YACS::HMI::Subject Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::Subject:
Collaboration diagram for YACS::HMI::Subject:
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
void registerUndoDestroy ()
bool isDestructible ()
virtual TypeOfElem getType ()
virtual ~Observer ()
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
Friends
class CommandReparentNode
Definition at line 117 of file guiObservers.hxx.
◆ Subject()
Subject::Subject ( Subject *  parent = 0)
Definition at line 85 of file guiObservers.cxx.
85 : _parent(parent)
86{
87 _destructible = true;
88 _askRegisterUndo = false;
89}
References _askRegisterUndo, and _destructible.
◆ ~Subject()
Subject::~Subject ( )
Destructor must only be called by Subject::erase to clean completely the context (detach observers), before the delete process itself. Some actions involving dynamic_cast can't be done in destructor.
Definition at line 97 of file guiObservers.cxx.
98{
99 DEBTRACE("Subject::~Subject " << this << " "<< getName());
100}
virtual std::string getName()
References DEBTRACE, and getName().
◆ addSubjectReference()
void Subject::addSubjectReference ( Subject *  ref)
◆ askRegisterUndoDestroy()
void YACS::HMI::Subject::askRegisterUndoDestroy ( )
Definition at line 141 of file guiObservers.hxx.
141{_askRegisterUndo=true; };
Referenced by YACS::HMI::GuiEditor::DeleteSubject().
◆ attach()
void Subject::attach ( GuiObserver *  obs)
◆ clean()
void Subject::clean ( Command *  command = 0)
Reimplemented in YACS::HMI::SubjectReference, YACS::HMI::SubjectDataPort, YACS::HMI::SubjectInputPort, YACS::HMI::SubjectOutputPort, YACS::HMI::SubjectInputDataStreamPort, YACS::HMI::SubjectOutputDataStreamPort, YACS::HMI::SubjectNode, YACS::HMI::SubjectComposedNode, YACS::HMI::SubjectBloc, YACS::HMI::SubjectContainerBase, YACS::HMI::SubjectComponent, YACS::HMI::SubjectDataType, YACS::HMI::SubjectProc, YACS::HMI::SubjectForLoop, YACS::HMI::SubjectWhileLoop, YACS::HMI::SubjectSwitch, YACS::HMI::SubjectForEachLoop, YACS::HMI::SubjectOptimizerLoop, YACS::HMI::SubjectElementaryNode, YACS::HMI::SubjectInlineNode, YACS::HMI::SubjectPythonNode, YACS::HMI::SubjectPyFuncNode, YACS::HMI::SubjectServiceNode, YACS::HMI::SubjectCORBANode, YACS::HMI::SubjectCppNode, YACS::HMI::SubjectSalomeNode, YACS::HMI::SubjectSalomePythonNode, YACS::HMI::SubjectXmlNode, YACS::HMI::SubjectSplitterNode, YACS::HMI::SubjectDataNode, YACS::HMI::SubjectPresetNode, YACS::HMI::SubjectOutNode, YACS::HMI::SubjectStudyInNode, YACS::HMI::SubjectStudyOutNode, YACS::HMI::SubjectLink, YACS::HMI::SubjectControlLink, and YACS::HMI::SubjectDynParaLoop.
Definition at line 107 of file guiObservers.cxx.
108{
109 localclean(command);
110}
References localclean().
Referenced by YACS::HMI::SubjectReference::clean(), YACS::HMI::SubjectDataPort::clean(), YACS::HMI::SubjectNode::clean(), YACS::HMI::SubjectContainerBase::clean(), YACS::HMI::SubjectComponent::clean(), YACS::HMI::SubjectDataType::clean(), YACS::HMI::SubjectLink::clean(), YACS::HMI::SubjectControlLink::clean(), and erase().
◆ destroy()
bool Subject::destroy ( Subject *  son)
From user action in Ihm, destroy an object.
