CppComponent.hxx
20#ifndef __YACS_CppCOMPONENT__
21#define __YACS_CppCOMPONENT__
23#include <string>
24#include "ComponentInstance.hxx"
26
27namespace YACS
28{
29 namespace ENGINE
30 {
31
32 class Any;
33
34 struct returnInfo {
35 int code;
36 std::string message;
37 };
38
39 typedef void * (*InitFunction)();
40 typedef void (*RunFunction) (void *, const char *, int, int, Any **, Any **, returnInfo *);
41 typedef void (*TerminateFunction)(void **);
42 typedef void (*PingFunction) ();
43
45 public:
46
47 CppComponent(const std::string & name);
49 const std::string & name)
50 : __obj(obj), __run(r), __terminate(t), ComponentInstance(name) {}
51 CppComponent(const CppComponent& other);
52 virtual ~CppComponent();
53
54 void run(const char * service, int nbIn, int nbOut,
55 Any ** argIn, Any ** argOut);
56
57 static const char KIND[];
58 virtual std::string getKind() const;
59 virtual std::string getKindForNode() const;
60 virtual void load(Task *askingNode);
61 virtual void unload(Task *askingNode);
62 virtual bool isLoaded(Task *askingNode) const;
63 virtual ServiceNode* createNode(const std::string& name);
64 virtual YACS::ENGINE::ComponentInstance* clone() const;
65 virtual YACS::ENGINE::ComponentInstance* cloneAlways() const;
66
67 protected:
68
69 void * __obj;
72 };
73 };
74};
75
76#endif
#define YACSRUNTIMESALOME_EXPORT
Definition: Any.hxx:79
YACS::ENGINE::TerminateFunction __terminate
CppComponent(void *obj, RunFunction r, TerminateFunction t, const std::string &name)
YACS::ENGINE::RunFunction __run
void(* RunFunction)(void *, const char *, int, int, Any **, Any **, returnInfo *)
void(* PingFunction)()
void(* TerminateFunction)(void **)
void * run(void *obj)
Definition: yacs_clt.cxx:54
