20#ifndef _GUIOBSERVERS_HXX_
21#define _GUIOBSERVERS_HXX_
55 class SalomePythonNode;
68 class InputDataStreamPort;
69 class OutputDataStreamPort;
71 class ComponentInstance;
73 class HomogeneousPoolContainer;
116 class SubjectReference;
125 virtual void select(
bool isSelected);
127 virtual std::string getName();
128 virtual bool setName(std::string name);
129 virtual bool setProperties(std::map<std::string, std::string> properties);
130 virtual std::map<std::string, std::string> getProperties();
131 virtual std::vector<std::string> knownProperties();
133 virtual void setParent(
Subject* son);
134 virtual bool destroy(
Subject *son);
135 virtual void loadChildren();
136 virtual void loadLinks();
137 virtual void addSubjectReference(
Subject *
ref);
138 virtual void clean(
Command *command=0);
139 void localclean(
140 void registerUndoDestroy();
143 static void erase(
Subject* sub,
Command *command=0,
bool post=
false);
145 virtual void setProgress( std::string newProgress );
160 virtual void select(
bool isSelected);
162 virtual void incrementSubjects(
Subject *subject);
163 virtual void decrementSubjects(
Subject *subject);
166 static std::string eventName(
GuiEvent event);
167 static void setEventMap();
179 virtual void select(
bool isSelected);
208 virtual std::string getName();
209 virtual bool setName(std::string name);
212 virtual void clean(
213 void localclean(
217 virtual bool setValue(std::string value);
218 void setExecValue(std::string value);
219 std::string getExecValue();
220 void registerUndoDestroy();
234 virtual bool setValue(std::string value);
247 virtual bool setValue(std::string value);
258 virtual bool setProperties(std::map<std::string, std::string> properties);
274 virtual bool setProperties(std::map<std::string, std::string> properties);
294 virtual bool setProperties(std::map<std::string, std::string> properties);
295 virtual std::map<std::string, std::string> getProperties();
296 virtual bool reparent(
Subject* parent);
297 virtual bool copy(
Subject* parent);
298 virtual std::string getName();
299 virtual bool setName(std::string name);
301 virtual void clean(
302 void registerUndoDestroy();
311 void localclean(
314 virtual void removeExternalLinks();
315 virtual void removeExternalControlLinks();
316 virtual void saveLinks();
317 virtual void restoreLinks();
318 virtual bool putInComposedNode(std::string name,std::string type,
bool toSaveRestoreLinks=
true);
319 virtual int isValid();
320 void setExecState(
int execState);
325 std::string name =
327 std::string name =
329 std::string name =
331 std::string name =
344 std::vector< std::pair<YACS::ENGINE::OutPort *, YACS::ENGINE::InPort *> >
dataLinks;
345 std::vector< std::pair<YACS::ENGINE::OutPort *, YACS::ENGINE::InPort *> >
dataflowLinks;
363 std::string name =
365 std::string compo =
366 std::string type =
422 virtual std::string getName();
424 virtual bool setName(std::string name);
426 virtual std::map<std::string, std::string> getProperties();
427 virtual bool setProperties(std::map<std::string, std::string> properties);
432 virtual void notifyComponentsChange(
GuiEvent event,
int type,
Subject* son);
433 virtual void clean(
434 void localclean(
435 bool isUsed() {
return !_subComponentSet.empty(); }
447 void registerUndoDestroy();
455 void registerUndoDestroy();
457 std::string
getLabelForHuman()
const {
return std::string(
"Salome Homogeneous Pool Container"); }
460 class SubjectServiceNode;
467 virtual std::string getName();
468 virtual void setContainer();
474 virtual bool setProperties(std::map<std::string, std::string> properties);
475 virtual std::map<std::string, std::string> getProperties();
476 virtual void notifyServicesChange(
GuiEvent event,
int type,
Subject* son);
477 virtual std::pair<std::string, int> getKey();
478 virtual void clean(
480 void localclean(
597 bool replace =
false);
600 std::map<int, SubjectNode*> getBodyMap();
601 virtual void completeChildrenSubjectList(
SubjectNode *son);
603 virtual bool setSelect(std::string select);
604 virtual bool setCase(std::string caseId,
SubjectNode* snode);
605 virtual bool hasValue();
606 virtual std::string getValue();
607 virtual void houseKeepingAfterCutPaste(
bool isCut,
SubjectNode *son);
608 virtual void clean(
609 void localclean(
666 virtual bool setAlgorithm(
const std::string& alglib,
const std::string& symbol);
697 virtual bool setScript(std::string script);
741 std::string service);
905 virtual bool setProperties(std::map<std::string, std::string> properties);
Class for CORBA Service Node.
