YACS::ENGINE::OutputStudyPort Class Reference
Class for Study output Ports. More...
#include <StudyPorts.hxx>
Inheritance diagram for YACS::ENGINE::OutputStudyPort:
Collaboration diagram for YACS::ENGINE::OutputStudyPort:
 OutputStudyPort (const std::string &name, Node *node, TypeCode *type)
 OutputStudyPort (const OutputStudyPort &other, Node *newHelder)
OutputPort * clone (Node *newHelder) const
void setData (const std::string &data)
std::string getData ()
virtual void putIOR (const std::string &ior)
virtual std::string dump ()
virtual std::string getPyObj ()
virtual void getDataFromStudy ()
- Public Member Functions inherited from YACS::ENGINE::OutputXmlPort
 OutputXmlPort (const std::string &name, Node *node, TypeCode *type)
 OutputXmlPort (const OutputXmlPort &other, Node *newHelder)
void put (const char *data)
virtual const char * get () const
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
std::string _storeData
- Protected Attributes inherited from YACS::ENGINE::OutputXmlPort
std::string _data
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
StudyInNode
Definition at line 32 of file StudyPorts.hxx.
◆ OutputStudyPort() [1/2]
YACS::ENGINE::OutputStudyPort::OutputStudyPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 52 of file StudyPorts.cxx.
53 : OutputXmlPort(name, node, type),
54 DataPort(name, node, type),
55 Port(node)
56{
57}
Definition: DataPort.cxx:41
OutputXmlPort(const std::string &name, Node *node, TypeCode *type)
Definition: XMLPorts.cxx:122
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ OutputStudyPort() [2/2]
YACS::ENGINE::OutputStudyPort::OutputStudyPort ( const OutputStudyPort &  other,
Node *  newHelder
Definition at line 59 of file StudyPorts.cxx.
60 : OutputXmlPort(other,newHelder),
61 DataPort(other,newHelder),
62 Port(other,newHelder),_storeData(other._storeData)
63{
64}
◆ clone()
OutputPort * YACS::ENGINE::OutputStudyPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::OutputPort.
Definition at line 66 of file StudyPorts.cxx.
67{
68 return new OutputStudyPort(*this,newHelder);
69}
OutputStudyPort(const std::string &name, Node *node, TypeCode *type)
Definition: StudyPorts.cxx:52
References OutputStudyPort().
◆ dump()
std::string YACS::ENGINE::OutputStudyPort::dump ( )
Reimplemented from YACS::ENGINE::OutputXmlPort.
Definition at line 122 of file StudyPorts.cxx.
123{
124 DEBTRACE( "OutputStudyPort::dump " << _storeData );
125 DEBTRACE( "OutputStudyPort::dump " << _data );
126 //return "<value><string>"+_storeData+"</string></value>";
127 return _data;
128}
References YACS::ENGINE::OutputXmlPort::_data, _storeData, and DEBTRACE.
◆ getAsString()
std::string YACS::ENGINE::OutputStudyPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 134 of file StudyPorts.cxx.
135{
136 return getData();
137}
References getData().
Referenced by YACS::HMI::CommandSetOutPortValue::localExecute(), and YACS::HMI::CommandSetOutPortValue::localReverse().
◆ getData()
std::string YACS::ENGINE::OutputStudyPort::getData ( )
◆ getDataFromStudy()
void YACS::ENGINE::OutputStudyPort::getDataFromStudy ( )
Definition at line 139 of file StudyPorts.cxx.
140{
141 std::string data = getData();
142 DEBTRACE("data: " << data );
143 //try an id
144 SALOMEDS::SObject_var aSO = KERNEL::getStudyServant()->FindObjectID(data.c_str());
145 if(CORBA::is_nil(aSO))
146 {
147 //try a path
148 aSO=KERNEL::getStudyServant()->FindObjectByPath(data.c_str());
149 if(CORBA::is_nil(aSO))
150 {
151 std::stringstream msg;
152 msg << "Execution problem: no id or path: " << data << " in study";
153 throw Exception(msg.str());
154 }
155 }
156
157 CORBA::String_var path=KERNEL::getStudyServant()->GetObjectPath(aSO);
158 DEBTRACE(path);
159 CORBA::String_var id=aSO->GetID();
160 DEBTRACE(id);
161 //CORBA::Object_var sobj=aSO->GetObject();
162
163 SALOMEDS::GenericAttribute_var aGAttr;
164 CORBA::String_var value;
165
166 if(edGetType()->kind()==Objref)
167 {
168 if ( aSO->FindAttribute( aGAttr, "AttributeIOR" ) )
169 {
170 SALOMEDS::AttributeIOR_var anAttr = SALOMEDS::AttributeIOR::_narrow( aGAttr );
171 value=anAttr->Value();
172 putIOR((const char*)value);
173 }
174 else
175 {
176 //Problem !!!
