YACS::ENGINE::CppComponent Class Reference
#include <CppComponent.hxx>
Inheritance diagram for YACS::ENGINE::CppComponent:
Collaboration diagram for YACS::ENGINE::CppComponent:
 CppComponent (const std::string &name)
 CppComponent constructor. More...
 CppComponent (void *obj, RunFunction r, TerminateFunction t, const std::string &name)
 CppComponent (const CppComponent &other)
 CppComponent copy constructor. More...
virtual ~CppComponent ()
void run (const char *service, int nbIn, int nbOut, Any **argIn, Any **argOut)
virtual std::string getKind () const
 Return the component kind. More...
virtual std::string getKindForNode () const
virtual void load (Task *askingNode)
 Load the component instance. More...
virtual void unload (Task *askingNode)
 Unload the component. More...
virtual bool isLoaded (Task *askingNode) const
 Is the component instance already loaded ? More...
virtual ServiceNode * createNode (const std::string &name)
virtual YACS::ENGINE::ComponentInstance * clone () const
 Clone the component instance. More...
virtual YACS::ENGINE::ComponentInstance * cloneAlways () const
- Public Member Functions inherited from YACS::ENGINE::ComponentInstance
 ComponentInstance (const std::string &name)
 ComponentInstance (const ComponentInstance &other)
const std::string & getCompoName () const
const std::string & getInstanceName () const
virtual void setAnonymous (bool anon)
virtual bool isAnonymous ()
int getNumId () const
virtual bool setContainer (Container *cont)
Container * getContainer () const
virtual void load (Task *askingNode)=0
virtual void unload (Task *askingNode)=0
 Unload the component instance. More...
virtual bool isLoaded (Task *askingNode) const =0
 Indicate if the component instance is loaded (true) or not. More...
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
bool isAttachedOnCloning () const
virtual std::string getFileRepr () const
 For dump in file. More...
virtual ServiceNode * createNode (const std::string &name)=0
virtual ComponentInstance * clone () const =0
virtual ComponentInstance * cloneAlways () const =0
- Public Member Functions inherited from YACS::ENGINE::PropertyInterface
virtual ~PropertyInterface ()
 Get a property value given its name. More...
std::map< std::string, std::string > getProperties () const
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND [] = "Cpp"
- Static Public Attributes inherited from YACS::ENGINE::ComponentInstance
static const char KIND [] =""
void * __obj
YACS::ENGINE::RunFunction __run
YACS::ENGINE::TerminateFunction __terminate
- Protected Attributes inherited from YACS::ENGINE::ComponentInstance
std::string _compoName
 WARNING : _compoName identify only the component type. More...
std::string _instanceName
 WARNING : _InstanceName has a strong semantic. It discriminates ComponentInstance instances each other. More...
int _numId
Container * _container
bool _isAttachedOnCloning
bool _anonymous
- Protected Attributes inherited from YACS::ENGINE::PropertyInterface
unsigned int _cnt
- Protected Member Functions inherited from YACS::ENGINE::ComponentInstance
virtual ~ComponentInstance ()
 RefCounter ()
virtual ~RefCounter ()
- Static Protected Attributes inherited from YACS::ENGINE::ComponentInstance
static const char NULL_FILE_REPR [] ="No repr specified for ComponentInstance"
static int _total = 0
Definition at line 44 of file CppComponent.hxx.
◆ CppComponent() [1/3]
CppComponent::CppComponent ( const std::string &  name)
Definition at line 86 of file CppComponent.cxx.
86 : ComponentInstance(name), __obj(0), __run(0),__terminate(0)
87{
89 /* This part of code has been commented because the load part is supposed to do that !
90 if (!_container->isAlreadyStarted(0))
91 _container->start(0);
92 CppContainer * _containerC = dynamic_cast<CppContainer *> (_container);
93 _containerC->createInternalInstance(name, __obj, __run, __terminate);*/
94}
ComponentInstance(const std::string &name)
static const char KIND[]
Definition: CppNode.hxx:62
virtual Container * createContainer(const std::string &kind="")
Definition: Runtime.cxx:221
Definition: Runtime.cxx:61
References YACS::ENGINE::ComponentInstance::_container, YACS::ENGINE::Runtime::createContainer(), YACS::ENGINE::getRuntime(), and YACS::ENGINE::CppNode::KIND.
Referenced by clone(), and cloneAlways().
◆ CppComponent() [2/3]
YACS::ENGINE::CppComponent::CppComponent ( void *  obj,
RunFunction  r,
◆ CppComponent() [3/3]
CppComponent::CppComponent ( const CppComponent &  other)
Definition at line 97 of file CppComponent.cxx.
98{
100 /* This part of code has been commented because the load part is supposed to do that !
101 if (!_container->isAlreadyStarted(0))
102 _container->start(0);
103 CppContainer * _containerC = dynamic_cast<CppContainer *> (_container);
104 _containerC->createInternalInstance(_compoName, __obj, __run, __terminate);*/
105}
◆ ~CppComponent()
CppComponent::~CppComponent ( )
Definition at line 107 of file CppComponent.cxx.
108{
109 DEBTRACE("CppComponent::~CppComponent()");
111 if (_container)
112 ((CppContainer *) _container)->unregisterComponentInstance(this);
113}
References __obj, __terminate, YACS::ENGINE::ComponentInstance::_container, and DEBTRACE.
◆ clone()
ComponentInstance * CppComponent::clone ( ) const
Implements YACS::ENGINE::ComponentInstance.
Definition at line 215 of file CppComponent.cxx.
216{
218 {
219 incrRef();
220 return (ComponentInstance*) (this);
221 }
222 else
223 return new CppComponent(*this);
224}
CppComponent(const std::string &name)
References YACS::ENGINE::ComponentInstance::_isAttachedOnCloning, CppComponent(), and YACS::ENGINE::RefCounter::incrRef().