Class for C++ Nodes (in process component)
Base class for dynamically (fully or semifully) built graphs.
Base class for all nodes.
Base class for observer in observer pattern.
Class for Salome component Service Node.
static std::map< int, std::string > _eventNameMap
std::set< Subject * > _subjectSet
virtual void removeNode(SubjectNode *child)
virtual void houseKeepingAfterCutPaste(bool isCut, SubjectNode *son)
virtual TypeOfElem getType()
YACS::ENGINE::Bloc * _bloc
virtual void completeChildrenSubjectList(SubjectNode *son)
virtual SubjectNode * addNode(YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst)
std::set< SubjectNode * > _children
SubjectBloc(YACS::ENGINE::Bloc *bloc, Subject *parent)
virtual void recursiveUpdate(GuiEvent event, int type, Subject *son)
virtual SubjectNode * getChild(YACS::ENGINE::Node *node=0) const
SubjectCORBANode(YACS::ENGINE::CORBANode *corbaNode, Subject *parent)
YACS::ENGINE::CORBANode * _corbaNode
virtual ~SubjectCORBANode()
std::map< SubjectServiceNode *, SubjectReference * > _subReferenceMap
YACS::ENGINE::ComponentInstance * _compoInst
std::set< SubjectServiceNode * > _subServiceSet
SubjectReference * _subRefContainer
SubjectControlLink * addSubjectControlLink(SubjectNode *sno, SubjectNode *sni)
SubjectComposedNode(YACS::ENGINE::ComposedNode *composedNode, Subject *parent)
virtual ~SubjectComposedNode()
virtual void removeControlLink(SubjectControlLink *link)
SubjectNode * addSubjectNode(YACS::ENGINE::Node *node, std::string name="", YACS::ENGINE::Catalog *catalog=0, std::string compo="", std::string type="")
virtual void removeLink(SubjectLink *link)
SubjectLink * addSubjectLink(SubjectNode *sno, SubjectDataPort *spo, SubjectNode *sni, SubjectDataPort *spi)
static SubjectComposedNode * getLowestCommonAncestor(SubjectNode *snode1, SubjectNode *snode2)
Retrieves the lowest common ancestor of 2 nodes.
virtual SubjectNode * createNode(YACS::ENGINE::Catalog *catalog, std::string compo, std::string type, std::string name, bool newCompoInst, int swCase=0)
YACS::ENGINE::ComposedNode * _composedNode
virtual YACS::ENGINE::Container * getContainer() const
std::map< SubjectComponent *, SubjectReference * > _subReferenceMap
virtual std::string getLabelForHuman() const =0
std::set< SubjectComponent * > _subComponentSet
YACS::ENGINE::Container * _container
virtual ~SubjectControlLink()
SubjectNode * _subOutNode
SubjectControlLink(SubjectNode *subOutNode, SubjectNode *subInNode, Subject *parent)
YACS::ENGINE::ComposedNode * _cla
SubjectNode * getSubjectInNode()
SubjectNode * getSubjectOutNode()
YACS::ENGINE::CppNode * _cppNode
virtual ~SubjectCppNode()
SubjectCppNode(YACS::ENGINE::CppNode *cppNode, Subject *parent)
YACS::ENGINE::DataNode * _dataNode
virtual ~SubjectDataNode()
SubjectDataNode(YACS::ENGINE::DataNode *dataNode, Subject *parent)
void addSubjectLink(SubjectLink *subject)
std::list< SubjectLink * > _listSubjectLink
std::list< SubjectLink * > getListOfSubjectLink()
void removeSubjectLink(SubjectLink *subject)
YACS::ENGINE::DataPort * _dataPort
virtual YACS::ENGINE::TypeCode * getTypeCode()
YACS::ENGINE::TypeCode * _typeCode
virtual ~SubjectDataType()
SubjectDataType(YACS::ENGINE::TypeCode *typeCode, Subject *parent, std::string alias)
virtual std::string getAlias()
SubjectNode * _subjectInitNode
virtual void clean(Command *command=NULL)
virtual SubjectNode * getChild(YACS::ENGINE::Node *node=NULL) const
YACS::ENGINE::DynParaLoop * _dynParaLoop
virtual ~SubjectDynParaLoop()
SubjectNode * _subjectExecNode
virtual bool setNbBranches(std::string nbBranches)
void localclean(Command *command=NULL)
SubjectNode * _subjectFinalizeNode
SubjectDynParaLoop(YACS::ENGINE::DynParaLoop *dynParaLoop, Subject *parent)
virtual bool OrderDataPorts(SubjectDataPort *portToMove, int isUp)
SubjectElementaryNode(YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
