commands.cxx
20#include "commands.hxx"
21#include "guiContext.hxx"
22#include "Proc.hxx"
23#include "Catalog.hxx"
24#include "RuntimeSALOME.hxx"
26//#define _DEVDEBUG_
27#include "YacsTrace.hxx"
28#include <sstream>
30using namespace std;
31
32using namespace YACS;
33using namespace YACS::HMI;
34
35int Invocator::_ctr = 0;
36
37Command::Command()
38{
39 _subCommands.clear();
40 _normalReverse = true;
41}
42
44
52{
53 if ( !GuiContext::getCurrent() || !GuiContext::getCurrent()->getInvoc() )
54 return false;
55
56 bool commandInProgress = !GuiContext::getCurrent()->getInvoc()->isSpecialReverse();
57 if (commandInProgress)
59
60 bool ret=true;
61 if (GuiContext::getCurrent()->getInvoc()->_isRedo && _normalReverse)
62 {
63 for (int i=0; i<_subCommands.size(); i++)
64 delete _subCommands[i];
65 _subCommands.clear();
66 }
67 ret = localExecute();
68 if (ret) GuiContext::getCurrent()->setNotSaved(true);
69
70 if (commandInProgress)
72 return ret;
73}
74
76
79bool Command::reverse(bool isNormal)
80{
81 bool ret=true;
82 if (! _subCommands.empty())
83 {
84 for (int i=0; i<_subCommands.size(); i++)
85 {
86 ret =_subCommands[i]->reverse(isNormal);
87 if (!ret) break;
88 }
89 }
90 if (ret)
91 {
92 if (isNormal) // true for all commands but commandDestroy
93 ret = localReverse();
94 else
95 ret = localExecute(); // subCommand of command Destroy
96 }
97 return ret;
98}
99
101
106{
107 bool ret=true;
108 if (! _subCommands.empty())
109 {
110 for (int i=0; i<_subCommands.size(); i++)
111 {
112 ret =_subCommands[i]->reverse(false);
113 if (!ret) break;
114 }
115 }
116 return ret;
117}
118
119std::string Command::dump()
120{
121 return "=== generic command dump ===";
122}
123
124std::string Command::recursiveDump(int level)
125{
126 string prefix = "";
127 for (int i=0; i<level; i++) prefix += " ";
128 string ret = prefix + dump() + "\n";
129 for (int i=0; i<_subCommands.size(); i++)
130 ret += _subCommands[i]->recursiveDump(level+1);
131 return ret;
132}
133
135{
136 _subCommands.push_back(command);
137}
138
139
140
141
142
144{
145 _commandsDone.clear();
146 _commandsUndone.clear();
147 _commandsInProgress.clear();
148 _isRedo = false;
149 _isUndo = false;
150 _specialReverse = false;
151 _undoCata = new YACS::ENGINE::Catalog("undoCata");
153 _undoProc= runTime->createProc("undoProc");
154}
155
157{
158 DEBTRACE("Invocator::add");
159 if(_isUndo)
160 return;
161 if (GuiContext::getCurrent()->getInvoc()->isSpecialReverse())
162 {
163 delete command;
164 return;
165 }
166 if (_commandsInProgress.empty())
167 {
168 _commandsDone.push_back(command); // --- to do after execute ok
169 _commandsUndone.clear(); // --- undone stack is no more relevant
170 }
171 else
172 {
173 DEBTRACE("addSubCommand");
174 _commandsInProgress.back()->addSubCommand(command);
175 }
176}
177
179{
180 DEBTRACE("Invocator::undo");
181 bool ret = true;
182
183 {
184 stringstream ret1;
185 ret1 << "_commandsDone" << endl;
186 for (int i=0; i<_commandsDone.size(); i++)
187 ret1 << i << _commandsDone[i]->recursiveDump(2);
188 DEBTRACE(ret1.str());
189 stringstream ret2;
190 ret2 << "_commandsUndone" << endl;
191 for (int i=0; i<_commandsUndone.size(); i++)
192 ret2 << i << _commandsUndone[i]->recursiveDump(2);
193 DEBTRACE(ret2.str());
194 }
195
196 if (! _commandsDone.empty())
197 {
198 bool isNormal = _commandsDone.back()->isNormalReverse();
199 _specialReverse = !isNormal;
200 _isUndo=true;
201 if (isNormal)
202 ret = _commandsDone.back()->reverse(isNormal);
203 else
