YACS::HMI::SubjectDataPort Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectDataPort:
Collaboration diagram for YACS::HMI::SubjectDataPort:
 SubjectDataPort (YACS::ENGINE::DataPort *port, Subject *parent)
virtual ~SubjectDataPort ()
virtual YACS::ENGINE::DataPort * getPort ()
void addSubjectLink (SubjectLink *subject)
void removeSubjectLink (SubjectLink *subject)
std::list< SubjectLink * > getListOfSubjectLink ()
virtual bool setValue (std::string value)
void setExecValue (std::string value)
std::string getExecValue ()
void registerUndoDestroy ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual TypeOfElem getType ()
virtual ~Observer ()
static bool tryCreateLink (SubjectDataPort *subOutport, SubjectDataPort *subInport, bool control=true)
YACS::ENGINE::DataPort * _dataPort
std::string _execValue
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
Definition at line 203 of file guiObservers.hxx.
◆ SubjectDataPort()
SubjectDataPort::SubjectDataPort ( YACS::ENGINE::DataPort *  port,
Subject *  parent
Definition at line 3510 of file guiObservers.cxx.
3511 : Subject(parent), _dataPort(port)
3512{
3513 _listSubjectLink.clear();
3514 _execValue = "";
3515}
std::list< SubjectLink * > _listSubjectLink
Subject(Subject *parent=0)
References _execValue, and _listSubjectLink.
◆ ~SubjectDataPort()
SubjectDataPort::~SubjectDataPort ( )
Definition at line 3517 of file guiObservers.cxx.
3518{
3519 DEBTRACE("SubjectDataPort::~SubjectDataPort " << getName());
3520 if (isDestructible())
3521 {
3522 Node* node = _dataPort->getNode();
3523 ElementaryNode * father = dynamic_cast<ElementaryNode*>(node);
3524 if (father)
3525 {
3526 DEBTRACE("father->edRemovePort(_dataPort)");
3527 try
3528 {
3529 father->edRemovePort(_dataPort);
3530 }
3531 catch (YACS::Exception &e)
3532 {
3533 DEBTRACE("------------------------------------------------------------------------------");
3534 DEBTRACE("SubjectDataPort::~SubjectDataPort: father->edRemovePort: YACS exception " << e.what());
3535 DEBTRACE("------------------------------------------------------------------------------");
3536 }
3537 }
3538 }
3539}
Base class for all nodes.
Definition: Node.hxx:70
Node * getNode() const
Definition: Port.hxx:46
const char * what(void) const noexcept
Definition: Exception.cxx:50
virtual std::string getName()
References _dataPort, DEBTRACE, YACS::ENGINE::ElementaryNode::edRemovePort(), getName(), YACS::ENGINE::Port::getNode(), YACS::HMI::Subject::isDestructible(), and YACS::Exception::what().
◆ addSubjectLink()
void YACS::HMI::SubjectDataPort::addSubjectLink ( SubjectLink *  subject)
Definition at line 214 of file guiObservers.hxx.
214{ _listSubjectLink.push_back(subject); };
Referenced by YACS::HMI::SubjectComposedNode::addSubjectLink().
◆ clean()
void SubjectDataPort::clean ( Command *  command = 0)
Reimplemented in YACS::HMI::SubjectInputPort, YACS::HMI::SubjectOutputPort, YACS::HMI::SubjectInputDataStreamPort, and YACS::HMI::SubjectOutputDataStreamPort.
Definition at line 3541 of file guiObservers.cxx.
3542{
3543 if (_askRegisterUndo)
3544 {
3545 _askRegisterUndo = false;
3547 }
3548 localclean(command);
3549 Subject::clean(command);
3550}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::Subject::clean(), localclean(), and registerUndoDestroy().
Referenced by YACS::HMI::SubjectInputPort::clean(), YACS::HMI::SubjectOutputPort::clean(), YACS::HMI::SubjectInputDataStreamPort::clean(), and YACS::HMI::SubjectOutputDataStreamPort::clean().
◆ getExecValue()
std::string SubjectDataPort::getExecValue ( )
◆ getListOfSubjectLink()
std::list< SubjectLink * > YACS::HMI::SubjectDataPort::getListOfSubjectLink ( )
◆ getName()
◆ getPort()
◆ localclean()
void SubjectDataPort::localclean ( Command *  command = 0)
Definition at line 3552 of file guiObservers.cxx.
3553{
3554 DEBTRACE("SubjectDataPort::localClean ");
3555 list<SubjectLink*> lsl = getListOfSubjectLink();
3556 for (list<SubjectLink*>::iterator it = lsl.begin(); it != lsl.end(); ++it)
3557 erase(*it);
3558}
std::list< SubjectLink * > getListOfSubjectLink()
static void erase(Subject *sub, Command *command=0, bool post=false)
References DEBTRACE, YACS::HMI::Subject::erase(), and getListOfSubjectLink().
Referenced by clean().
