YACS::ENGINE::LocalContainer Class Reference
#include <CppContainer.hxx>
Collaboration diagram for YACS::ENGINE::LocalContainer:
void destroy ()
LocalLibrary loadComponentLibrary (const std::string &, const char *prefix=NULL, bool forcedLoad=false)
CppComponent * createComponentInstance (const char *componentName)
 Find or create a new C++ component instance. More...
void createInternalInstance (const char *componentName, void *&obj, RunFunction &r, TerminateFunction &t)
void unLoadComponentLibrary (const std::string &aCompName)
void unregisterComponentInstance (CppComponent *C)
static YACS::ENGINE::LocalContainer * get ()
 LocalContainer ()
virtual ~LocalContainer ()
YACS::BASES::Mutex _instance_mapMutex
YACS::BASES::Mutex _library_mapMutex
Static Protected Attributes
static std::map< std::string, LocalLibrary > _library_map
static std::multimap< std::string, CppComponent * > _instance_map
Static Private Attributes
static LocalContainer * _singleton = NULL
Friends
class CppComponent
Definition at line 71 of file CppContainer.hxx.
◆ LocalContainer()
LocalContainer::LocalContainer ( )
Definition at line 182 of file CppContainer.cxx.
183{
184}
Referenced by get().
◆ ~LocalContainer()
LocalContainer::~LocalContainer ( )
Definition at line 186 of file CppContainer.cxx.
187{
188 destroy();
189}
References destroy().
◆ createComponentInstance()
CppComponent * LocalContainer::createComponentInstance ( const char *  name)
Create a new component class (C++ implementation)
Try to return a handle to an new instance of a C++ component If the associated library is not loaded, try to load it
a handle to the component instance or throw an exception if it's not possible
Definition at line 243 of file CppContainer.cxx.
244{
245 void *o;
248
249 createInternalInstance(name, o, r, t);
250
251 CppComponent * C;
252 C = new CppComponent(o, r, t, name);
253 _instance_mapMutex.lock(); // lock to be alone
254 _instance_map.insert(std::pair<std::string, CppComponent *>(name, C));
255 _instance_mapMutex.unLock(); // unlock
256 return C;
257}
void createInternalInstance(const char *componentName, void *&obj, RunFunction &r, TerminateFunction &t)
void(* RunFunction)(void *, const char *, int, int, Any **, Any **, returnInfo *)
void(* TerminateFunction)(void **)
References _instance_map, _instance_mapMutex, CppComponent, createInternalInstance(), testCppPluginInvokation::r, and gui.Appli::t.
Referenced by YACS::ENGINE::CppContainer::createComponentInstance().
◆ createInternalInstance()
void LocalContainer::createInternalInstance ( const char *  componentName,
void *&  obj,
RunFunction &  r,
TerminateFunction &  t
Definition at line 259 of file CppContainer.cxx.
261{
262 LocalLibrary L;
263
264 std::map<std::string, LocalLibrary>::iterator foundL = _library_map.find(name);
265 if (foundL != _library_map.end())
266 L = foundL->second;
267 else
268 L = loadComponentLibrary(name, NULL, false);
269
270 r = L.runHandle;
272 t = L.terminateHandle;
273
275 if (p) p();
276
277 obj = i();
278
279}
LocalLibrary loadComponentLibrary(const std::string &, const char *prefix=NULL, bool forcedLoad=false)
Proc * p
Definition: driver.cxx:216
void(* PingFunction)()
void *(* InitFunction)()
TerminateFunction terminateHandle
References _library_map, yacsorb.CORBAEngineTest::i, YACS::ENGINE::LocalLibrary::initHandle, loadComponentLibrary(), p, YACS::ENGINE::LocalLibrary::pingHandle, testCppPluginInvokation::r, YACS::ENGINE::LocalLibrary::runHandle, gui.Appli::t, and YACS::ENGINE::LocalLibrary::terminateHandle.
Referenced by createComponentInstance(), and YACS::ENGINE::CppContainer::createInternalInstance().
◆ destroy()
void LocalContainer::destroy ( )
Definition at line 200 of file CppContainer.cxx.