Called from GuiEditor::DeleteSubject(parent, toRemove). The subject (this) is the parent of the subject (son) to remove. Son must represent a Node, a DataPort, a Link or a ControlLink. All other objects can only be destroyed automatically, not via an user command. Only the destruction originated from user, using this method, are registered for undo-redo.
Definition at line 238 of file guiObservers.cxx.
239{
240 string toDestroy = son->getName();
241 DEBTRACE("Subject::destroy " << toDestroy);
243 string startnode = "";
244 string endnode = "";
245 string startport = "";
246 string endport = "";
247 TypeOfElem startportType = UNKNOWN;
248 TypeOfElem endportType = UNKNOWN;
249
250 if (dynamic_cast<SubjectProc*>(son))
251 startnode = proc->getName();
252 else
253 {
254 if (SubjectNode *subNode = dynamic_cast<SubjectNode*>(son))
255 {
256 if (subNode->getNode()->getFather() )
257 startnode = proc->getChildName(subNode->getNode());
258 }
259 else if (dynamic_cast<SubjectDataPort*>(son))
260 {
261 SubjectNode *subNodep = dynamic_cast<SubjectNode*>(son->getParent());
262 startnode = proc->getChildName(subNodep->getNode());
263 startport = son->getName();
264 startportType = son->getType();
265 }
266 else if (SubjectLink* slink = dynamic_cast<SubjectLink*>(son))
267 {
268 startnode = proc->getChildName(slink->getSubjectOutNode()->getNode());
269 endnode = proc->getChildName(slink->getSubjectInNode()->getNode());
270 startport = slink->getSubjectOutPort()->getName();
271 endport = slink->getSubjectInPort()->getName();
272 startportType = slink->getSubjectOutPort()->getType();
273 endportType = slink->getSubjectInPort()->getType();
274 }
275 else if (SubjectControlLink* sclink = dynamic_cast<SubjectControlLink*>(son))
276 {
277 startnode = proc->getChildName(sclink->getSubjectOutNode()->getNode());
278 endnode = proc->getChildName(sclink->getSubjectInNode()->getNode());
279 }
280 else if (SubjectContainerBase* scont = dynamic_cast<SubjectContainerBase*>(son))
281 {
282 if(scont->getName() == "DefaultContainer")
283 {
284 GuiContext::getCurrent()->_lastErrorMessage = "You can't delete the default container";
285 return false;
286 }
287 if(scont->isUsed())
288 {
289 GuiContext::getCurrent()->_lastErrorMessage = "You can't delete a container that contains components";
290 return false;
291 }
292 startnode = scont->getName();
293 }
294 else
295 {
296 GuiContext::getCurrent()->_lastErrorMessage = "No command Destroy for that type";
297 return false;
298 }
299 }
300 if (son->isDestructible())
301 {
302 CommandDestroy* command = new CommandDestroy(son->getType(), startnode, startport, startportType, endnode, endport, endportType);
303 if (command->execute())
304 {
305 DEBTRACE("Destruction done: " << toDestroy);
306 GuiContext::getCurrent()->getInvoc()->add(command);
307 return true;
308 }
309 else delete command;
310 }
311 return false;
312}
std::string getName() const
Definition: Proc.hxx:44
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
std::string _lastErrorMessage
Definition: guiContext.hxx:79
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
virtual Subject * getParent()
virtual TypeOfElem getType()
References YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), getName(), YACS::ENGINE::ComposedNode::getName(), YACS::HMI::SubjectNode::getNode(), getParent(), YACS::HMI::GuiContext::getProc(), getType(), isDestructible(), and YACS::HMI::UNKNOWN.
Referenced by YACS::HMI::GuiEditor::DeleteSubject(), and YACS::HMI::SubjectContainerBase::~SubjectContainerBase().
◆ detach()
void Subject::detach ( GuiObserver *  obs)
Definition at line 153 of file guiObservers.cxx.
154{
155 DEBTRACE("Subject::detach " << obs);
156 obs->decrementSubjects(this);
157 _setObs.erase(obs);
158}
virtual void decrementSubjects(Subject *subject)
References _setObs, DEBTRACE, and YACS::HMI::GuiObserver::decrementSubjects().