◆ registerUndoDestroy()
void SubjectDataPort::registerUndoDestroy ( )
Definition at line 3658 of file guiObservers.cxx.
3659{
3660 DEBTRACE("SubjectDataPort::registerUndoDestroy");
3661 Proc *proc = GuiContext::getCurrent()->getProc();
3662 SubjectNode *sno = dynamic_cast<SubjectNode*>(getParent());
3663 YASSERT(sno);
3664 Node *node = sno->getNode();
3665 string nodeName = proc->getChildName(node);
3666 string portName = getName();
3667 ElementaryNode* father = dynamic_cast<ElementaryNode*>(node);
3668 YASSERT(father);
3669
3670 DataPort *port = getPort();
3671 TypeCode *dtyp = port->edGetType();
3672 string typeName = dtyp->name();
3674 undoCata->_typeMap[typeName] = dtyp;
3675
3676 Command *command = 0;
3677 Command *comm2 =0;
3678 TypeOfElem elemType = getType();
3679 switch (elemType)
3680 {
3681 case INPUTPORT:
3682 command = new CommandAddInputPortFromCatalog(undoCata, typeName, nodeName, portName);
3683 {
3684 int rang = 1;
3685 int nbUp = 0;
3686 list<InputPort*> plist = father->getSetOfInputPort();
3687 list<InputPort*>::iterator pos = plist.begin();
3688 for (; (*pos) != port; pos++)
3689 rang++;
3690 nbUp = plist.size() -rang;
3691 if (nbUp)
3692 comm2 = new CommandOrderInputPorts(nodeName, portName, nbUp);
3693 }
3694 break;
3695 case OUTPUTPORT:
3696 command = new CommandAddOutputPortFromCatalog(undoCata, typeName, nodeName, portName);
3697 {
3698 int rang = 1;
3699 int nbUp = 0;
3700 list<OutputPort*> plist = father->getSetOfOutputPort();
3701 list<OutputPort*>::iterator pos = plist.begin();
3702 for (; (*pos) != port; pos++)
3703 rang++;
3704 nbUp = plist.size() -rang;
3705 if (nbUp)
3706 comm2 = new CommandOrderOutputPorts(nodeName, portName, nbUp);
3707 }
3708 break;
3710 command = new CommandAddIDSPortFromCatalog(undoCata, typeName, nodeName, portName);
3711 break;
3713 command = new CommandAddODSPortFromCatalog(undoCata, typeName, nodeName, portName);
3714 break;
3715 }
3716 if (command)
3717 GuiContext::getCurrent()->getInvoc()->add(command);
3718 if (comm2)
3719 GuiContext::getCurrent()->getInvoc()->add(comm2);
3720 //save links
3721 list<SubjectLink*> lsl = getListOfSubjectLink();
3722 for (list<SubjectLink*>::iterator it = lsl.begin(); it != lsl.end(); ++it)
3723 {
3724 (*it)->registerUndoDestroy();
3725 }
3726}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
class for YACS catalogs.
Definition: Catalog.hxx:42
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::list< OutputPort * > getSetOfOutputPort() const
Definition: Proc.hxx:44
Definition: TypeCode.hxx:68
Definition: TypeCode.cxx:72
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
YACS::ENGINE::Catalog * getUndoCata()
Definition: commands.hxx:67
virtual YACS::ENGINE::DataPort * getPort()
virtual Subject * getParent()
virtual TypeOfElem getType()
@ OUTPUTDATASTREAMPORT
@ INPUTDATASTREAMPORT
References YACS::ENGINE::Catalog::_typeMap, YACS::HMI::Invocator::add(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), getListOfSubjectLink(), getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::Subject::getParent(), getPort(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::ElementaryNode::getSetOfInputPort(), YACS::ENGINE::ElementaryNode::getSetOfOutputPort(), YACS::HMI::Subject::getType(), YACS::HMI::Invocator::getUndoCata(), YACS::HMI::INPUTDATASTREAMPORT, YACS::HMI::INPUTPORT, YACS::ENGINE::TypeCode::name(), YACS::HMI::OUTPUTDATASTREAMPORT, YACS::HMI::OUTPUTPORT, and YASSERT.
Referenced by clean(), YACS::HMI::SubjectInputPort::clean(), YACS::HMI::SubjectOutputPort::clean(), YACS::HMI::SubjectInputDataStreamPort::registerUndoDestroy(), and YACS::HMI::SubjectOutputDataStreamPort::registerUndoDestroy().
◆ removeSubjectLink()
void YACS::HMI::SubjectDataPort::removeSubjectLink ( SubjectLink *  subject)
Definition at line 215 of file guiObservers.hxx.
215{ _listSubjectLink.remove(subject); };
Referenced by YACS::HMI::SubjectComposedNode::removeLink().
◆ setExecValue()
void SubjectDataPort::setExecValue ( std::string  value)
Definition at line 3648 of file guiObservers.cxx.
