YACS::HMI::CaseSwitchEditor Class Reference
#include <ValueDelegate.hxx>
Inheritance diagram for YACS::HMI::CaseSwitchEditor:
Collaboration diagram for YACS::HMI::CaseSwitchEditor:
 CaseSwitchEditor (Subject *subject, const ValueDelegate *delegate, int column=0, QWidget *parent=0)
virtual ~CaseSwitchEditor ()
virtual QString GetStrValue ()
virtual void setData (QVariant val)
- Public Member Functions inherited from YACS::HMI::CaseSwitch
 CaseSwitch (QWidget *parent=0)
 ~CaseSwitch ()
bool isDefaultChecked ()
void setDefaultChecked (bool isDefault)
- Public Member Functions inherited from YACS::HMI::GenericEditor
 GenericEditor ()
virtual ~GenericEditor ()
virtual void setSubject (Subject *subject)
virtual void setColumn (int column)
virtual void setDelegate (const ValueDelegate *delegate)
virtual int getColumnInSubject ()
virtual bool firstSetData ()
- Public Slots inherited from YACS::HMI::CaseSwitch
void on_cb_default_stateChanged (int state)
- Protected Attributes inherited from YACS::HMI::CaseSwitch
bool _isDefault
- Protected Attributes inherited from YACS::HMI::GenericEditor
Subject * _subject
int _column
const ValueDelegate * _delegate
bool _first
Definition at line 102 of file ValueDelegate.hxx.
◆ CaseSwitchEditor()
CaseSwitchEditor::CaseSwitchEditor ( Subject *  subject,
const ValueDelegate *  delegate,
int  column = 0,
QWidget *  parent = 0
Definition at line 199 of file ValueDelegate.cxx.
203 : CaseSwitch(parent), GenericEditor()
204{
205 sb_case->setMinimum(INT_MIN);
206 sb_case->setMaximum(INT_MAX);
207 setSubject(subject);
208 setDelegate(delegate);
209 setColumn(column);
210}
CaseSwitch(QWidget *parent=0)
Definition: CaseSwitch.cxx:28
virtual void setDelegate(const ValueDelegate *delegate)
virtual void setColumn(int column)
virtual void setSubject(Subject *subject)
References YACS::HMI::GenericEditor::setColumn(), YACS::HMI::GenericEditor::setDelegate(), and YACS::HMI::GenericEditor::setSubject().
◆ ~CaseSwitchEditor()
CaseSwitchEditor::~CaseSwitchEditor ( )
Definition at line 212 of file ValueDelegate.cxx.
213{
214}
◆ GetStrValue()
QString CaseSwitchEditor::GetStrValue ( )
Reimplemented from YACS::HMI::GenericEditor.
Definition at line 216 of file ValueDelegate.cxx.
217{
218 QString str;
219 int val = sb_case->value();
220 if (_isDefault)
222 str.setNum(val);
223 DEBTRACE(val);
224 return str;
225}
static const int ID_FOR_DEFAULT_NODE
Definition: Switch.hxx:91
References YACS::HMI::CaseSwitch::_isDefault, DEBTRACE, and YACS::ENGINE::Switch::ID_FOR_DEFAULT_NODE.
◆ setData()
void CaseSwitchEditor::setData ( QVariant  val)
Definition at line 227 of file ValueDelegate.cxx.
228{
229 DEBTRACE("CaseSwitchEditor::setData");
230 if (val == "default")
231 {
232 setDefaultChecked(true);
233 }
234 else
235 {
236 setDefaultChecked(false);
237 DEBTRACE(val.canConvert<int>() << " " << val.toInt());
238 sb_case->setValue(val.toInt());
239 }
240}
void setDefaultChecked(bool isDefault)
Definition: CaseSwitch.cxx:55
References DEBTRACE, and YACS::HMI::CaseSwitch::setDefaultChecked().
