YACS::HMI::CommandAddLink Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandAddLink:
Collaboration diagram for YACS::HMI::CommandAddLink:
 CommandAddLink (std::string outNode, std::string outPort, TypeOfElem outPortType, std::string inNode, std::string inPort, TypeOfElem inPortType, bool control=true)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
std::string _outNode
std::string _outPort
TypeOfElem _outPortType
std::string _inNode
std::string _inPort
TypeOfElem _inPortType
bool _control
bool _controlCreatedWithDF
bool _normalReverse
Definition at line 499 of file commandsProc.hxx.
◆ CommandAddLink()
CommandAddLink::CommandAddLink ( std::string  outNode,
std::string  inNode,
std::string  inPort,
bool  control = true
Definition at line 2857 of file commandsProc.cxx.
2859 : Command(), _outNode(outNode), _outPort(outPort), _outPortType(outPortType),
2860 _inNode(inNode), _inPort(inPort), _inPortType(inPortType), _control(control)
2861{
2862 DEBTRACE("CommandAddLink::CommandAddLink "<<outNode<<"."<<outPort<<"->"<<inNode<<"."<<inPort<<" "<<control);
2863 _controlCreatedWithDF = false;
2864}
References _controlCreatedWithDF, and DEBTRACE.
◆ dump()
std::string CommandAddLink::dump ( )
Definition at line 2866 of file commandsProc.cxx.
2867{
2868 string s = "false";
2869 if (_control) s = "true";
2870 string ret ="CommandAddLink " + _outNode + " " + _outPort + " " + _inNode + " " + _inPort + " " + s;
2871 return ret;
2872}
References _control, _inNode, _inPort, _outNode, and _outPort.
◆ localExecute()
bool CommandAddLink::localExecute ( )
Definition at line 2874 of file commandsProc.cxx.
2875{
2876 DEBTRACE("CommandAddLink::localExecute");
2877 DEBTRACE(_outNode<<"."<<_outPort<<"->"<<_inNode<<"."<<_inPort<<" "<<_control);
2878 try
2879 {
2880 Proc* proc = GuiContext::getCurrent()->getProc();
2881 Node* outn = proc->getChildByName(_outNode);
2882 Node* inn = proc->getChildByName(_inNode);
2883 OutPort* outp;
2884 InPort* inp;
2885
2886 // --- is a control link already existing ?
2887 bool preexistingControl = false;
2888 {
2889 Node* outn2=outn;
2890 Node* inn2=inn;
2891 ComposedNode* father = ComposedNode::getLowestCommonAncestor(outn2,inn2);
2892 if(outn2==father || inn2==father)
2893 preexistingControl = true;
2894 else
2895 {
2896 while(outn2->getFather() != father)
2897 outn2 = outn2->getFather();
2898 while(inn2->getFather() != father)
2899 inn2 = inn2->getFather();
2900 OutGate *ogate = outn2->getOutGate();
2901 InGate *igate = inn2->getInGate();
2902 if (ogate->isAlreadyInSet(igate))
2903 preexistingControl = true;
2904 }
2905 }
2906
2908 outp = outn->getOutputPort(_outPort);
2909 else
2910 outp = outn->getOutputDataStreamPort(_outPort);
2911
2912 if(_inPortType == INPUTPORT)
2913 inp = inn->getInputPort(_inPort);
2914 else
2915 inp = inn->getInputDataStreamPort(_inPort);
2916
2917 ComposedNode *cla = ComposedNode::getLowestCommonAncestor(outn->getFather(),inn->getFather());
2918 DEBTRACE(cla->getName());
2919 if (dynamic_cast<OutputDataStreamPort*>(outp))
2920 cla->edAddLink(outp,inp);
2921 else if(_control)
2922 cla->edAddDFLink(outp,inp);
2923 else
2924 cla->edAddLink(outp,inp);
2925
2926 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(cla));
2928 SubjectComposedNode *scla = dynamic_cast<SubjectComposedNode*>(sub);
2929 DEBTRACE(scla->getName());