3649{
3650 _execValue = value;
3651}
References _execValue.
Referenced by YACS::HMI::GuiExecutor::event(), and YACS::HMI::GuiExecutor::updateSchema().
◆ setName()
bool SubjectDataPort::setName ( std::string  name)
Definition at line 3565 of file guiObservers.cxx.
3566{
3567 DEBTRACE("SubjectDataPort::setName " << name);
3568 Proc *proc = GuiContext::getCurrent()->getProc();
3569 string position = "";
3570 Node *node = getPort()->getNode();
3571 if (proc != dynamic_cast<Proc*>(node))
3572 position = proc->getChildName(node);
3573 else
3574 position = node->getName();
3575
3576 Command *command = 0;
3577 bool isIn = dynamic_cast<InPort*>(_dataPort);
3578 if (isIn)
3579 command = new CommandRenameInDataPort(position, _dataPort->getName(),name, getType());
3580 else
3581 command = new CommandRenameOutDataPort(position, _dataPort->getName(),name, getType());
3582
3583 if (command->execute())
3584 {
3585 GuiContext::getCurrent()->getInvoc()->add(command);
3586 return true;
3587 }
3588 else delete command;
3589 return false;
3590}
Definition: Node.hxx:125
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
References _dataPort, YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Port::getNode(), getPort(), YACS::HMI::GuiContext::getProc(), and YACS::HMI::Subject::getType().
Referenced by YACS::HMI::SubjectNode::addSubjectIDSPort(), YACS::HMI::SubjectNode::addSubjectInputPort(), YACS::HMI::SubjectNode::addSubjectODSPort(), YACS::HMI::SubjectNode::addSubjectOutputPort(), YACS::HMI::EditionElementaryNode::onCommitData(), and YACS::HMI::TreeView::onCommitData().
◆ setValue()
bool SubjectDataPort::setValue ( std::string  value)
◆ tryCreateLink()
bool SubjectDataPort::tryCreateLink ( SubjectDataPort *  subOutport,
SubjectDataPort *  subInport,
bool  control = true
Definition at line 3597 of file guiObservers.cxx.
3598{
3599 DEBTRACE("SubjectDataPort::tryCreateLink");
3600
3601 InPort *inp = dynamic_cast<InPort*>(subInport->getPort());
3602 OutPort *outp = dynamic_cast<OutPort*>(subOutport->getPort());
3603 if (outp && outp->isAlreadyLinkedWith(inp))
3604 {
3605 DEBTRACE("isAlreadyLinkedWith");
3606 GuiContext::getCurrent()->_lastErrorMessage = "Ports are already linked";
3607 return false;
3608 }
3609
3610 Proc *proc = GuiContext::getCurrent()->getProc();
3611
3612 string outNodePos = "";
3613 SubjectNode *sno = dynamic_cast<SubjectNode*>(subOutport->getParent());
3614 YASSERT(sno);
3615 Node *outNode = sno->getNode();
3616 outNodePos = proc->getChildName(outNode);
3617 string outportName = subOutport->getName();
3618
3619 string inNodePos = "";
3620 SubjectNode *sni = dynamic_cast<SubjectNode*>(subInport->getParent());
3621 YASSERT(sni);
3622 Node *inNode = sni->getNode();
3623 inNodePos = proc->getChildName(inNode);
3624 string inportName = subInport->getName();
3625
3626 CommandAddLink *command = new CommandAddLink(outNodePos, outportName, subOutport->getType(),
3627 inNodePos, inportName, subInport->getType(), control);
3628 if (command->execute())
3629 {
3630 GuiContext::getCurrent()->getInvoc()->add(command);
3631 return true;
3632 }
3633 else
3634 {
3635 delete command;
3636 return false;
3637 }
3638}
virtual bool isAlreadyLinkedWith(InPort *withp) const =0
std::string _lastErrorMessage
Definition: guiContext.hxx:79
References YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::Subject::getParent(), getPort(), YACS::HMI::GuiContext::getProc(), YACS::HMI::Subject::getType(), YACS::ENGINE::OutPort::isAlreadyLinkedWith(), and YASSERT.
Referenced by YACS::HMI::SceneInPortItem::dropEvent(), and YACS::HMI::SchemaInPortItem::dropMimeData().
◆ _dataPort
YACS::ENGINE::DataPort* YACS::HMI::SubjectDataPort::_dataPort
Definition at line 222 of file guiObservers.hxx.
Referenced by getName(), getPort(), setName(), and ~SubjectDataPort().
◆ _execValue
std::string YACS::HMI::SubjectDataPort::_execValue
Definition at line 224 of file guiObservers.hxx.
Referenced by getExecValue(), setExecValue(), and SubjectDataPort().
◆ _listSubjectLink
std::list<SubjectLink*> YACS::HMI::SubjectDataPort::_listSubjectLink
Definition at line 223 of file guiObservers.hxx.
Referenced by SubjectDataPort().