201{
202 if (NULL == _singleton)
203 return;
204
205 // destroy all component instances
206 _instance_mapMutex.lock(); // lock
207 std::multimap<std::string, CppComponent *>::iterator iI, iJ;
208 for (iI=_instance_map.begin(); iI != _instance_map.end(); iI = iJ)
209 {
210 iJ = iI++;
211 iI->second->setContainer(NULL);
212 delete iI->second;
213 }
214 _instance_map.clear();
215 _instance_mapMutex.unLock(); // unlock
216
217 // unload all dynamic libraries
218 _library_mapMutex.lock();
219 std::map<std::string, LocalLibrary>::iterator iL;
220 for (iL=_library_map.begin(); iL != _library_map.end(); iL++)
221 dlclose(iL->second.handle);
222 _library_map.clear();
223 _library_mapMutex.unLock();
224
225 delete _singleton;
226 _singleton = NULL;
227}
References _instance_map, _instance_mapMutex, _library_map, _library_mapMutex, and _singleton.
Referenced by ~LocalContainer().
◆ get()
LocalContainer * LocalContainer::get ( )
Definition at line 191 of file CppContainer.cxx.
192{
193 if (NULL == _singleton)
194 {
196 }
197 return _singleton;
198}
References _singleton, and LocalContainer().
Referenced by YACS::ENGINE::CppContainer::start().
◆ loadComponentLibrary()
LocalLibrary LocalContainer::loadComponentLibrary ( const std::string &  aCompName,
const char *  prefix = NULL,
bool  forcedLoad = false
Definition at line 293 of file CppContainer.cxx.
294{
295
296 // if forcedLoad is true, unload library if it exists
297 // if forcedLoad is false, return the existing library or load it
298
299 if (forcedLoad)
300 unLoadComponentLibrary(aCompName);
301 else
302 {
303 std::map<std::string, LocalLibrary >::iterator itLib
304 = _library_map.find(aCompName);
305 if (itLib != _library_map.end()) return itLib->second;
306 }
307
308 // --- try dlopen C++ component
309
310 std::string sprefix;
311 if (prefix)
312 sprefix = prefix;
313 else
314 {
315 std::string s = aCompName + "_ROOT_DIR";
316 toupper(s);
317 const char * t = getenv(s.c_str());
318 sprefix="";
319 if (t)
320 {
321 sprefix = t;
322 sprefix += "/lib/salome";
323 }
324 }
325
326#ifndef WIN32
327#ifdef __APPLE__
328 std::string impl_name = std::string ("lib") + aCompName + std::string("Local.dylib");
329#else
330 std::string impl_name = std::string ("lib") + aCompName + std::string("Local.so");
331#endif
332 if(sprefix != "")
333 impl_name = sprefix + std::string("/") + impl_name;
334#else
335 std::string impl_name = aCompName + std::string("Local.dll");
336 impl_name = sprefix + std::string("\\") + impl_name;
337#endif
338 DEBTRACE("impl_name = " << impl_name);
339
340#if defined( WIN32 )
341 HMODULE handle;
342#if defined(UNICODE)
343 size_t length = strlen(impl_name.c_str()) + sizeof(char);
344 wchar_t* aPath = new wchar_t[length + 1];
345 memset(aPath, '\0', length);
346 mbstowcs(aPath, impl_name.c_str(), length);
347#else
348 const char* aPath = fullLibName.c_str();
349#endif
350 handle = dlopen( aPath ) ;
351#else
352 void* handle;
353 handle = dlopen( impl_name.c_str() , RTLD_LAZY ) ;
354#endif
355
356 const char * sError;
357#if defined( WIN32 )
358 sError = "Not available here !";
359#endif
360
361#if defined( WIN32 )
362 if (!handle)
363#else
364 sError = dlerror();
365 if ((sError = dlerror()) || !handle)
366#endif
367 {
368 std::stringstream msg;
369 msg << "Can't load shared library : " << impl_name
370 << " (dlopen error : " << sError << ") at "
371 << __FILE__ << ":" << __LINE__;
372 throw YACS::Exception(msg.str());
373 }
374