2934 SubjectLink *slink = scla->addSubjectLink(sno, subOutport, sni, subInport);
2935
2936 // --- if control link, identify the nodes linked and draw the control link if not already existing
2937
2938 if (_control)
2939 {
2940 ComposedNode* father = ComposedNode::getLowestCommonAncestor(outn,inn);
2941 if(outn==father || inn==father) return true;
2942 while(outn->getFather() != father)
2943 outn = outn->getFather();
2944 while(inn->getFather() != father)
2945 inn = inn->getFather();
2946 OutGate *ogate = outn->getOutGate();
2947 InGate *igate = inn->getInGate();
2948 if (ogate->isAlreadyInSet(igate))
2949 {
2950 if (!preexistingControl)
2951 _controlCreatedWithDF = true;
2952 pair<Node*,Node*> keyLink(outn,inn);
2953 if (!GuiContext::getCurrent()->_mapOfSubjectControlLink.count(keyLink))
2954 {
2957 if (!sfno || !sfni) return true;
2958 SubjectControlLink *sclink = scla->addSubjectControlLink(sfno, sfni);
2959 }
2960 }
2961 }
2962 return true;
2963 }
2964 catch (Exception& ex)
2965 {
2966 DEBTRACE("CommandAddLink::localExecute() : " << ex.what());
2967 setErrorMsg(ex);
2968 return false;
2969 }
2970}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::string getName() const
virtual bool edAddDFLink(OutPort *start, InPort *end)
Connect an OutPort to an InPort and add the necessary control link.
bool edAddLink(OutPort *start, InPort *end)
Add a dataflow link between two data ports.
Base class for all nodes.
Definition: Node.hxx:70
ComposedNode * getFather() const
Definition: Node.hxx:127
OutGate * getOutGate()
Definition: Node.hxx:124
virtual OutputPort * getOutputPort(const std::string &name) const =0
InGate * getInGate()
Definition: Node.hxx:123
virtual OutputDataStreamPort * getOutputDataStreamPort(const std::string &name) const =0
virtual InputPort * getInputPort(const std::string &name) const
Definition: Node.cxx:260
virtual InputDataStreamPort * getInputDataStreamPort(const std::string &name) const =0
bool isAlreadyInSet(InGate *inGate) const
Definition: OutGate.cxx:150
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:71
Definition: guiContext.hxx:70
Definition: guiContext.hxx:50
SubjectControlLink * addSubjectControlLink(SubjectNode *sno, SubjectNode *sni)
SubjectLink * addSubjectLink(SubjectNode *sno, SubjectDataPort *spo, SubjectNode *sni, SubjectDataPort *spi)
virtual std::string getName()
References _control, _controlCreatedWithDF, _inNode, _inPort, _inPortType, YACS::HMI::GuiContext::_mapOfSubjectDataPort, YACS::HMI::GuiContext::_mapOfSubjectNode, _outNode, _outPort, _outPortType, YACS::HMI::SubjectComposedNode::addSubjectControlLink(), YACS::HMI::SubjectComposedNode::addSubjectLink(), DEBTRACE, YACS::ENGINE::ComposedNode::edAddDFLink(), YACS::ENGINE::ComposedNode::edAddLink(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getFather(), YACS::ENGINE::Node::getInGate(), YACS::ENGINE::Node::getInputDataStreamPort(), YACS::ENGINE::Node::getInputPort(), YACS::HMI::SubjectNode::getName(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getOutGate(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::ENGINE::Node::getOutputPort(), YACS::HMI::GuiContext::getProc(), YACS::HMI::INPUTPORT, YACS::ENGINE::OutGate::isAlreadyInSet(), YACS::HMI::OUTPUTPORT, setErrorMsg(), and YASSERT.
◆ localReverse()
bool CommandAddLink::localReverse ( )
Definition at line 2972 of file commandsProc.cxx.
