YACS::HMI::CommandCopyNode Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandCopyNode:
Collaboration diagram for YACS::HMI::CommandCopyNode:
 CommandCopyNode (YACS::ENGINE::Proc *fromproc, std::string position, std::string newParent, int acase=0)
YACS::ENGINE::Node * getNode ()
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _position
std::string _newParent
std::string _newName
int _case
YACS::ENGINE::Node * _clone
YACS::ENGINE::Proc * _fromproc
bool _normalReverse
Definition at line 169 of file commandsProc.hxx.
◆ CommandCopyNode()
CommandCopyNode::CommandCopyNode ( YACS::ENGINE::Proc *  fromproc,
int  acase = 0
Definition at line 668 of file commandsProc.cxx.
672 : Command(), _fromproc(fromproc), _position(position), _newParent(newParent), _newName(""), _clone(0), _case(swCase)
673{
674 DEBTRACE("CommandCopyNode::CommandCopyNode " << _position << " " << _newParent);
675}
References _newParent, _position, and DEBTRACE.
◆ dump()
std::string CommandCopyNode::dump ( )
Definition at line 677 of file commandsProc.cxx.
678{
679 string ret ="CommandCopyNode " + _position + " " + _newParent;
680 return ret;
681}
References _newParent, and _position.
◆ getNode()
YACS::ENGINE::Node * CommandCopyNode::getNode ( )
Definition at line 683 of file commandsProc.cxx.
684{
685 return _clone;
686}
References _clone.
◆ localExecute()
bool CommandCopyNode::localExecute ( )
Definition at line 688 of file commandsProc.cxx.
689{
690 DEBTRACE("CommandCopyNode::localExecute");
692 Node* node = 0;
693 try
694 {
695 if (_position == _fromproc->getName())
696 throw YACS::Exception("Copy the proc (main bloc) is impossible");
698 ComposedNode *oldFather = node->getFather();
699 ComposedNode *newFather = proc;
700 Node *newF = 0;
701 if (_newParent != proc->getName())
702 {
703 newF = proc->getChildByName(_newParent);
704 newFather = dynamic_cast<ComposedNode*>(newF);
705 }
706 if (!newFather)
707 throw YACS::Exception("new parent must be a composed node");
708 if (Loop *loop = dynamic_cast<Loop*>(newFather))
709 if (!loop->edGetDirectDescendants().empty())
710 throw YACS::Exception("Already a node in a new parent of Loop type");
711 //_clone = node->cloneWithoutCompAndContDeepCpy(newFather);
713 if (!_clone)
714 throw YACS::Exception("Node cannot be cloned");
715 int nodeSuffix = -1;
716 bool sameName = true;
717 stringstream s;
718 do
719 {
720 s.str("");
721 s << node->getName();
722 if (nodeSuffix >= 0) // --- first try <0 means without suffix
723 s << nodeSuffix;
724 DEBTRACE(s.str());
725 try
726 {
727 Node *nodeSameName = newFather->getChildByName(s.str());
728 }
729 catch (Exception& e)
730 {
731 sameName = false;
732 }
733 nodeSuffix++;
734 }
735 while(sameName);
736 _clone->setName(s.str());
738
739 if (YACS::ENGINE::Switch* theswitch = dynamic_cast<YACS::ENGINE::Switch*>(newFather))
740 {
741 DEBTRACE("father is a switch " << newFather->getName());
742 int theCase=_case;
743 if(theswitch->edGetNode(_case))
744 {
745 //the case is already used. Try another one
746 theCase=theswitch->getMaxCase()+1;
747 }
748 theswitch->edSetNode(theCase,_clone);
749 }
750 else
751 newFather->edAddChild(_clone);
752
755
757 SubjectComposedNode *snp = dynamic_cast<SubjectComposedNode*>(sub);
758 SubjectNode *son = snp->addSubjectNode(_clone);
759 son->loadChildren();
760 son->loadLinks();
761 }
762 catch (Exception& ex)
763 {
764 DEBTRACE("CommandCopyNode::localExecute() : " << ex.what());
766 _clone = 0;
767 }
768 return (_clone != 0);
769}
std::string getName() const
virtual bool edAddChild(Node *DISOWNnode)
Base class for loop node.
