YACS::HMI::Command Class Referenceabstract
#include <commands.hxx>
Inheritance diagram for YACS::HMI::Command:
Collaboration diagram for YACS::HMI::Command:
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
bool _normalReverse
Definition at line 38 of file commands.hxx.
◆ Command()
Command::Command ( )
Definition at line 37 of file commands.cxx.
38{
39 _subCommands.clear();
40 _normalReverse = true;
41}
std::vector< Command * > _subCommands
Definition: commands.hxx:52
References _normalReverse, and _subCommands.
◆ addSubCommand()
void Command::addSubCommand ( Command *  command)
Definition at line 134 of file commands.cxx.
135{
136 _subCommands.push_back(command);
137}
References _subCommands.
◆ dump()
std::string Command::dump ( )
Reimplemented in YACS::HMI::CommandAddNodeFromCatalog, YACS::HMI::CommandReparentNode, YACS::HMI::CommandPutInComposedNode, YACS::HMI::CommandCopyNode, YACS::HMI::CommandRenameNode, YACS::HMI::CommandRenameContainer, YACS::HMI::CommandRenameInDataPort, YACS::HMI::CommandRenameOutDataPort, YACS::HMI::CommandAddDataTypeFromCatalog, YACS::HMI::CommandAddInputPortFromCatalog, YACS::HMI::CommandAddOutputPortFromCatalog, YACS::HMI::CommandAddIDSPortFromCatalog, YACS::HMI::CommandAddODSPortFromCatalog, YACS::HMI::CommandOrderInputPorts, YACS::HMI::CommandOrderOutputPorts, YACS::HMI::CommandSetInPortValue, YACS::HMI::CommandSetOutPortValue, YACS::HMI::CommandSetSwitchSelect, YACS::HMI::CommandSetSwitchCase, YACS::HMI::CommandSetForLoopSteps, YACS::HMI::CommandSetWhileCondition, YACS::HMI::CommandSetForEachBranch, YACS::HMI::CommandSetAlgo, YACS::HMI::CommandAddLink, YACS::HMI::CommandAddControlLink, YACS::HMI::CommandAddContainer, YACS::HMI::CommandAddHPContainer, YACS::HMI::CommandSetContainerProperties, YACS::HMI::CommandSetNodeProperties, YACS::HMI::CommandSetComponentInstanceProperties, YACS::HMI::CommandSetDSPortProperties, YACS::HMI::CommandSetLinkProperties, YACS::HMI::CommandSetFuncNodeFunctionName, YACS::HMI::CommandSetInlineNodeScript, YACS::HMI::CommandAddComponentInstance, YACS::HMI::CommandSetExecutionMode, YACS::HMI::CommandSetContainer, YACS::HMI::CommandAssociateComponentToContainer, YACS::HMI::CommandAssociateServiceToComponent, YACS::HMI::CommandAddComponentFromCatalog, and YACS::HMI::CommandDestroy.
Definition at line 119 of file commands.cxx.
120{
121 return "=== generic command dump ===";
122}
Referenced by recursiveDump().
◆ execute()
bool Command::execute ( )
the command is executed a first time after its registration for undo redo, then on redo
Execute may induce subcommands to be registered during its execution. Subcommands must be deleted before redo, to be recreated by redo. CommandDestroy is a special case, where subcommands are registered before Execute, and undo action calls executeSubOnly instead of reverse. Subcommands pf CommandDestroy must not be deleted.
Definition at line 51 of file commands.cxx.