Referenced by localclean().
◆ erase()
void Subject::erase ( Subject *  sub,
Command *  command = 0,
bool  post = false
Definition at line 74 of file guiObservers.cxx.
75{
76 Subject* parent =sub->getParent();
77 sub->clean(command);
78 delete sub;
79 if (!post) // --- avoid recursion in erase, see cleanPostErase
81}
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
References clean(), YACS::HMI::SubjectProc::cleanPostErase(), YACS::HMI::GuiContext::getCurrent(), getParent(), and YACS::HMI::GuiContext::getSubjectProc().
Referenced by YACS::HMI::SubjectProc::cleanPostErase(), YACS::HMI::SubjectContainerBase::detachComponent(), YACS::HMI::SubjectComponent::detachService(), YACS::HMI::SubjectDataPort::localclean(), YACS::HMI::SubjectNode::localclean(), YACS::HMI::SubjectBloc::localclean(), YACS::HMI::SubjectContainerBase::localclean(), YACS::HMI::SubjectComponent::localclean(), YACS::HMI::SubjectForLoop::localclean(), YACS::HMI::SubjectWhileLoop::localclean(), YACS::HMI::SubjectSwitch::localclean(), YACS::HMI::SubjectForEachLoop::localclean(), YACS::HMI::SubjectServiceNode::localclean(), YACS::HMI::SubjectDynParaLoop::localclean(), YACS::HMI::CommandDestroy::localExecute(), YACS::HMI::CommandAddNodeFromCatalog::localReverse(), YACS::HMI::CommandPutInComposedNode::localReverse(), YACS::HMI::CommandCopyNode::localReverse(), YACS::HMI::CommandAddInputPortFromCatalog::localReverse(), YACS::HMI::CommandAddOutputPortFromCatalog::localReverse(), YACS::HMI::CommandAddIDSPortFromCatalog::localReverse(), YACS::HMI::CommandAddODSPortFromCatalog::localReverse(), YACS::HMI::CommandAddLink::localReverse(), YACS::HMI::CommandAddControlLink::localReverse(), YACS::HMI::SubjectComponent::moveService(), YACS::HMI::SubjectNode::removeExternalControlLinks(), YACS::HMI::SubjectComposedNode::removeExternalControlLinks(), YACS::HMI::SubjectNode::removeExternalLinks(), YACS::HMI::SubjectProc::removeSubjectContainer(), YACS::HMI::SubjectProc::removeSubjectDataType(), and YACS::HMI::GuiContext::setProc().
◆ getName()
std::string Subject::getName ( )
Reimplemented in YACS::HMI::SubjectReference, YACS::HMI::SubjectDataPort, YACS::HMI::SubjectNode, YACS::HMI::SubjectContainerBase, YACS::HMI::SubjectComponent, YACS::HMI::SubjectDataType, YACS::HMI::SubjectSplitterNode, YACS::HMI::SubjectLink, and YACS::HMI::SubjectControlLink.
Definition at line 160 of file guiObservers.cxx.