2973{
2974 DEBTRACE("CommandAddLink::localReverse");
2975 try
2976 {
2977 SubjectLink *slink =0;
2978 SubjectControlLink *sclink = 0;
2979 Proc* proc = GuiContext::getCurrent()->getProc();
2980 Node* outn = proc->getChildByName(_outNode);
2981 Node* inn = proc->getChildByName(_inNode);
2982 OutPort* outp;
2983 InPort* inp;
2985 outp = outn->getOutputPort(_outPort);
2986 else
2987 outp = outn->getOutputDataStreamPort(_outPort);
2988 if(_inPortType == INPUTPORT)
2989 inp = inn->getInputPort(_inPort);
2990 else
2991 inp = inn->getInputDataStreamPort(_inPort);
2992 YASSERT(GuiContext::getCurrent()->_mapOfSubjectLink.count(pair<OutPort*,InPort*>(outp,inp)));
2993 slink = GuiContext::getCurrent()->_mapOfSubjectLink[pair<OutPort*,InPort*>(outp,inp)];
2995 {
2996 YASSERT(GuiContext::getCurrent()->_mapOfSubjectControlLink.count(pair<Node*,Node*>(outn,inn)));
2997 sclink = GuiContext::getCurrent()->_mapOfSubjectControlLink[pair<Node*,Node*>(outn,inn)];
2998 }
2999
3000 Subject *father = slink->getParent();
3001 Subject::erase(slink);
3002 slink = 0;
3003 if (father)
3004 {
3005 DEBTRACE("REMOVE");
3006 father->select(true);
3007 father->update(REMOVE,0,0);
3008 }
3009 if (!sclink)
3010 return true;
3011 father=sclink->getParent();
3012 Subject::erase(sclink);
3013 sclink = 0;
3014 if (father)
3015 {
3016 DEBTRACE("REMOVE");
3017 father->select(true);
3018 father->update(REMOVE,0,0);
3019 }
3020 return true;
3021 }
3022 catch (Exception& ex)
3023 {
3024 DEBTRACE("CommandAddLink::localReverse(): " << ex.what());
3025 setErrorMsg(ex);
3026 return false;
3027 }
3028}
std::map< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * >, YACS::HMI::SubjectLink * > _mapOfSubjectLink
Definition: guiContext.hxx:72
std::map< std::pair< YACS::ENGINE::Node *, YACS::ENGINE::Node * >, YACS::HMI::SubjectControlLink * > _mapOfSubjectControlLink
Definition: guiContext.hxx:73
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
virtual void select(bool isSelected)
References _controlCreatedWithDF, _inNode, _inPort, _inPortType, YACS::HMI::GuiContext::_mapOfSubjectControlLink, YACS::HMI::GuiContext::_mapOfSubjectLink, _outNode, _outPort, _outPortType, DEBTRACE, YACS::HMI::Subject::erase(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getInputDataStreamPort(), YACS::ENGINE::Node::getInputPort(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::ENGINE::Node::getOutputPort(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::INPUTPORT, YACS::HMI::OUTPUTPORT, YACS::HMI::REMOVE, YACS::HMI::Subject::select(), setErrorMsg(), YACS::HMI::Subject::update(), and YASSERT.
◆ _control
bool YACS::HMI::CommandAddLink::_control
Definition at line 514 of file commandsProc.hxx.
◆ _controlCreatedWithDF
bool YACS::HMI::CommandAddLink::_controlCreatedWithDF
Definition at line 515 of file commandsProc.hxx.
Referenced by CommandAddLink(), localExecute(), and localReverse().
◆ _inNode
std::string YACS::HMI::CommandAddLink::_inNode
Definition at line 511 of file commandsProc.hxx.
◆ _inPort
std::string YACS::HMI::CommandAddLink::_inPort
Definition at line 512 of file commandsProc.hxx.
◆ _inPortType
TypeOfElem YACS::HMI::CommandAddLink::_inPortType
Definition at line 513 of file commandsProc.hxx.
Referenced by localExecute(), and localReverse().
◆ _outNode
std::string YACS::HMI::CommandAddLink::_outNode
Definition at line 508 of file commandsProc.hxx.
◆ _outPort
std::string YACS::HMI::CommandAddLink::_outPort
Definition at line 509 of file commandsProc.hxx.
◆ _outPortType
TypeOfElem YACS::HMI::CommandAddLink::_outPortType
Definition at line 510 of file commandsProc.hxx.