204 ret = _commandsDone.back()->executeSubOnly();
205 _isUndo=false;
206 _commandsUndone.push_back(_commandsDone.back());
207 _commandsDone.pop_back();
208 _specialReverse = false;
209 }
210
211 {
212 stringstream ret1;
213 ret1 << "_commandsDone" << endl;
214 for (int i=0; i<_commandsDone.size(); i++)
215 ret1 << i << _commandsDone[i]->recursiveDump(2);
216 DEBTRACE(ret1.str());
217 stringstream ret2;
218 ret2 << "_commandsUndone" << endl;
219 for (int i=0; i<_commandsUndone.size(); i++)
220 ret2 << i << _commandsUndone[i]->recursiveDump(2);
221 DEBTRACE(ret2.str());
222 }
223
224 return ret;
225}
226
228{
229 DEBTRACE("Invocator::redo");
230 bool ret = true;
231
232 {
233 stringstream ret1;
234 ret1 << "_commandsDone" << endl;
235 for (int i=0; i<_commandsDone.size(); i++)
236 ret1 << i << _commandsDone[i]->recursiveDump(2);
237 DEBTRACE(ret1.str());
238 stringstream ret2;
239 ret2 << "_commandsUndone" << endl;
240 for (int i=0; i<_commandsUndone.size(); i++)
241 ret2 << i << _commandsUndone[i]->recursiveDump(2);
242 DEBTRACE(ret2.str());
243 }
244
245 if (! _commandsUndone.empty())
246 {
247 _isRedo=true;
248 ret = _commandsUndone.back()->execute();
249 _isRedo=false;
250 _commandsDone.push_back(_commandsUndone.back());
251 _commandsUndone.pop_back();
252 }
253
254 {
255 stringstream ret1;
256 ret1 << "_commandsDone" << endl;
257 for (int i=0; i<_commandsDone.size(); i++)
258 ret1 << i << _commandsDone[i]->recursiveDump(2);
259 DEBTRACE(ret1.str());
260 stringstream ret2;
261 ret2 << "_commandsUndone" << endl;
262 for (int i=0; i<_commandsUndone.size(); i++)
263 ret2 << i << _commandsUndone[i]->recursiveDump(2);
264 DEBTRACE(ret2.str());
265 }
266
267 return ret;
268}
269
270std::list<std::string> Invocator::getDone()
271{
272 list<string> listDone;
273 listDone.clear();
274 for (int i=0; i<_commandsDone.size(); i++)
275 listDone.push_back(_commandsDone[i]->recursiveDump());
276 return listDone;
277}
278
279std::list<std::string> Invocator::getUndone()
280{
281 list<string> listUndone;
282 listUndone.clear();
283 for (int i=0; i<_commandsUndone.size(); i++)
284 listUndone.push_back(_commandsUndone[i]->recursiveDump());
285 return listUndone;
286}
class for YACS catalogs.
Definition: Catalog.hxx:42
virtual Proc * createProc(const std::string &name)
virtual bool reverse(bool isNormal=true)
Reverse action: undo.
Definition: commands.cxx:79
virtual bool executeSubOnly()
execute only sub commands in a reverse action
Definition: commands.cxx:105
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
virtual bool localExecute()=0
std::vector< Command * > _subCommands
Definition: commands.hxx:52
std::string recursiveDump(int level=0)
Definition: commands.cxx:124
virtual bool localReverse()=0
void addSubCommand(Command *command)
Definition: commands.cxx:134
virtual std::string dump()
Definition: commands.cxx:119
void setNotSaved(bool isNotSaved)
Definition: guiContext.hxx:64
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
void add(Command *command)
Definition: commands.cxx:156
YACS::ENGINE::Proc * _undoProc
Definition: commands.hxx:75
YACS::ENGINE::Catalog * _undoCata
Definition: commands.hxx:76
std::vector< Command * > _commandsUndone
Definition: commands.hxx:73
std::vector< Command * > _commandsDone
Definition: commands.hxx:72
std::list< std::string > getUndone()
Definition: commands.cxx:279
std::vector< Command * > _commandsInProgress
Definition: commands.hxx:74
std::list< std::string > getDone()
Definition: commands.cxx:270