virtual SubjectDataPort * addInputPort(YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addIDSPort(YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual void removePort(SubjectDataPort *port)
virtual SubjectDataPort * addODSPort(YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
YACS::ENGINE::ElementaryNode * _elementaryNode
virtual ~SubjectElementaryNode()
virtual SubjectDataPort * addOutputPort(YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
SubjectForEachLoop(YACS::ENGINE::ForEachLoopGen *forEachLoop, Subject *parent)
YACS::ENGINE::ForEachLoopGen * _forEachLoop
virtual ~SubjectForEachLoop()
YACS::ENGINE::ForLoop * _forLoop
SubjectForLoop(YACS::ENGINE::ForLoop *forLoop, Subject *parent)
virtual ~SubjectForLoop()
virtual bool setNbSteps(std::string nbSteps)
SubjectInlineNode(YACS::ENGINE::InlineNode *inlineNode, Subject *parent)
YACS::ENGINE::InlineNode * _inlineNode
virtual std::string getScript()
virtual bool setExecutionMode(const std::string &mode)
virtual ~SubjectInlineNode()
virtual bool setContainer(SubjectContainerBase *scont)
SubjectDataPort * getSubjectInPort()
SubjectDataPort * getSubjectOutPort()
SubjectLink(SubjectNode *subOutNode, SubjectDataPort *outPort, SubjectNode *subInNode, SubjectDataPort *inPort, Subject *parent)
SubjectDataPort * _outPort
YACS::ENGINE::OutPort * _outp
virtual std::vector< std::string > knownProperties()
virtual bool setProperties(std::map< std::string, std::string > properties)
YACS::ENGINE::InPort * _inp
virtual std::map< std::string, std::string > getProperties()
SubjectDataPort * _inPort
std::list< YACS::ENGINE::OutGate * > loutgate
void removeSubjectControlLink(SubjectControlLink *sub)
std::list< SubjectControlLink * > getSubjectControlLinks() const
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputPort * > getSubjectInputPorts() const
YACS::ENGINE::Node * _node
SubjectControlLink * addSubjectControlLink(SubjectControlLink *sub)
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::list< SubjectLink * > getSubjectLinks() const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts() const
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts() const
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectControlLink * > _listSubjectControlLink
std::list< SubjectOutputPort * > getSubjectOutputPorts() const
std::list< YACS::ENGINE::InGate * > singate
YACS::ENGINE::OptimizerLoop * _optimizerLoop
SubjectOptimizerLoop(YACS::ENGINE::OptimizerLoop *optimizerLoop, Subject *parent)
virtual ~SubjectOptimizerLoop()
virtual bool setAlgorithm(const std::string &alglib, const std::string &symbol)
virtual ~SubjectOutNode()
SubjectOutNode(YACS::ENGINE::OutNode *outNode, Subject *parent)
YACS::ENGINE::OutNode * _outNode
virtual ~SubjectOutputDataStreamPort()
YACS::ENGINE::OutputDataStreamPort * _outputDataStreamPort
SubjectOutputDataStreamPort(YACS::ENGINE::OutputDataStreamPort *port, Subject *parent)
YACS::ENGINE::OutputPort * _outputPort
virtual ~SubjectOutputPort()
SubjectOutputPort(YACS::ENGINE::OutputPort *port, Subject *parent)
YACS::ENGINE::PresetNode * _presetNode
SubjectPresetNode(YACS::ENGINE::PresetNode *presetNode, Subject *parent)
virtual ~SubjectPresetNode()
std::vector< Subject * > _postEraseList
YACS::ENGINE::Proc * _proc
SubjectProc(YACS::ENGINE::Proc *proc, Subject *parent)
virtual SubjectContainerBase * addHPContainer(std::string name, std::string ref="")
SubjectContainerBase * addSubjectContainer(YACS::ENGINE::Container *cont, std::string name="")
virtual SubjectComponent * addComponent(std::string compoName, std::string containerName="")
virtual bool addDataType(YACS::ENGINE::Catalog *catalog, std::string typeName)
virtual SubjectContainerBase * addContainer(std::string name, std::string ref="")
void addPostErase(Subject *sub)
SubjectDataType * addSubjectDataType(YACS::ENGINE::TypeCode *type, std::string alias)
void loadTypes()
Load types for a SubjectProc.