52{
53 if ( !GuiContext::getCurrent() || !GuiContext::getCurrent()->getInvoc() )
54 return false;
55
56 bool commandInProgress = !GuiContext::getCurrent()->getInvoc()->isSpecialReverse();
57 if (commandInProgress)
59
60 bool ret=true;
61 if (GuiContext::getCurrent()->getInvoc()->_isRedo && _normalReverse)
62 {
63 for (int i=0; i<_subCommands.size(); i++)
64 delete _subCommands[i];
65 _subCommands.clear();
66 }
67 ret = localExecute();
68 if (ret) GuiContext::getCurrent()->setNotSaved(true);
69
70 if (commandInProgress)
72 return ret;
73}
virtual bool localExecute()=0
void setNotSaved(bool isNotSaved)
Definition: guiContext.hxx:64
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
std::vector< Command * > _commandsInProgress
Definition: commands.hxx:74
References YACS::HMI::Invocator::_commandsInProgress, _normalReverse, _subCommands, YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), yacsorb.CORBAEngineTest::i, YACS::HMI::Invocator::isSpecialReverse(), localExecute(), and YACS::HMI::GuiContext::setNotSaved().
Referenced by YACS::HMI::SubjectProc::addComponent(), YACS::HMI::SubjectProc::addComSubjectDataType(), YACS::HMI::SubjectProc::addContainer(), YACS::HMI::SubjectProc::addDataType(), YACS::HMI::SubjectProc::addHPContainer(), YACS::HMI::SubjectElementaryNode::addIDSPort(), YACS::HMI::SubjectElementaryNode::addInputPort(), YACS::HMI::SubjectElementaryNode::addODSPort(), YACS::HMI::SubjectElementaryNode::addOutputPort(), YACS::HMI::SubjectServiceNode::associateToComponent(), YACS::HMI::SubjectComponent::associateToContainer(), YACS::HMI::SubjectNode::copy(), YACS::HMI::SubjectComposedNode::createNode(), YACS::HMI::Subject::destroy(), YACS::HMI::SubjectElementaryNode::OrderDataPorts(), YACS::HMI::SubjectNode::putInComposedNode(), YACS::HMI::SubjectNode::reparent(), YACS::HMI::SubjectOptimizerLoop::setAlgorithm(), YACS::HMI::SubjectSwitch::setCase(), YACS::HMI::SubjectServiceNode::setComponentFromCatalog(), YACS::HMI::SubjectWhileLoop::setCondition(), YACS::HMI::SubjectInlineNode::setContainer(), YACS::HMI::SubjectInlineNode::setExecutionMode(), YACS::HMI::SubjectPyFuncNode::setFunctionName(), YACS::HMI::SubjectDataPort::setName(), YACS::HMI::SubjectNode::setName(), YACS::HMI::SubjectContainerBase::setName(), YACS::HMI::SubjectDynParaLoop::setNbBranches(), YACS::HMI::SubjectForLoop::setNbSteps(), YACS::HMI::SubjectInputDataStreamPort::setProperties(), YACS::HMI::SubjectOutputDataStreamPort::setProperties(), YACS::HMI::SubjectNode::setProperties(), YACS::HMI::SubjectContainerBase::setProperties(), YACS::HMI::SubjectComponent::setProperties(), YACS::HMI::SubjectLink::setProperties(), YACS::HMI::SubjectInlineNode::setScript(), YACS::HMI::SubjectSwitch::setSelect(), YACS::HMI::SubjectInputPort::setValue(), YACS::HMI::SubjectOutputPort::setValue(), YACS::HMI::SubjectDataPort::tryCreateLink(), and YACS::HMI::SubjectNode::tryCreateLink().
◆ executeSubOnly()
bool Command::executeSubOnly ( )
execute only sub commands in a reverse action
for undo of commandDestroy, only sub commands of commandDestroy must be executed, via subcommand->reverse(false)
Definition at line 105 of file commands.cxx.
106{
107 bool ret=true;
108 if (! _subCommands.empty())
109 {
110 for (int i=0; i<_subCommands.size(); i++)
111 {
112 ret =_subCommands[i]->reverse(false);
113 if (!ret) break;
114 }
115 }
116 return ret;
117}
References _subCommands, and yacsorb.CORBAEngineTest::i.
◆ isNormalReverse()
bool YACS::HMI::Command::isNormalReverse ( )
Definition at line 48 of file commands.hxx.
48{ return _normalReverse; };
References _normalReverse.