Definition: Loop.hxx:147
Base class for all nodes.
Definition: Node.hxx:70
Definition: Node.hxx:125
ComposedNode * getFather() const
Definition: Node.hxx:127
std::string getQualifiedName() const
same as Node::getName() in most cases, but differs for children of switch
Definition: Node.cxx:632
Change the name of the node.
Definition: Node.cxx:162
Node * cloneWithoutCompAndContDeepCpy(ComposedNode *father, bool editionOnly=true) const
This method MUST NEVER BE VIRTUAL
Definition: Node.cxx:150
Definition: Proc.hxx:44
Definition: Switch.hxx:85
Definition: guiContext.hxx:67
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
SubjectNode * addSubjectNode(YACS::ENGINE::Node *node, std::string name="", YACS::ENGINE::Catalog *catalog=0, std::string compo="", std::string type="")
virtual void loadLinks()
virtual void loadChildren()
References _case, _clone, _fromproc, YACS::HMI::GuiContext::_mapOfSubjectNode, _newName, _newParent, _position, YACS::HMI::SubjectComposedNode::addSubjectNode(), YACS::ENGINE::Node::cloneWithoutCompAndContDeepCpy(), DEBTRACE, YACS::ENGINE::ComposedNode::edAddChild(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getFather(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::Node::getQualifiedName(), YACS::HMI::Subject::loadChildren(), YACS::HMI::Subject::loadLinks(), setErrorMsg(), and YACS::ENGINE::Node::setName().
◆ localReverse()
bool CommandCopyNode::localReverse ( )
Definition at line 771 of file commandsProc.cxx.
772{
773 DEBTRACE("CommandCopyNode::localReverse " << _position << " " << _newParent);
774 try
775 {
777 string nodeName = _newParent + "." + _newName;
778 if (_newParent == proc->getName())
779 nodeName = _newName;
780 DEBTRACE(nodeName);
781 _clone = proc->getChildByName(nodeName);
782
783 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(_clone));
785 Subject *father = snode->getParent();
786 Subject::erase(snode);
787 _clone = 0;
788 if (father)
789 {
790 DEBTRACE("REMOVE");
791 father->select(true);
792 father->update(REMOVE,0,0);
793 }
794 return true;
795 }
796 catch (Exception& ex)
797 {
798 DEBTRACE("CommandCopyNode::localReverse(): " << ex.what());
800 return false;
801 }
802 return true;
803}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
virtual void select(bool isSelected)
References _clone, YACS::HMI::GuiContext::_mapOfSubjectNode, _newName, _newParent, _position, DEBTRACE, YACS::HMI::Subject::erase(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComposedNode::getName(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::REMOVE, YACS::HMI::Subject::select(), setErrorMsg(), YACS::HMI::Subject::update(), and YASSERT.
◆ _case
int YACS::HMI::CommandCopyNode::_case
Definition at line 184 of file commandsProc.hxx.
Referenced by localExecute().
◆ _clone
YACS::ENGINE::Node* YACS::HMI::CommandCopyNode::_clone
Definition at line 185 of file commandsProc.hxx.
Referenced by getNode(), localExecute(), and localReverse().
◆ _fromproc
YACS::ENGINE::Proc* YACS::HMI::CommandCopyNode::_fromproc
Definition at line 186 of file commandsProc.hxx.
◆ _newName
std::string YACS::HMI::CommandCopyNode::_newName
Definition at line 183 of file commandsProc.hxx.
Referenced by localExecute(), and localReverse().
◆ _newParent
std::string YACS::HMI::CommandCopyNode::_newParent
Definition at line 182 of file commandsProc.hxx.
Referenced by CommandCopyNode(), dump(), localExecute(), and localReverse().
◆ _position
std::string YACS::HMI::CommandCopyNode::_position
Definition at line 181 of file commandsProc.hxx.