SubjectDataType * addComSubjectDataType(YACS::ENGINE::TypeCode *type, std::string alias)
void removeSubjectContainer(SubjectContainerBase *scont)
SubjectComponent * addSubjectComponent(YACS::ENGINE::ComponentInstance *compo)
void removeSubjectDataType(std::string typeName)
SubjectPyFuncNode(YACS::ENGINE::PyFuncNode *pyFuncNode, Subject *parent)
virtual bool setFunctionName(std::string funcName)
virtual ~SubjectPyFuncNode()
YACS::ENGINE::PyFuncNode * _pyFuncNode
YACS::ENGINE::PythonNode * _pythonNode
virtual ~SubjectPythonNode()
SubjectPythonNode(YACS::ENGINE::PythonNode *pythonNode, Subject *parent)
SubjectReference(Subject *ref, Subject *parent)
virtual void reparent(Subject *parent)
virtual ~SubjectReference()
virtual Subject * getReference() const
SubjectSalomeNode(YACS::ENGINE::SalomeNode *salomeNode, Subject *parent)
virtual ~SubjectSalomeNode()
YACS::ENGINE::SalomeNode * _salomeNode
YACS::ENGINE::SalomePythonNode * _salomePythonNode
virtual ~SubjectSalomePythonNode()
SubjectSalomePythonNode(YACS::ENGINE::SalomePythonNode *salomePythonNode, Subject *parent)
SubjectReference * _subjectReference
virtual ~SubjectServiceNode()
SubjectReference * _subRefComponent
virtual SubjectReference * getSubjectReference()
virtual void setComponentFromCatalog(YACS::ENGINE::Catalog *catalog, std::string compo, std::string service)
YACS::ENGINE::ServiceNode * _serviceNode
virtual void removeSubRefComponent()
virtual bool associateToComponent(SubjectComponent *subcomp)
virtual void addSubjectReference(Subject *ref)
virtual void setComponent()
SubjectServiceNode(YACS::ENGINE::ServiceNode *serviceNode, Subject *parent)
virtual void removeSubjectReference()
YACS::ENGINE::SplitterNode * _splitterNode
SubjectSplitterNode(YACS::ENGINE::SplitterNode *splitterNode, Subject *parent)
virtual ~SubjectSplitterNode()
virtual ~SubjectStudyInNode()
SubjectStudyInNode(YACS::ENGINE::StudyInNode *studyInNode, Subject *parent)
YACS::ENGINE::StudyInNode * _studyInNode
YACS::ENGINE::StudyOutNode * _studyOutNode
SubjectStudyOutNode(YACS::ENGINE::StudyOutNode *studyOutNode, Subject *parent)
virtual ~SubjectStudyOutNode()
YACS::ENGINE::Switch * _switch
std::map< int, SubjectNode * > _bodyMap
virtual bool setCondition(std::string condition)
SubjectWhileLoop(YACS::ENGINE::WhileLoop *whileLoop, Subject *parent)
virtual ~SubjectWhileLoop()
YACS::ENGINE::WhileLoop * _whileLoop
SubjectXmlNode(YACS::ENGINE::XmlNode *xmlNode, Subject *parent)
virtual ~SubjectXmlNode()
YACS::ENGINE::XmlNode * _xmlNode
void askRegisterUndoDestroy()
std::set< GuiObserver * > _setObs
virtual std::string getProgress()
