 CppContainer ()
virtual ~CppContainer ()
std::string getKind () const
bool isAlreadyStarted (const Task *askingNode) const
void start (const Task *askingNode)
void shutdown (int level)
std::string getPlacementId (const Task *askingNode) const
std::string getFullPlacementId (const Task *askingNode) const
YACS::ENGINE::Container * clone () const
 WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method More...
Container * cloneAlways () const
void lock ()
void unLock ()
void checkCapabilityToDealWith (const ComponentInstance *inst) const
bool loadComponentLibrary (const std::string &componentName)
CppComponent * createComponentInstance (const std::string &componentName)
void createInternalInstance (const std::string &componentName, void *&obj, RunFunction &r, TerminateFunction &t)
void unregisterComponentInstance (CppComponent *C)
void setProperty (const std::string &name, const std::string &value)
std::string getProperty (const std::string &name) const
void clearProperties ()
void addComponentName (const std::string &name)
std::map< std::string, std::string > getProperties () const
std::map< std::string, std::string > getResourceProperties (const std::string &name) const
- Public Member Functions inherited from YACS::ENGINE::Container
virtual std::string getKind () const =0
virtual std::string getDiscreminantStrOfThis (const Task *askingNode) const
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void start (const Task *askingNode)=0
virtual void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name)
virtual bool isUsingPythonCache ()
virtual void usePythonCache (bool v)
virtual std::string getPlacementId (const Task *askingNode) const =0
virtual std::string getFullPlacementId (const Task *askingNode) const =0
virtual void setAttachOnCloningStatus (bool val) const
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
virtual bool isAttachedOnCloning () const
virtual void lock ()=0
virtual void unLock ()=0
virtual Container * clone () const =0
virtual Container * cloneAlways () const =0
virtual bool isSupportingRTODefNbOfComp () const
virtual void checkCapabilityToDealWith (const ComponentInstance *inst) const =0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name) const =0
virtual void clearProperties ()=0
virtual void addComponentName (const std::string &name)=0
virtual std::map< std::string, std::string > getProperties () const =0
virtual std::map< std::string, std::string > getResourceProperties (const std::string &name) const =0
virtual void setProperties (const std::map< std::string, std::string > &properties)
virtual std::string getName () const
void setName (std::string name)
 WARNING ! name is used in edition to identify different containers, it is not the runtime name of the container More...
void setProc (Proc *proc)
Proc * getProc ()
virtual void shutdown (int level)=0
void incrRef () const
bool decrRef () const
Static Public Attributes
static char KIND [] ="Cpp"
- Static Public Attributes inherited from YACS::ENGINE::Container
static const char KIND_ENTRY [] ="container_kind"
static const char AOC_ENTRY [] ="attached_on_cloning"
static const char USE_PYCACHE_PROPERTY [] ="use_py_cache"
YACS::BASES::Mutex _mutex
LocalContainer * _trueCont
- Protected Attributes inherited from YACS::ENGINE::Container
bool _isAttachedOnCloning
Proc * _proc
unsigned int _cnt
Friends
class CppComponent
class LocalContainer
- Protected Member Functions inherited from YACS::ENGINE::Container
 Container ()
virtual ~Container ()
 RefCounter ()
virtual ~RefCounter ()
Definition at line 103 of file CppContainer.hxx.
◆ CppContainer()
CppContainer::CppContainer ( )
Local C++ container class constructor
Definition at line 51 of file CppContainer.cxx.
51 : _trueCont(0L)
52{
53 DEBTRACE("CppContainer::CppContainer()");
54}
References DEBTRACE.
Referenced by clone(), and cloneAlways().
◆ ~CppContainer()
CppContainer::~CppContainer ( )
Local C++ container class destructor
Definition at line 63 of file CppContainer.cxx.
64{
65 DEBTRACE("CppContainer::~CppContainer()");
66}
◆ addComponentName()
void YACS::ENGINE::CppContainer::addComponentName ( const std::string &  name)
Implements YACS::ENGINE::Container.
Definition at line 131 of file CppContainer.hxx.
131{ }
◆ checkCapabilityToDealWith()
void CppContainer::checkCapabilityToDealWith ( const ComponentInstance *  inst) const
Definition at line 171 of file CppContainer.cxx.
172{
173 if(inst->getKind()!=CppComponent::KIND)
174 throw Exception("CppContainer::checkCapabilityToDealWith : CppContainer is not able to deal with this type of ComponentInstance.");
175}
Return the component kind.
static const char KIND[]
References YACS::ENGINE::ComponentInstance::getKind(), and YACS::ENGINE::CppComponent::KIND.
◆ clearProperties()
void YACS::ENGINE::CppContainer::clearProperties ( )
Definition at line 130 of file CppContainer.hxx.
130{ }
◆ clone()
Container * CppContainer::clone ( ) const
Definition at line 98 of file CppContainer.cxx.
99{
101 {
102 incrRef();
103 return (Container*) (this);
104 }
105 else
106 return new CppContainer(*this);
107}
References YACS::ENGINE::Container::_isAttachedOnCloning, CppContainer(), and YACS::ENGINE::RefCounter::incrRef().
◆ cloneAlways()
Container * CppContainer::cloneAlways ( ) const
Definition at line 109 of file CppContainer.cxx.
110{
111 return new CppContainer(*this);
112}
References CppContainer().
◆ createComponentInstance()
CppComponent * CppContainer::createComponentInstance ( const std::string &  componentName)
Definition at line 129 of file CppContainer.cxx.