375 void *ihandle, *rhandle, *phandle = NULL, *thandle = NULL;
376
377 ihandle = dlsym(handle, "__init");
378#if defined( WIN32 )
379 if (!ihandle)
380#else
381 if (sError = dlerror())
382#endif
383 {
384 dlclose(handle);
385 std::stringstream msg;
386 msg << "Library " << impl_name
387 << " doesn't contains initialization function (" << sError << ") at "
388 << __FILE__ << ":" << __LINE__;
389 throw YACS::Exception(msg.str());
390 }
391
392 rhandle = dlsym(handle, "__run");
393#if defined( WIN32 )
394 if (!rhandle)
395#else
396 if (sError = dlerror())
397#endif
398 {
399 dlclose(handle);
400 std::stringstream msg;
401 msg << "Library " << impl_name
402 << " doesn't contains main switch function (" << sError << ") at "
403 << __FILE__ << ":" << __LINE__;
404 throw YACS::Exception(msg.str());
405 }
406
407 thandle = dlsym(handle, "__terminate");
408#if defined( WIN32 )
409 if (!thandle)
410#else
411 if (sError = dlerror())
412#endif
413 {
414 dlclose(handle);
415 std::stringstream msg;
416 msg << "Library " << impl_name
417 << " doesn't contains terminate function (" << sError << ") at "
418 << __FILE__ << ":" << __LINE__;
419 throw YACS::Exception(msg.str());
420 }
421 phandle = dlsym(handle, "__ping");
422
423 _library_map[aCompName] = LocalLibrary(handle, (InitFunction) ihandle,
424 (RunFunction) rhandle,
425 (PingFunction) phandle,
426 (TerminateFunction) thandle);
427 return _library_map[aCompName];
428}
void toupper(std::string &s)
void unLoadComponentLibrary(const std::string &aCompName)
References _library_map, DEBTRACE, gui.Appli::t, toupper(), and unLoadComponentLibrary().
Referenced by createInternalInstance(), and YACS::ENGINE::CppContainer::loadComponentLibrary().
◆ unLoadComponentLibrary()
void LocalContainer::unLoadComponentLibrary ( const std::string &  aCompName)
Definition at line 430 of file CppContainer.cxx.
431{
432 std::map<std::string, LocalLibrary >::iterator itLib
433 = _library_map.find(aCompName);
434
435 if (itLib == _library_map.end()) return;
436
437 dlclose(itLib->second.handle);
438 _library_map.erase(itLib);
439
440}
References _library_map.
Referenced by loadComponentLibrary().
◆ unregisterComponentInstance()
void LocalContainer::unregisterComponentInstance ( CppComponent *  C)
Definition at line 281 of file CppContainer.cxx.
282{
283 _instance_mapMutex.lock(); // lock to be alone
284 _instance_map.erase(C->getCompoName());
285 _instance_mapMutex.unLock(); // unlock
286}
References _instance_map, _instance_mapMutex, and YACS::ENGINE::ComponentInstance::getCompoName().
Referenced by YACS::ENGINE::CppContainer::unregisterComponentInstance().
◆ CppComponent
friend class CppComponent
friend
Definition at line 73 of file CppContainer.hxx.
Referenced by createComponentInstance().
◆ _instance_map
std::multimap< std::string, CppComponent * > LocalContainer::_instance_map
staticprotected
Definition at line 94 of file CppContainer.hxx.
Referenced by createComponentInstance(), destroy(), and unregisterComponentInstance().
◆ _instance_mapMutex
YACS::BASES::Mutex YACS::ENGINE::LocalContainer::_instance_mapMutex
Definition at line 92 of file CppContainer.hxx.
◆ _library_map
std::map< std::string, LocalLibrary > LocalContainer::_library_map
staticprotected
◆ _library_mapMutex
YACS::BASES::Mutex YACS::ENGINE::LocalContainer::_library_mapMutex
Referenced by destroy().
◆ _singleton
LocalContainer * LocalContainer::_singleton = NULL
staticprivate
Definition at line 98 of file CppContainer.hxx.
Referenced by destroy(), and get().
