ValueDelegate.cxx
20#include "ValueDelegate.hxx"
21#include "guiObservers.hxx"
22#include "SchemaItem.hxx"
23#include "DataPort.hxx"
24#include "StudyPorts.hxx"
25#include "TypeCode.hxx"
26#include "Switch.hxx"
27#include "ItemEdition.hxx"
28
29//#define _DEVDEBUG_
30#include "YacsTrace.hxx"
31
32#include <QSize>
33#include <QSpinBox>
34#include <cassert>
35#include <climits>
36
37using namespace std;
38using namespace YACS::HMI;
39
40
41// -----------------------------------------------------------------------------
42
43GenericEditor::GenericEditor()
44{
45 _subject = 0;
46 _column = 0;
47 _delegate = 0;
48 _first = true;
49}
50
52{
53 DEBTRACE("GenericEditor::~GenericEditor " << this);
54
55}
56
58{
59 _subject = subject;
60}
61
63{
64 _column= column;
65}
66
68{
69 _delegate = delegate;
70}
71
73{
74 return "";
75}
76
78{
79 return _subject;
80}
81
83{
84 return _column;
85}
86
87void GenericEditor::setData(QVariant val)
88{
89}
90
92{
93 bool ret = _first;
94 _first = false;
95 return ret;
96}
97
98// -----------------------------------------------------------------------------
99
101 const ValueDelegate* delegate,
102 int column,
103 QWidget * parent)
104 : QLineEdit(parent), GenericEditor()
105{
106 DEBTRACE("GeneralEditor::GeneralEditor");
107 setDelegate(delegate);
108 setSubject(subject);
109 setColumn(column);
110}
111
113{
114}
115
117{
118 DEBTRACE("GeneralEditor::GetStrValue " << text().toStdString());
119 return text();
120}
121
122void GeneralEditor::setData(QVariant val)
123{
124 DEBTRACE("GeneralEditor::setData " << this);
125 DEBTRACE(val.canConvert<QString>());
126 DEBTRACE(val.toString().toStdString());
127 setText(val.toString());
128}
129
130// -----------------------------------------------------------------------------
131
133 const ValueDelegate* delegate,
134 int column,
135 QWidget * parent)
136 : QLineEdit(parent), GenericEditor()
137{
138 DEBTRACE("NameEditor::NameEditor");
139 setDelegate(delegate);
140 setSubject(subject);
141 setColumn(column);
142}
143
145{
146}
147
149{
150 DEBTRACE("Name::GetStrValue " << text().toStdString());
151 string filtered = ItemEdition::filterName(text().toStdString());
152 return filtered.c_str();
153}
154
155void NameEditor::setData(QVariant val)
156{
157 DEBTRACE("NameEditor::setData " << this);
158 DEBTRACE(val.canConvert<QString>());
159 DEBTRACE(val.toString().toStdString());
160 string filtered = ItemEdition::filterName(val.toString().toStdString());
161 setText(filtered.c_str());
162}
163
164// -----------------------------------------------------------------------------
165
167 const ValueDelegate* delegate,
168 int column,
169 QWidget * parent)
170 : QSpinBox(parent), GenericEditor()
171{
172 setMinimum(INT_MIN);
173 setMaximum(INT_MAX);
174 setSubject(subject);
175 setDelegate(delegate);
176 setColumn(column);
177}
178
180{
181}
182
184{
185 QString str;
186 str.setNum(value());
187 return str;
188}
189
190void IntEditor::setData(QVariant val)
191{
192 DEBTRACE("IntEditor::setData");
193 DEBTRACE(val.canConvert<int>());
194 setValue(val.toInt());
195}
196
197// -----------------------------------------------------------------------------
198
200 const ValueDelegate* delegate,
201 int column,
202 QWidget* parent)
203 : CaseSwitch(parent), GenericEditor()
204{
205 sb_case->setMinimum(INT_MIN);
206 sb_case->setMaximum(INT_MAX);
207 setSubject(subject);
208 setDelegate(delegate);
209 setColumn(column);
210}
211
213{
214}
215
217{
218 QString str;
219 int val = sb_case->value();
220 if (_isDefault)
222 str.setNum(val);
223 DEBTRACE(val);
224 return str;
225}
226
228{
229 DEBTRACE("CaseSwitchEditor::setData");
230 if (val == "default")
231 {
232 setDefaultChecked(true);
233 }
234 else
235 {
236 setDefaultChecked(false);
237 DEBTRACE(val.canConvert<int>() << " " << val.toInt());
238 sb_case->setValue(val.toInt());
239 }
240}
241
242
243// -----------------------------------------------------------------------------
244
246 : QItemDelegate(parent)
247{
248 DEBTRACE("ValueDelegate::ValueDelegate");
249 _errorMap.clear();
250}
251
253{
254 DEBTRACE("ValueDelegate::~ValueDelegate");
255}
256
258 const QStyleOptionViewItem &option,
259 const QModelIndex &index) const
260{
261 DEBTRACE("ValueDelegate::createEditor");
262
263 SchemaItem *item = static_cast<SchemaItem*>(index.internalPointer());
264 Subject *subject = item->getSubject();
265 int column = index.column();
266 DEBTRACE(subject->getName() << " " << column);
267
268 QWidget *editor = 0;
