YACS::ENGINE::StudyInNode Class Reference
#include <StudyNodes.hxx>
Inheritance diagram for YACS::ENGINE::StudyInNode:
Collaboration diagram for YACS::ENGINE::StudyInNode:
 StudyInNode (const std::string &name)
 StudyInNode (const StudyInNode &other, ComposedNode *father)
virtual void execute ()
virtual void setData (OutputPort *port, const std::string &data)
- Public Member Functions inherited from YACS::ENGINE::DataNode
virtual void setData (InputPort *port, const std::string &data)
virtual void setRef (const std::string &ref)
virtual std::string getRef ()
virtual ~DataNode ()
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char IMPL_NAME [] ="XML"
Node * simpleClone (ComposedNode *father, bool editionOnly) const
- Protected Member Functions inherited from YACS::ENGINE::DataNode
 DataNode (const DataNode &other, ComposedNode *father)
 DataNode (const std::string &name)
template<class PORT >
YACS::Colour _colour
- Protected Attributes inherited from YACS::ENGINE::DataNode
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 30 of file StudyNodes.hxx.
◆ StudyInNode() [1/2]
YACS::ENGINE::StudyInNode::StudyInNode ( const std::string &  name)
Definition at line 48 of file StudyNodes.cxx.
49 : DataNode(name)
50{
52}
DataNode(const DataNode &other, ComposedNode *father)
Definition: DataNode.hxx:40
Definition: Node.hxx:97
static const char IMPL_NAME[]
Definition: StudyNodes.hxx:44
References YACS::ENGINE::Node::_implementation, and IMPL_NAME.
Referenced by simpleClone().
◆ StudyInNode() [2/2]
YACS::ENGINE::StudyInNode::StudyInNode ( const StudyInNode &  other,
ComposedNode *  father
Definition at line 54 of file StudyNodes.cxx.
55 : DataNode(other, father)
56{
57}
◆ accept()
void YACS::ENGINE::StudyInNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 133 of file StudyNodes.cxx.
134{
135 visitor->visitStudyInNode(this);
136}
References YACS::ENGINE::Visitor::visitStudyInNode().
◆ checkBasicConsistency()
void YACS::ENGINE::StudyInNode::checkBasicConsistency ( ) const
Definition at line 96 of file StudyNodes.cxx.
97{
98 DEBTRACE("StudyInNode::checkBasicConsistency");
99 if (! _setOfInputPort.empty())
100 {
101 std::string what = "StudyNode ";
102 what += getName();
103 what += " only accepts OutputStudyPort, no InputPort";
104 throw Exception(what);
105 }
106
107 std::list<OutputPort *>::const_iterator iter;
108 for(iter=_setOfOutputPort.begin();iter!=_setOfOutputPort.end();iter++)
109 {
110 OutputStudyPort *inp = dynamic_cast<OutputStudyPort*>(*iter);
111 if (!inp)
112 {
113 std::string what("Output port: ");
114 what += (*iter)->getName();
115 what += " is not an OutputStudyPort. StudyNode ";
116 what += getName();
117 what += " only accepts OutputStudyPorts";
118 throw Exception(what);
119 }
120
121 std::string data = inp->getData();
122 DEBTRACE(data);
123 if (data.empty())
124 {
125 std::string what("OutputStudyPort: ");
126 what += (*iter)->getName();
127 what += " is not initialised";
128 throw Exception(what);
129 }
130 }
131}
Definition: Node.hxx:125
References YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, YACS::ENGINE::OutputStudyPort::getData(), and YACS::ENGINE::Node::getName().
◆ createOutputPort()
OutputPort * YACS::ENGINE::StudyInNode::createOutputPort ( const std::string &  outputPortName,
TypeCode *  type
Definition at line 64 of file StudyNodes.cxx.
65{
66 return new OutputStudyPort(outputPortName, this, type);
67}
◆ execute()
void YACS::ENGINE::StudyInNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 75 of file StudyNodes.cxx.
76{
77 DEBTRACE("+++++++ StudyInNode::execute +++++++++++");
78
79 std::list<OutputPort *>::const_iterator iter;
80 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
81 {
82 OutputStudyPort *outp = dynamic_cast<OutputStudyPort *>(*iter);
83 try
84 {
85 outp->getDataFromStudy();
86 }
87 catch(Exception& e)
88 {
89 _errorDetails=e.what();
90 throw;
91 }
92 }
93 DEBTRACE("+++++++ end StudyInNode::execute +++++++++++" );
94}
Definition: Node.hxx:93
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, YACS::ENGINE::OutputStudyPort::getDataFromStudy(), and YACS::Exception::what().
◆ setData()
void YACS::ENGINE::StudyInNode::setData ( OutputPort *  port,
const std::string &  data
Reimplemented from YACS::ENGINE::DataNode.
Definition at line 69 of file StudyNodes.cxx.
70{
71 OutputStudyPort *outp = dynamic_cast<OutputStudyPort *>(port);
72 outp->setData(data);
73}
References YACS::ENGINE::OutputStudyPort::setData().
◆ simpleClone()
Node * YACS::ENGINE::StudyInNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 59 of file StudyNodes.cxx.
60{
61 return new StudyInNode(*this,father);
62}
StudyInNode(const std::string &name)
Definition: StudyNodes.cxx:48
References StudyInNode().
◆ typeName()
virtual std::string YACS::ENGINE::StudyInNode::typeName ( )
Definition at line 42 of file StudyNodes.hxx.
42{return "YACS__ENGINE__StudyInNode";}
◆ IMPL_NAME
const char YACS::ENGINE::StudyInNode::IMPL_NAME ="XML"
Definition at line 44 of file StudyNodes.hxx.
Referenced by StudyInNode().