161{
162 return "generic";
163}
Referenced by YACS::HMI::SchemaContainerItem::addComponentInstance(), YACS::HMI::SchemaDirContainersItem::addContainerItem(), YACS::HMI::SchemaDirLinksItem::addLinkItem(), addSubjectReference(), YACS::HMI::GuiEditor::arrangeNodes(), YACS::HMI::GuiEditor::CopySubject(), YACS::HMI::GenericGui::createContext(), YACS::HMI::ValueDelegate::createEditor(), YACS::HMI::GuiEditor::CreateNode(), YACS::HMI::GuiEditor::CutSubject(), YACS::HMI::GuiEditor::DeleteSubject(), destroy(), YACS::HMI::GenericGui::displayPortLinks(), YACS::HMI::SchemaModel::dropMimeData(), YACS::HMI::SceneNodeItem::getHeaderLabel(), YACS::HMI::SubjectReference::getName(), YACS::HMI::ItemEditionBase::ItemEditionBase(), YACS::HMI::SubjectLink::localclean(), YACS::HMI::SubjectControlLink::localclean(), YACS::HMI::CommandAddNodeFromCatalog::localReverse(), YACS::HMI::TablePortsEdition::on_pb_insert_clicked(), YACS::HMI::TablePortsEdition::on_pb_remove_clicked(), YACS::HMI::TablePortsEdition::oncb_insert_activated(), YACS::HMI::GenericGui::onEmphasisCtrlLinks(), YACS::HMI::GenericGui::onEmphasisPortLinks(), YACS::HMI::SchemaContainerItem::SchemaContainerItem(), YACS::HMI::RootSceneItem::setNewRoot(), YACS::HMI::SchemaModel::setNewRoot(), YACS::HMI::ValueDelegate::setResultEditing(), YACS::HMI::EditionContainer::update(), YACS::HMI::EditionSalomeNode::update(), YACS::HMI::ItemEdition::update(), YACS::HMI::SceneComposedNodeItem::update(), YACS::HMI::SceneDataPortItem::update(), YACS::HMI::SceneElementaryNodeItem::update(), YACS::HMI::SceneNodeItem::update(), YACS::HMI::SchemaComposedNodeItem::update(), YACS::HMI::SchemaContainerItem::update(), YACS::HMI::SchemaItem::update(), YACS::HMI::SchemaNodeItem::update(), YACS::HMI::SchemaReferenceItem::update(), YACS::HMI::SchemaModel::updateSelection(), YACS::HMI::TablePortsEdition::upOrDown(), and ~Subject().
◆ getParent()
Subject * Subject::getParent ( )
◆ getProgress()
virtual std::string YACS::HMI::Subject::getProgress ( )
Definition at line 146 of file guiObservers.hxx.
146{ return _progress; };
Referenced by YACS::HMI::SceneComposedNodeItem::update().
◆ getProperties()
std::map< std::string, std::string > Subject::getProperties ( )
◆ getType()
◆ isDestructible()
bool YACS::HMI::Subject::isDestructible ( )
◆ knownProperties()
std::vector< std::string > Subject::knownProperties ( )
Reimplemented in YACS::HMI::SubjectInputDataStreamPort, and YACS::HMI::SubjectLink.
Definition at line 181 of file guiObservers.cxx.
182{
183 std::vector<std::string> empty;
184 return empty;
185}
Referenced by YACS::HMI::SubjectLink::knownProperties(), and YACS::HMI::PropertyEditor::PropertyEditor().
◆ loadChildren()
◆ loadLinks()
void Subject::loadLinks ( )
◆ localclean()
void Subject::localclean ( Command *  command = 0)
the local clean method of base class of subjects take care of Observers. Remaining Observers in the list are detached, if an observer has no more Subject to observe, it can be deleted.
Definition at line 117 of file guiObservers.cxx.
118{
119 DEBTRACE("Subject::localClean ");
120 set<GuiObserver*>::iterator it;
121 while (int nbObs = _setObs.size())
122 {
123 DEBTRACE("--- " << this << " nbObs " << nbObs);
124 set<GuiObserver*> copySet = _setObs;
125 for (it = copySet.begin(); it != copySet.end(); ++it)
126 {
127 GuiObserver* anObs = (*it);
128 detach(anObs);
129 int nbsub = anObs->getNbSubjects();
130 DEBTRACE("nbSubjects=" << nbsub << " obs=" << anObs);
131 if (nbsub <= 0 && anObs->isDestructible())
132 {
133 delete anObs ;
134 break; // --- each delete may induce remove of other observers
135 }
136 }
137 }
138 _setObs.clear();
139}
virtual void detach(GuiObserver *obs)
References _setObs, DEBTRACE, detach(), YACS::HMI::GuiObserver::getNbSubjects(), and isDestructible().
Referenced by clean().