269 SubjectDataPort *sport = 0;
270 SubjectNode *snode = 0;
271
272 if (column == YValue)
273 {
274 sport = dynamic_cast<SubjectDataPort*>(subject);
275 if (!sport)
276 snode= dynamic_cast<SubjectNode*>(subject);
277
278 if (sport)
279 {
280 YACS::ENGINE::DataPort *port = sport->getPort();
283 YACS::ENGINE::TypeCode *tc = port->edGetType();
284 YACS::ENGINE::DynType dt = tc->kind();
285 if (!istport && !ostport && dt == YACS::ENGINE::Int)
286 editor = new IntEditor(subject, this, column, parent);
287 }
288 else if (snode)
289 {
290 SubjectSwitch *sSwitch = dynamic_cast<SubjectSwitch*>(snode->getParent());
291 if (sSwitch)
292 editor = new CaseSwitchEditor(subject, this, column, parent);
293 }
294 }
295
296 if (column == YLabel)
297 {
298 sport = dynamic_cast<SubjectDataPort*>(subject);
299 if (sport)
300 editor = new NameEditor(subject, this, column, parent);
301 }
302
303 if (!editor) editor = new GeneralEditor(subject, this, column, parent);
304 return editor;
305}
306
314 const QModelIndex &index) const
315{
316 DEBTRACE("ValueDelegate::setEditorData");
317 GenericEditor* gedit = dynamic_cast<GenericEditor*>(editor);
318 YASSERT(gedit);
319 QString edited = gedit->GetStrValue();
320 DEBTRACE(edited.toStdString());
321 Subject *sub = gedit->getSubject();
322 if (! gedit->firstSetData()) // --- editor already initialized
323 return;
324 else if (_errorMap.count(sub)) // --- initialize with previous error
325 {
326 string error = _errorMap[sub];
327 gedit->setData(QString(error.c_str()));
328 _errorMap.erase(gedit->getSubject());
329 DEBTRACE("--------erase-----------");
330 }
331 else // --- initialize with model
332 gedit->setData(index.model()->data(index, Qt::DisplayRole));
333}
334
339 QAbstractItemModel *model,
340 const QModelIndex &index) const
341{
342 DEBTRACE("ValueDelegate::setModelData");
343 GenericEditor* gedit = dynamic_cast<GenericEditor*>(editor);
344 YASSERT(gedit);
345 QString value = gedit->GetStrValue();
346 DEBTRACE(value.toStdString());
347 //model->setData(index, value, Qt::EditRole); // real set done by update
348}
349
351 const QStyleOptionViewItem &option,
352 const QModelIndex &index) const
353{
354 DEBTRACE("ValueDelegate::updateEditorGeometry");
355 editor->setGeometry(option.rect);
356}
357
364{
365 DEBTRACE("ValueDelegate::setResultEditing " << isOk);
366 GenericEditor* gedit = dynamic_cast<GenericEditor*>(editor);
367 YASSERT(gedit);
368 Subject *sub = gedit->getSubject();
369 string val = gedit->GetStrValue().toStdString();
370 DEBTRACE(sub->getName() << " " << val);
371 if (!isOk)
372 {
373 sub->update(EDIT, 1, sub);
374 _errorMap[sub] = val;
375 }
376 else
377 sub->update(EDIT, 0, sub);
378}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Class for Study input Ports.
Definition: StudyPorts.hxx:51
Class for Study output Ports.
Definition: StudyPorts.hxx:33
static const int ID_FOR_DEFAULT_NODE
Definition: Switch.hxx:91
Definition: TypeCode.hxx:68
DynType kind() const
Definition: TypeCode.cxx:47
virtual void setData(QVariant val)
CaseSwitchEditor(Subject *subject, const ValueDelegate *delegate, int column=0, QWidget *parent=0)
virtual QString GetStrValue()
void setDefaultChecked(bool isDefault)
Definition: CaseSwitch.cxx:55
GeneralEditor(Subject *subject, const ValueDelegate *delegate, int column=0, QWidget *parent=0)
virtual int getColumnInSubject()
virtual void setDelegate(const ValueDelegate *delegate)
virtual Subject * getSubject()
virtual void setColumn(int column)
virtual void setSubject(Subject *subject)
virtual bool firstSetData()
const ValueDelegate * _delegate
IntEditor(Subject *subject, const ValueDelegate *delegate, int column=0, QWidget *parent=0)
static std::string filterName(const std::string &name)
NameEditor(Subject *subject, const ValueDelegate *delegate, int column=0, QWidget *parent=0)
Definition: SchemaItem.cxx:169
virtual YACS::ENGINE::DataPort * getPort()
virtual Subject * getParent()
virtual std::string getName()
std::map< Subject *, std::string > _errorMap
virtual void setEditorData(QWidget *editor, const QModelIndex &index) const
virtual void updateEditorGeometry(QWidget *editor, const QStyleOptionViewItem &option, const QModelIndex &index) const
virtual QWidget * createEditor(QWidget *parent, const QStyleOptionViewItem &option, const QModelIndex &index) const
virtual void setModelData(QWidget *editor, QAbstractItemModel *model, const QModelIndex &index) const
ValueDelegate(QObject *parent=0)
virtual void setResultEditing(QWidget *editor, bool isOk)