◆ cloneAlways()
YACS::ENGINE::ComponentInstance * CppComponent::cloneAlways ( ) const
Definition at line 226 of file CppComponent.cxx.
227{
228 return new CppComponent(*this);
229}
References CppComponent().
◆ createNode()
ServiceNode * CppComponent::createNode ( const std::string &  name)
Definition at line 207 of file CppComponent.cxx.
208{
209 CppNode* node=new CppNode(name);
210 node->setComponent(this);
211 return node;
212}
Class for C++ Nodes (in process component)
Definition: CppNode.hxx:47
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
References YACS::ENGINE::ServiceNode::setComponent().
◆ getKind()
std::string CppComponent::getKind ( ) const
A runtime can provide several implementations of a component instance. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode is they have the same kind.
Reimplemented from YACS::ENGINE::ComponentInstance.
Definition at line 75 of file CppComponent.cxx.
76{
77 return CppComponent::KIND;
78}
References KIND.
◆ getKindForNode()
std::string CppComponent::getKindForNode ( ) const
Definition at line 80 of file CppComponent.cxx.
81{
82 return CppComponent::KIND;
83}
References KIND.
◆ isLoaded()
bool CppComponent::isLoaded ( Task *  askingNode) const
Definition at line 160 of file CppComponent.cxx.
161{
162 return NULL != __obj;
163}
References __obj.
◆ load()
void CppComponent::load ( Task *  askingNode)
Definition at line 165 of file CppComponent.cxx.
166{
167 if (!_container)
168 {
170 }
171
172 if(_container)
173 {
174 CppContainer *containerC(dynamic_cast< CppContainer *> (_container));
175 if(!containerC)
176 throw Exception("The type of container should be CPP for component CPP !");
177 containerC->lock();//To be sure
178 if(!_container->isAlreadyStarted(askingNode))
179 {
180 try
181 {
182 _container->start(askingNode);
183 }
184 catch(Exception& e)
185 {
186 containerC->unLock();
187 throw e;
188 }
189 }
190 containerC->unLock();
191 containerC->lock();//To be sure
192
193 bool isLoadable(containerC->loadComponentLibrary(_compoName));
194 if (isLoadable)
195 containerC->createInternalInstance(_compoName, __obj, __run, __terminate);
196
197 if(NULL == __obj)
198 {
199 containerC->unLock();
200 throw Exception("CppComponent::load : Error while trying to create a new component.");
201 }
202 containerC->unLock();
203 return;
204 }
205}
virtual void start(const Task *askingNode)=0
virtual bool isAlreadyStarted(const Task *askingNode) const =0
References __obj, __run, __terminate, YACS::ENGINE::ComponentInstance::_compoName, YACS::ENGINE::ComponentInstance::_container, YACS::ENGINE::Runtime::createContainer(), YACS::ENGINE::CppContainer::createInternalInstance(), YACS::ENGINE::getRuntime(), YACS::ENGINE::Container::isAlreadyStarted(), YACS::ENGINE::CppNode::KIND, YACS::ENGINE::CppContainer::loadComponentLibrary(), YACS::ENGINE::CppContainer::lock(), YACS::ENGINE::Container::start(), and YACS::ENGINE::CppContainer::unLock().
◆ run()
void CppComponent::run ( const char *  service,
int  nbIn,
int  nbOut,
Any **  argIn,
Any **  argOut
Definition at line 115 of file CppComponent.cxx.
117{
118 int i;
119 returnInfo return_code;
120
121#ifdef _DEVDEBUG_
122 std::ostringstream sDebug;
123 sDebug << getInstanceName() << "::" << service << "(";
124 for (i=0; i<nbIn; i++) {
125 sDebug << *(argIn[i]);
126 if (i<nbIn-1)
127 sDebug << ", ";
128 }
129 sDebug << ")";
130#endif
131
132 __run(__obj, service, nbIn, nbOut, argIn, argOut, &return_code);
133
134 if (return_code.code != 0) {
135#ifdef _DEVDEBUG_
136 std::cerr << sDebug << " ???" << std::endl;
137#endif
138 throw YACS::Exception(return_code.message);
139 }
140
141#ifdef _DEVDEBUG_
142 if (nbOut > 0) {
143 sDebug << "->";
144 for (i=0; i<nbOut; i++) {
145 sDebug << " " << *(argOut[i]);
146 }
147 }
148 DEBTRACE(sDebug.str());
149#endif
150}
const std::string & getInstanceName() const
References __obj, __run, YACS::ENGINE::returnInfo::code, DEBTRACE, YACS::ENGINE::ComponentInstance::getInstanceName(), yacsorb.CORBAEngineTest::i, and YACS::ENGINE::returnInfo::message.
Referenced by YACS::ENGINE::CppNode::execute().
◆ unload()
void CppComponent::unload ( Task *  askingNode)
Definition at line 153 of file CppComponent.cxx.
154{
155 //Not implemented
156 DEBTRACE("CppComponent::unload : not implemented ");
157}
References DEBTRACE.
◆ __obj
void* YACS::ENGINE::CppComponent::__obj
Definition at line 69 of file CppComponent.hxx.
Referenced by isLoaded(), load(), run(), and ~CppComponent().
◆ __run
YACS::ENGINE::RunFunction YACS::ENGINE::CppComponent::__run
Definition at line 70 of file CppComponent.hxx.
Referenced by load(), and run().
◆ __terminate
YACS::ENGINE::TerminateFunction YACS::ENGINE::CppComponent::__terminate
Definition at line 71 of file CppComponent.hxx.
Referenced by load(), and ~CppComponent().
◆ KIND
const char CppComponent::KIND = "Cpp"
