YACS::HMI::SubjectLink Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectLink:
Collaboration diagram for YACS::HMI::SubjectLink:
 SubjectLink (SubjectNode *subOutNode, SubjectDataPort *outPort, SubjectNode *subInNode, SubjectDataPort *inPort, Subject *parent)
virtual ~SubjectLink ()
SubjectNode * getSubjectOutNode ()
SubjectNode * getSubjectInNode ()
SubjectDataPort * getSubjectOutPort ()
SubjectDataPort * getSubjectInPort ()
virtual TypeOfElem getType ()
void registerUndoDestroy ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
SubjectNode * _subOutNode
SubjectDataPort * _outPort
SubjectNode * _subInNode
SubjectDataPort * _inPort
YACS::ENGINE::ComposedNode * _cla
YACS::ENGINE::OutPort * _outp
YACS::ENGINE::InPort * _inp
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
Definition at line 889 of file guiObservers.hxx.
◆ SubjectLink()
SubjectLink::SubjectLink ( SubjectNode *  subOutNode,
SubjectDataPort *  outPort,
SubjectNode *  subInNode,
SubjectDataPort *  inPort,
Subject *  parent
Definition at line 4000 of file guiObservers.cxx.
4005 : Subject(parent),
4006 _subOutNode(subOutNode), _outPort(outPort), _subInNode(subInNode), _inPort(inPort)
4007{
4008 _name = "";
4009 ComposedNode *cla = ComposedNode::getLowestCommonAncestor(_subOutNode->getNode()->getFather(),
4011 DEBTRACE(_subOutNode->getName() << "." << _outPort->getName());
4012 DEBTRACE(_subInNode->getName() << "." << _inPort->getName());
4013 DEBTRACE(cla->getName());
4015 _name += "." + _outPort->getName();
4016 _name += "->";
4018 _name += "." + _inPort->getName();
4019 DEBTRACE("SubjectLink::SubjectLink " << _name);
4020}
std::string getName() const
ComposedNode * getFather() const
Definition: Node.hxx:127
virtual std::string getName()
Subject(Subject *parent=0)
References _inPort, _name, _outPort, _subInNode, _subOutNode, DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Node::getFather(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::SubjectNode::getName(), YACS::ENGINE::ComposedNode::getName(), and YACS::HMI::SubjectNode::getNode().
◆ ~SubjectLink()
SubjectLink::~SubjectLink ( )
Definition at line 4022 of file guiObservers.cxx.
4023{
4024 DEBTRACE("SubjectLink::~SubjectLink " << getName());
4027}
References _inPort, _outPort, YACS::HMI::DATALINK, DEBTRACE, getName(), YACS::HMI::UPDATE, and YACS::HMI::Subject::update().
◆ clean()
void SubjectLink::clean ( Command *  command = 0)
Definition at line 4029 of file guiObservers.cxx.
4030{
4031 if (_askRegisterUndo)
4032 {
4033 _askRegisterUndo = false;
4035 }
4036 localclean(command);
4037 Subject::clean(command);
4038}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::Subject::clean(), localclean(), and registerUndoDestroy().
◆ getName()
◆ getProperties()
std::map< std::string, std::string > SubjectLink::getProperties ( )
Definition at line 4065 of file guiObservers.cxx.
4066{
4067 return getSubjectInPort()->getProperties();
4068}
virtual std::map< std::string, std::string > getProperties()
References YACS::HMI::Subject::getProperties(), and getSubjectInPort().
Referenced by registerUndoDestroy().
◆ getSubjectInNode()
SubjectNode * YACS::HMI::SubjectLink::getSubjectInNode ( )
Definition at line 902 of file guiObservers.hxx.
902{ return _subInNode; };
References _subInNode.
◆ getSubjectInPort()
◆ getSubjectOutNode()
SubjectNode * YACS::HMI::SubjectLink::getSubjectOutNode ( )
Definition at line 901 of file guiObservers.hxx.
901{ return _subOutNode; };
References _subOutNode.
◆ getSubjectOutPort()
SubjectDataPort * YACS::HMI::SubjectLink::getSubjectOutPort ( )
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectLink::getType ( )
Definition at line 908 of file guiObservers.hxx.
908{return DATALINK;}
References YACS::HMI::DATALINK.
◆ knownProperties()
std::vector< std::string > SubjectLink::knownProperties ( )
Definition at line 4070 of file guiObservers.cxx.
4071{
4073}
virtual std::vector< std::string > knownProperties()
References getSubjectInPort(), and YACS::HMI::Subject::knownProperties().
◆ localclean()
void SubjectLink::localclean ( Command *  command = 0)
Definition at line 4040 of file guiObservers.cxx.