◆ registerUndoDestroy()
void Subject::registerUndoDestroy ( )
◆ select()
void Subject::select ( bool  isSelected)
◆ setName()
bool Subject::setName ( std::string  name)
Reimplemented in YACS::HMI::SubjectDataPort, YACS::HMI::SubjectNode, and YACS::HMI::SubjectContainerBase.
Definition at line 165 of file guiObservers.cxx.
166{
167 return false;
168}
Referenced by YACS::HMI::ItemEdition::onApply().
◆ setParent()
void Subject::setParent ( Subject *  son)
◆ setProgress()
void Subject::setProgress ( std::string  newProgress)
Definition at line 329 of file guiObservers.cxx.
330{
331 _progress = newProgress;
332}
References _progress.
Referenced by YACS::HMI::GuiExecutor::event().
◆ setProperties()
bool Subject::setProperties ( std::map< std::string, std::string >  properties)
◆ update()
void Subject::update ( GuiEvent  event,
int  type,
Subject *  son
Reimplemented in YACS::HMI::SubjectNode.
Definition at line 198 of file guiObservers.cxx.
199{
200 //DEBTRACE("Subject::update " << type << "," << GuiObserver::eventName(event) << "," << son);
201 set<GuiObserver*> copySet = _setObs;
202 for (set<GuiObserver *>::iterator it = copySet.begin(); it != copySet.end(); ++it)
203 {
204 //DEBTRACE("Subject::update " << *it);
205 try
206 {
207 (*it)->update(event, type, son);
208 }
209 catch(Exception& ex)
210 {
211 std::cerr << "Internal error in Subject::update: " << ex.what() << std::endl;
212 }
213 catch(...)
214 {
215 std::cerr << "Internal error in Subject::update: " << std::endl;
216 }
217 }
218}
References _setObs, and testCppPluginInvokation::ex.
Referenced by YACS::HMI::SubjectComposedNode::addSubjectLink(), addSubjectReference(), YACS::HMI::SubjectContainerBase::attachComponent(), YACS::HMI::SubjectComponent::attachService(), gui.graph.MyCanvas::customEvent(), YACS::HMI::SubjectContainerBase::detachComponent(), YACS::HMI::SubjectComponent::detachService(), YACS::HMI::GenericGui::emphasizePortLink(), YACS::HMI::GuiExecutor::event(), YACS::HMI::SubjectComponent::localclean(), YACS::HMI::CommandRenameInDataPort::localExecute(), YACS::HMI::CommandRenameOutDataPort::localExecute(), YACS::HMI::CommandSetInPortValue::localExecute(), YACS::HMI::CommandSetOutPortValue::localExecute(), YACS::HMI::CommandSetForEachBranch::localExecute(), YACS::HMI::CommandSetAlgo::localExecute(), YACS::HMI::CommandSetContainerProperties::localExecute(), YACS::HMI::CommandSetComponentInstanceProperties::localExecute(), YACS::HMI::CommandSetLinkProperties::localExecute(), YACS::HMI::CommandDestroy::localExecute(), YACS::HMI::CommandAddNodeFromCatalog::localReverse(), YACS::HMI::CommandCopyNode::localReverse(), YACS::HMI::CommandRenameInDataPort::localReverse(), YACS::HMI::CommandRenameOutDataPort::localReverse(), YACS::HMI::CommandAddInputPortFromCatalog::localReverse(), YACS::HMI::CommandAddOutputPortFromCatalog::localReverse(), YACS::HMI::CommandAddIDSPortFromCatalog::localReverse(), YACS::HMI::CommandAddODSPortFromCatalog::localReverse(), YACS::HMI::CommandSetInPortValue::localReverse(), YACS::HMI::CommandSetOutPortValue::localReverse(), YACS::HMI::CommandSetForEachBranch::localReverse(), YACS::HMI::CommandSetAlgo::localReverse(), YACS::HMI::CommandAddLink::localReverse(), YACS::HMI::CommandAddControlLink::localReverse(), YACS::HMI::CommandSetComponentInstanceProperties::localReverse(), YACS::HMI::CommandSetLinkProperties::localReverse(), YACS::HMI::SubjectContainerBase::moveComponent(), YACS::HMI::SubjectComponent::moveService(), YACS::HMI::GenericGui::onDeEmphasizeAll(), YACS::HMI::GenericGui::onEmphasisCtrlLinks(), YACS::HMI::GenericGui::onEmphasisLink(), YACS::HMI::GenericGui::onToggleStraightLinks(), YACS::HMI::ItemEdition::setEdited(), YACS::HMI::GuiContext::setProc(), YACS::HMI::ValueDelegate::setResultEditing(), YACS::HMI::EditionForEachLoop::synchronize(), YACS::HMI::EditionLoop::synchronize(), YACS::HMI::EditionOptimizerLoop::synchronize(), YACS::HMI::EditionSwitch::synchronize(), YACS::HMI::EditionWhile::synchronize(), YACS::HMI::SubjectObserver::update(), YACS::HMI::SubjectNode::update(), YACS::HMI::GuiExecutor::updateSchema(), and YACS::HMI::SubjectLink::~SubjectLink().