177 std::string error="Execution problem: no AttributeIOR in study object: ";
178 error=error+data;
179 throw Exception(error);
180 }
181 }
182 else if(edGetType()->kind()==Double )
183 {
184 if ( aSO->FindAttribute( aGAttr, "AttributeReal" ) )
185 {
186 SALOMEDS::AttributeReal_var anAttr = SALOMEDS::AttributeReal::_narrow( aGAttr );
187 CORBA::Double d=anAttr->Value();
188 std::stringstream msg;
189 msg << "<value><double>" << std::setprecision(16) << d << "</double></value>";
190 put(msg.str().c_str());
191 }
192 else
193 {
194 std::string error="Execution problem: no AttributeReal in study object: ";
195 throw Exception(error+data);
196 }
197 }
198 else if(edGetType()->kind()== Int)
199 {
200 if ( aSO->FindAttribute( aGAttr, "AttributeInteger" ) )
201 {
202 SALOMEDS::AttributeInteger_var anAttr = SALOMEDS::AttributeInteger::_narrow( aGAttr );
203 CORBA::Long l=anAttr->Value();
204 std::stringstream msg;
205 msg << "<value><int>" << l << "</int></value>";
206 put(msg.str().c_str());
207 }
208 else
209 {
210 std::string error="Execution problem: no AttributeInteger in study object: ";
211 throw Exception(error+data);
212 }
213 }
214 else
215 {
216 if ( aSO->FindAttribute( aGAttr, "AttributeComment" ) )
217 {
218 SALOMEDS::AttributeComment_var anAttr = SALOMEDS::AttributeComment::_narrow( aGAttr );
219 value=anAttr->Value();
220 DEBTRACE(value);
221 putIOR((const char*)value);
222 }
223 else
224 {
225 std::string error="Execution problem: no AttributeComment in study object: ";
226 throw Exception(error+data);
227 }
228 }
229}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual void putIOR(const std::string &ior)
Definition: StudyPorts.cxx:84
Definition: XMLPorts.cxx:137
References DEBTRACE, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), getData(), YACS::ENGINE::Int, testCppPluginInvokation::l, YACS::ENGINE::Objref, YACS::ENGINE::OutputXmlPort::put(), and putIOR().
Referenced by YACS::ENGINE::StudyInNode::execute().
◆ getPyObj()
std::string YACS::ENGINE::OutputStudyPort::getPyObj ( )
Definition at line 130 of file StudyPorts.cxx.
131{
132 return getData();
133}
◆ putIOR()
void YACS::ENGINE::OutputStudyPort::putIOR ( const std::string &  ior)
Definition at line 84 of file StudyPorts.cxx.
85{
86 DEBTRACE("OutputStudyPort::putIOR " << ior);
87 if(ior.substr(0,7) == "<value>")
88 {
89 put(ior.c_str());
90 }
91 else
92 {
93 int tk=edGetType()->kind();
94 std::string value;
95 switch(tk)
96 {
97 case Double:
98 value="<value><double>"+ior+"</double></value>";
99 break;
100 case Int:
101 value="<value><int>"+ior+"</int></value>";
102 break;
103 case String:
104 value="<value><string>"+ior+"</string></value>";
105 break;
106 case Bool:
107 value="<value><boolean>"+ior+"</boolean></value>";
108 break;
109 case Objref:
110 value="<value><objref>"+ior+"</objref></value>";
111 break;
112 case Sequence:
113 case Array:
114 case Struct:
115 default:
116 break;
117 }
118 put(value.c_str());
119 }
120}
DynType kind() const
Definition: TypeCode.cxx:47
References YACS::ENGINE::Array, YACS::ENGINE::Bool, DEBTRACE, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::Int, YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, YACS::ENGINE::OutputXmlPort::put(), YACS::ENGINE::Sequence, YACS::ENGINE::String, and YACS::ENGINE::Struct.
Referenced by getDataFromStudy().
◆ setData()
void YACS::ENGINE::OutputStudyPort::setData ( const std::string &  data)
Definition at line 71 of file StudyPorts.cxx.
72{
73 _storeData = data;
74 DEBTRACE( "OutputStudyPort::setData " << _storeData );
75 modified();
76}
void modified()
Definition: Port.cxx:53
References _storeData, DEBTRACE, and YACS::ENGINE::Port::modified().
Referenced by YACS::ENGINE::StudyInNode::setData().
◆ typeName()
virtual std::string YACS::ENGINE::OutputStudyPort::typeName ( )
Reimplemented from YACS::ENGINE::OutputPort.
Definition at line 44 of file StudyPorts.hxx.
44{return "YACS__ENGINE__OutputStudyPort";}
◆ _storeData
std::string YACS::ENGINE::OutputStudyPort::_storeData
Definition at line 47 of file StudyPorts.hxx.
Referenced by dump(), getData(), and setData().
