62 m.popupMenu(caller, globalPos);
68return "<p>Links between ports or nodes under that block level appears in this folder.\n" \
69 "You can add data links (between ports) and control links (between nodes) " \
70 "by drag from origin (out node or out port) to destination (in node or in port) " \
71 "either in 2D graphic view or tree view. <a href=\"modification.html#create-a-link\">More...</a></p>";
QList< QVariant > _itemDeco
virtual QVariant editionWhatsThis(int column) const
virtual void popupMenu(QWidget *caller, const QPoint &globalPos)
virtual TypeOfElem getType()