◆ localExecute()
virtual bool YACS::HMI::Command::localExecute ( )
protectedpure virtual
Implemented in YACS::HMI::CommandAddNodeFromCatalog, YACS::HMI::CommandReparentNode, YACS::HMI::CommandPutInComposedNode, YACS::HMI::CommandCopyNode, YACS::HMI::CommandRenameNode, YACS::HMI::CommandRenameContainer, YACS::HMI::CommandRenameInDataPort, YACS::HMI::CommandRenameOutDataPort, YACS::HMI::CommandAddDataTypeFromCatalog, YACS::HMI::CommandAddInputPortFromCatalog, YACS::HMI::CommandAddOutputPortFromCatalog, YACS::HMI::CommandAddIDSPortFromCatalog, YACS::HMI::CommandAddODSPortFromCatalog, YACS::HMI::CommandOrderInputPorts, YACS::HMI::CommandOrderOutputPorts, YACS::HMI::CommandSetInPortValue, YACS::HMI::CommandSetOutPortValue, YACS::HMI::CommandSetSwitchSelect, YACS::HMI::CommandSetSwitchCase, YACS::HMI::CommandSetForLoopSteps, YACS::HMI::CommandSetWhileCondition, YACS::HMI::CommandSetForEachBranch, YACS::HMI::CommandSetAlgo, YACS::HMI::CommandAddLink, YACS::HMI::CommandAddControlLink, YACS::HMI::CommandAddContainerBase, YACS::HMI::CommandSetContainerProperties, YACS::HMI::CommandSetNodeProperties, YACS::HMI::CommandSetComponentInstanceProperties, YACS::HMI::CommandSetDSPortProperties, YACS::HMI::CommandSetLinkProperties, YACS::HMI::CommandSetFuncNodeFunctionName, YACS::HMI::CommandSetInlineNodeScript, YACS::HMI::CommandAddComponentInstance, YACS::HMI::CommandSetExecutionMode, YACS::HMI::CommandSetContainer, YACS::HMI::CommandAssociateComponentToContainer, YACS::HMI::CommandAssociateServiceToComponent, YACS::HMI::CommandAddComponentFromCatalog, and YACS::HMI::CommandDestroy.
Referenced by execute(), and reverse().
◆ localReverse()
virtual bool YACS::HMI::Command::localReverse ( )
Referenced by reverse().
◆ recursiveDump()
std::string Command::recursiveDump ( int  level = 0)
Definition at line 124 of file commands.cxx.
125{
126 string prefix = "";
127 for (int i=0; i<level; i++) prefix += " ";
128 string ret = prefix + dump() + "\n";
129 for (int i=0; i<_subCommands.size(); i++)
130 ret += _subCommands[i]->recursiveDump(level+1);
131 return ret;
132}
std::string recursiveDump(int level=0)
Definition: commands.cxx:124
virtual std::string dump()
Definition: commands.cxx:119
References _subCommands, dump(), yacsorb.CORBAEngineTest::i, and recursiveDump().
◆ reverse()
bool Command::reverse ( bool  isNormal = true)
Recursive reverse of sub commands then local action
isNormaltrue for ordinary command, false for command Destroy
Definition at line 79 of file commands.cxx.
80{
81 bool ret=true;
82 if (! _subCommands.empty())
83 {
84 for (int i=0; i<_subCommands.size(); i++)
85 {
86 ret =_subCommands[i]->reverse(isNormal);
87 if (!ret) break;
88 }
89 }
90 if (ret)
91 {
92 if (isNormal) // true for all commands but commandDestroy
93 ret = localReverse();
94 else
95 ret = localExecute(); // subCommand of command Destroy
96 }
97 return ret;
98}
virtual bool localReverse()=0
References _subCommands, yacsorb.CORBAEngineTest::i, localExecute(), and localReverse().
◆ _normalReverse
bool YACS::HMI::Command::_normalReverse
◆ _subCommands
std::vector<Command*> YACS::HMI::Command::_subCommands
Definition at line 52 of file commands.hxx.
Referenced by addSubCommand(), Command(), execute(), executeSubOnly(), recursiveDump(), and reverse().