4041{
4042 DEBTRACE("SubjectLink::localClean ");
4043 if (_parent)
4044 {
4045 DEBTRACE("clean link: " << _parent->getName() << " " << getName());
4046 SubjectComposedNode* father = dynamic_cast<SubjectComposedNode*>(_parent);
4047 YASSERT(father);
4048 father->removeLink(this); // --- clean subjects first
4049 _cla = dynamic_cast<ComposedNode*>(father->getNode());
4050 YASSERT(_cla);
4051 _outp = dynamic_cast<OutPort*>(_outPort->getPort());
4052 YASSERT(_outp);
4053 _inp = dynamic_cast<InPort*>(_inPort->getPort());
4054 YASSERT(_inp);
4055 if (isDestructible())
4057 }
4058}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
void edRemoveLink(OutPort *start, InPort *end)
Remove a dataflow link.
virtual void removeLink(SubjectLink *link)
virtual YACS::ENGINE::DataPort * getPort()
References _cla, _inp, _inPort, _outp, _outPort, YACS::HMI::Subject::_parent, DEBTRACE, YACS::ENGINE::ComposedNode::edRemoveLink(), YACS::HMI::Subject::getName(), getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::Subject::isDestructible(), YACS::HMI::SubjectComposedNode::removeLink(), and YASSERT.
Referenced by clean().
◆ registerUndoDestroy()
void SubjectLink::registerUndoDestroy ( )
Definition at line 4091 of file guiObservers.cxx.
4092{
4093 DEBTRACE("SubjectLink::registerUndoDestroy");
4094 Proc *proc = GuiContext::getCurrent()->getProc();
4095 Node *outn = getSubjectOutNode()->getNode();
4096 Node *inn = getSubjectInNode()->getNode();
4097 DataPort *outp = getSubjectOutPort()->getPort();
4098 DataPort *inp = getSubjectInPort()->getPort();
4099 CommandAddLink *command = new CommandAddLink(proc->getChildName(outn),
4100 outp->getName(),
4102 proc->getChildName(inn),
4103 inp->getName(),
4105 false);
4106 GuiContext::getCurrent()->getInvoc()->add(command);
4107
4108 map<string, string> properties = getProperties();
4109 if (properties.empty())
4110 return;
4111
4113 outp->getName(),
4114 proc->getChildName(inn),
4115 inp->getName(),
4116 properties);
4117 GuiContext::getCurrent()->getInvoc()->add(command2);
4118}
Definition: DataPort.hxx:55
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::ENGINE::DataPort::getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::SubjectDataPort::getPort(), YACS::HMI::GuiContext::getProc(), getProperties(), getSubjectInNode(), getSubjectInPort(), getSubjectOutNode(), getSubjectOutPort(), and getType().
Referenced by clean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
◆ setProperties()
bool SubjectLink::setProperties ( std::map< std::string, std::string >  properties)
Definition at line 4075 of file guiObservers.cxx.
4076{
4077 Proc *proc = GuiContext::getCurrent()->getProc();
4078 CommandSetLinkProperties *command =
4079 new CommandSetLinkProperties(proc->getChildName(getSubjectOutPort()->getPort()->getNode()), getSubjectOutPort()->getName(),
4080 proc->getChildName(getSubjectInPort()->getPort()->getNode()), getSubjectInPort()->getName(),
4081 properties);
4082 if (command->execute())
4083 {
4084 GuiContext::getCurrent()->getInvoc()->add(command);
4085 return true;
4086 }
4087 else delete command;
4088 return false;
4089}
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
References YACS::HMI::Invocator::add(), YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), getName(), YACS::HMI::GuiContext::getProc(), getSubjectInPort(), and getSubjectOutPort().
◆ _cla
YACS::ENGINE::ComposedNode* YACS::HMI::SubjectLink::_cla
Definition at line 916 of file guiObservers.hxx.
Referenced by localclean().
◆ _inp
YACS::ENGINE::InPort* YACS::HMI::SubjectLink::_inp
Definition at line 918 of file guiObservers.hxx.
◆ _inPort
SubjectDataPort* YACS::HMI::SubjectLink::_inPort
Definition at line 914 of file guiObservers.hxx.
Referenced by getSubjectInPort(), localclean(), SubjectLink(), and ~SubjectLink().
◆ _name
std::string YACS::HMI::SubjectLink::_name
Definition at line 915 of file guiObservers.hxx.
Referenced by getName(), and SubjectLink().
◆ _outp
YACS::ENGINE::OutPort* YACS::HMI::SubjectLink::_outp
Definition at line 917 of file guiObservers.hxx.
◆ _outPort
SubjectDataPort* YACS::HMI::SubjectLink::_outPort
Definition at line 912 of file guiObservers.hxx.
Referenced by getSubjectOutPort(), localclean(), SubjectLink(), and ~SubjectLink().
◆ _subInNode
SubjectNode* YACS::HMI::SubjectLink::_subInNode
Definition at line 913 of file guiObservers.hxx.
Referenced by getSubjectInNode(), and SubjectLink().
◆ _subOutNode
SubjectNode* YACS::HMI::SubjectLink::_subOutNode
Definition at line 911 of file guiObservers.hxx.
Referenced by getSubjectOutNode(), and SubjectLink().