130{
131 DEBTRACE("CppContainer::createComponentInstance");
132 if (_trueCont)
133 return _trueCont->createComponentInstance(componentName.c_str());
134 else
135 {
136 std::string mesg = "CppContainer not started";
137 throw YACS::Exception(mesg);
138 }
139}
CppComponent * createComponentInstance(const char *componentName)
Find or create a new C++ component instance.
References _trueCont, YACS::ENGINE::LocalContainer::createComponentInstance(), and DEBTRACE.
◆ createInternalInstance()
void CppContainer::createInternalInstance ( const std::string &  componentName,
void *&  obj,
RunFunction &  r,
TerminateFunction &  t
Definition at line 141 of file CppContainer.cxx.
143{
144 DEBTRACE("CppContainer::createInternalInstance");
145 if (_trueCont)
146 _trueCont->createInternalInstance(name.c_str(), obj, r, t);
147 else
148 {
149 std::string mesg = "CppContainer not started";
150 throw YACS::Exception(mesg);
151 }
152}
void createInternalInstance(const char *componentName, void *&obj, RunFunction &r, TerminateFunction &t)
References _trueCont, YACS::ENGINE::LocalContainer::createInternalInstance(), DEBTRACE, testCppPluginInvokation::r, and gui.Appli::t.
Referenced by YACS::ENGINE::CppComponent::load().
◆ getFullPlacementId()
std::string CppContainer::getFullPlacementId ( const Task *  askingNode) const
Definition at line 166 of file CppContainer.cxx.
167{
168 return "/";
169}
◆ getKind()
std::string CppContainer::getKind ( ) const
Definition at line 78 of file CppContainer.cxx.
79{
80 return KIND;
81}
References KIND.
◆ getPlacementId()
std::string CppContainer::getPlacementId ( const Task *  askingNode) const
Definition at line 161 of file CppContainer.cxx.
162{
163 return "/";
164}
◆ getProperties()
std::map< std::string, std::string > YACS::ENGINE::CppContainer::getProperties ( ) const
Definition at line 132 of file CppContainer.hxx.
132{ return std::map<std::string,std::string>(); }
◆ getProperty()
std::string YACS::ENGINE::CppContainer::getProperty ( const std::string &  name) const
Definition at line 129 of file CppContainer.hxx.
129{ return std::string(); }
◆ getResourceProperties()
std::map< std::string, std::string > YACS::ENGINE::CppContainer::getResourceProperties ( const std::string &  name) const
Definition at line 133 of file CppContainer.hxx.
133{ return std::map<std::string,std::string>(); }
◆ isAlreadyStarted()
bool CppContainer::isAlreadyStarted ( const Task *  askingNode) const
Definition at line 83 of file CppContainer.cxx.
84{
85 return NULL != _trueCont;
86}
References _trueCont.
◆ loadComponentLibrary()
bool CppContainer::loadComponentLibrary ( const std::string &  componentName)
Definition at line 114 of file CppContainer.cxx.
115 {
116 if (_trueCont)
117 {
118 LocalLibrary L = _trueCont->loadComponentLibrary(componentName);
119 return L.good();
120 }
121 else
122 {
123 std::string mesg = "CppContainer not started";
124 throw YACS::Exception(mesg);
125 }
126 return false;
127 }
LocalLibrary loadComponentLibrary(const std::string &, const char *prefix=NULL, bool forcedLoad=false)
References _trueCont, YACS::ENGINE::LocalLibrary::good(), and YACS::ENGINE::LocalContainer::loadComponentLibrary().
◆ lock()
void CppContainer::lock ( )
Definition at line 68 of file CppContainer.cxx.
69{
70 _mutex.lock();
71}
References _mutex.
◆ setProperty()
void YACS::ENGINE::CppContainer::setProperty ( const std::string &  name,
const std::string &  value
Definition at line 128 of file CppContainer.hxx.
128{ }
◆ shutdown()
void CppContainer::shutdown ( int  level)
Definition at line 93 of file CppContainer.cxx.
94{
95
96}
◆ start()
void CppContainer::start ( const Task *  askingNode)
Definition at line 88 of file CppContainer.cxx.
89{
91}
static YACS::ENGINE::LocalContainer * get()
References _trueCont, and YACS::ENGINE::LocalContainer::get().
◆ unLock()
void CppContainer::unLock ( )
Definition at line 73 of file CppContainer.cxx.
74{
75 _mutex.unLock();
76}
References _mutex.
◆ unregisterComponentInstance()
void CppContainer::unregisterComponentInstance ( CppComponent *  C)
Definition at line 154 of file CppContainer.cxx.
155{
156 if (_trueCont)
158}
void unregisterComponentInstance(CppComponent *C)
References _trueCont, and YACS::ENGINE::LocalContainer::unregisterComponentInstance().
◆ CppComponent
friend class CppComponent
friend
Definition at line 105 of file CppContainer.hxx.
◆ LocalContainer
friend class LocalContainer
friend
Definition at line 106 of file CppContainer.hxx.
◆ _mutex
YACS::BASES::Mutex YACS::ENGINE::CppContainer::_mutex
Definition at line 138 of file CppContainer.hxx.
Referenced by lock(), and unLock().
◆ _trueCont
LocalContainer* YACS::ENGINE::CppContainer::_trueCont
◆ KIND
char CppContainer::KIND ="Cpp"
Definition at line 136 of file CppContainer.hxx.
Referenced by YACS::ENGINE::RuntimeSALOME::createContainer(), and getKind().