◆ CommandReparentNode
friend class CommandReparentNode
friend
Definition at line 120 of file guiObservers.hxx.
Referenced by YACS::HMI::SubjectNode::reparent().
◆ _askRegisterUndo
bool YACS::HMI::Subject::_askRegisterUndo
Definition at line 151 of file guiObservers.hxx.
Referenced by YACS::HMI::SubjectReference::clean(), YACS::HMI::SubjectDataPort::clean(), YACS::HMI::SubjectInputPort::clean(), YACS::HMI::SubjectOutputPort::clean(), YACS::HMI::SubjectInputDataStreamPort::clean(), YACS::HMI::SubjectOutputDataStreamPort::clean(), YACS::HMI::SubjectNode::clean(), YACS::HMI::SubjectComposedNode::clean(), YACS::HMI::SubjectBloc::clean(), YACS::HMI::SubjectContainerBase::clean(), YACS::HMI::SubjectComponent::clean(), YACS::HMI::SubjectDataType::clean(), YACS::HMI::SubjectProc::clean(), YACS::HMI::SubjectForLoop::clean(), YACS::HMI::SubjectWhileLoop::clean(), YACS::HMI::SubjectSwitch::clean(), YACS::HMI::SubjectForEachLoop::clean(), YACS::HMI::SubjectOptimizerLoop::clean(), YACS::HMI::SubjectElementaryNode::clean(), YACS::HMI::SubjectInlineNode::clean(), YACS::HMI::SubjectPythonNode::clean(), YACS::HMI::SubjectPyFuncNode::clean(), YACS::HMI::SubjectServiceNode::clean(), YACS::HMI::SubjectCORBANode::clean(), YACS::HMI::SubjectCppNode::clean(), YACS::HMI::SubjectSalomeNode::clean(), YACS::HMI::SubjectSalomePythonNode::clean(), YACS::HMI::SubjectXmlNode::clean(), YACS::HMI::SubjectSplitterNode::clean(), YACS::HMI::SubjectDataNode::clean(), YACS::HMI::SubjectPresetNode::clean(), YACS::HMI::SubjectOutNode::clean(), YACS::HMI::SubjectStudyInNode::clean(), YACS::HMI::SubjectStudyOutNode::clean(), YACS::HMI::SubjectLink::clean(), YACS::HMI::SubjectControlLink::clean(), YACS::HMI::SubjectDynParaLoop::clean(), and Subject().
◆ _destructible
◆ _parent
◆ _progress
std::string YACS::HMI::Subject::_progress
Definition at line 152 of file guiObservers.hxx.
Referenced by setProgress().
◆ _setObs
std::set<GuiObserver *> YACS::HMI::Subject::_setObs
Definition at line 148 of file guiObservers.hxx.
Referenced by attach(), detach(), localclean(), select(), and update().
