YACS::HMI::SubjectControlLink Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectControlLink:
Collaboration diagram for YACS::HMI::SubjectControlLink:
 SubjectControlLink (SubjectNode *subOutNode, SubjectNode *subInNode, Subject *parent)
virtual ~SubjectControlLink ()
SubjectNode * getSubjectOutNode ()
SubjectNode * getSubjectInNode ()
virtual TypeOfElem getType ()
void registerUndoDestroy ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
SubjectNode * _subOutNode
SubjectNode * _subInNode
YACS::ENGINE::ComposedNode * _cla
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
Definition at line 921 of file guiObservers.hxx.
◆ SubjectControlLink()
SubjectControlLink::SubjectControlLink ( SubjectNode *  subOutNode,
SubjectNode *  subInNode,
Subject *  parent
Definition at line 4122 of file guiObservers.cxx.
4125 : Subject(parent),
4126 _subOutNode(subOutNode), _subInNode(subInNode)
4127{
4128 _name = "";
4129 ComposedNode *cla = ComposedNode::getLowestCommonAncestor(_subOutNode->getNode()->getFather(),
4133 DEBTRACE(cla->getName());
4135 _name += "-->>";
4137 DEBTRACE("SubjectControlLink::SubjectControlLink " << _name);
4138}
std::string getName() const
ComposedNode * getFather() const
Definition: Node.hxx:127
virtual std::string getName()
Subject(Subject *parent=0)
References _name, _subInNode, _subOutNode, DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getFather(), YACS::HMI::SubjectNode::getName(), YACS::ENGINE::ComposedNode::getName(), and YACS::HMI::SubjectNode::getNode().
◆ ~SubjectControlLink()
SubjectControlLink::~SubjectControlLink ( )
Definition at line 4140 of file guiObservers.cxx.
4141{
4142 DEBTRACE("SubjectControlLink::~SubjectControlLink " << getName());
4143 if (isDestructible())
4144 {
4145 try
4146 {
4147
4149 }
4150 catch (YACS::Exception &e)
4151 {
4152 DEBTRACE("------------------------------------------------------------------------------");
4153 DEBTRACE("SubjectControlLink::~SubjectControlLink: edRemoveLink YACS exception " << e.what());
4154 DEBTRACE("------------------------------------------------------------------------------");
4155 }
4156 }
4157}
void edRemoveCFLink(Node *nodeS, Node *nodeE)
Remove a controlflow link.
const char * what(void) const noexcept
Definition: Exception.cxx:50
References _cla, _subInNode, _subOutNode, DEBTRACE, YACS::ENGINE::ComposedNode::edRemoveCFLink(), getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::Subject::isDestructible(), and YACS::Exception::what().
◆ clean()
void SubjectControlLink::clean ( Command *  command = 0)
Definition at line 4159 of file guiObservers.cxx.
4160{
4161 if (_askRegisterUndo)
4162 {
4163 _askRegisterUndo = false;
4165 }
4166 localclean(command);
4167 Subject::clean(command);
4168}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::Subject::clean(), localclean(), and registerUndoDestroy().
◆ getName()
std::string SubjectControlLink::getName ( )
Definition at line 4184 of file guiObservers.cxx.
4185{
4186 return _name;
4187}
References _name.
Referenced by YACS::HMI::SubjectComposedNode::addSubjectControlLink(), localclean(), and ~SubjectControlLink().
◆ getSubjectInNode()
SubjectNode * YACS::HMI::SubjectControlLink::getSubjectInNode ( )
◆ getSubjectOutNode()
SubjectNode * YACS::HMI::SubjectControlLink::getSubjectOutNode ( )
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectControlLink::getType ( )
Definition at line 933 of file guiObservers.hxx.
933{return CONTROLLINK;}
References YACS::HMI::CONTROLLINK.
◆ localclean()
void SubjectControlLink::localclean ( Command *  command = 0)
Definition at line 4170 of file guiObservers.cxx.
4171{
4172 DEBTRACE("SubjectControlLink::localClean ");
4173 if (_parent)
4174 {
4175 DEBTRACE("clean control link: " << _parent->getName() << " " << getName());
4176 SubjectComposedNode* father = dynamic_cast<SubjectComposedNode*>(_parent);
4177 YASSERT(father);
4178 father->removeControlLink(this); // --- clean subjects first
4179 _cla = dynamic_cast<ComposedNode*>(father->getNode());
4180 YASSERT(_cla);
4181 }
4182}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual void removeControlLink(SubjectControlLink *link)
References _cla, YACS::HMI::Subject::_parent, DEBTRACE, YACS::HMI::Subject::getName(), getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::SubjectComposedNode::removeControlLink(), and YASSERT.
Referenced by clean().
◆ registerUndoDestroy()
void SubjectControlLink::registerUndoDestroy ( )
Definition at line 4189 of file guiObservers.cxx.
4190{
4191 DEBTRACE("SubjectControlLink::registerUndoDestroy");
4192 Proc *proc = GuiContext::getCurrent()->getProc();
4193 Node *outn = getSubjectOutNode()->getNode();
4194 Node *inn = getSubjectInNode()->getNode();
4195 CommandAddControlLink *command = new CommandAddControlLink(proc->getChildName(outn),
4196 proc->getChildName(inn));
4197 GuiContext::getCurrent()->getInvoc()->add(command);
4198}
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::GuiContext::getProc(), getSubjectInNode(), and getSubjectOutNode().
◆ _cla
YACS::ENGINE::ComposedNode* YACS::HMI::SubjectControlLink::_cla
Definition at line 939 of file guiObservers.hxx.
Referenced by localclean(), and ~SubjectControlLink().
◆ _name
std::string YACS::HMI::SubjectControlLink::_name
Definition at line 938 of file guiObservers.hxx.
Referenced by getName(), and SubjectControlLink().
◆ _subInNode
SubjectNode* YACS::HMI::SubjectControlLink::_subInNode
Definition at line 937 of file guiObservers.hxx.
Referenced by getSubjectInNode(), SubjectControlLink(), and ~SubjectControlLink().
◆ _subOutNode
SubjectNode* YACS::HMI::SubjectControlLink::_subOutNode
Definition at line 936 of file guiObservers.hxx.
Referenced by getSubjectOutNode(), SubjectControlLink(), and ~SubjectControlLink().
