YACS::HMI::ItemEdition Class Reference
#include <ItemEdition.hxx>
Inheritance diagram for YACS::HMI::ItemEdition:
Collaboration diagram for YACS::HMI::ItemEdition:
Public Slots
virtual void onApply ()
virtual void onCancel ()
virtual ~ItemEdition ()
virtual void synchronize ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
static void setEventMap ()
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
Definition at line 53 of file ItemEdition.hxx.
◆ ItemEdition()
ItemEdition::ItemEdition ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
generic item edition based on a FormEditItem widget to be completed in derived classes. Apply - cancel edition buttons are not always relevants.
Definition at line 151 of file ItemEdition.cxx.
154 : FormEditItem(parent), ItemEditionBase(subject)
155{
156 DEBTRACE("ItemEdition::ItemEdition " << name);
157
158 _haveScript = false;
159 _isEdited = false;
160 setEdited(false);
161
162 connect(_wid->pb_apply, SIGNAL(clicked()), this, SLOT(onApply()));
163 connect(_wid->pb_cancel, SIGNAL(clicked()), this, SLOT(onCancel()));
164
165 // --- type of item and name
166
167 _wid->la_type->setText(_type.c_str());
168 _wid->le_name->setText(_name.c_str());
169 connect(_wid->le_name, SIGNAL(textChanged(const QString&)),
170 this, SLOT(onModifyName(const QString&)));
171 _wid->le_name->setReadOnly(true); // to be changed on derived classes depending on context
172
174 DEBTRACE("_stackId " << _stackId);
175 YASSERT(!QtGuiContext::getQtCurrent()->_mapOfEditionItem.count(_subject));
177 //QtGuiContext::getQtCurrent()->getStackedWidget()->raiseWidget(_stackId);
178}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
FormEditItem(QWidget *parent=0)
WidEditItem * _wid
ItemEditionBase(Subject *subject)
Definition: ItemEdition.cxx:68
virtual void onModifyName(const QString &text)
virtual void setEdited(bool isEdited)
virtual void onApply()
virtual void onCancel()
QStackedWidget * getStackedWidget()
std::map< YACS::HMI::Subject *, QWidget * > _mapOfEditionItem
References _haveScript, _isEdited, YACS::HMI::QtGuiContext::_mapOfEditionItem, YACS::HMI::ItemEditionBase::_name, YACS::HMI::ItemEditionBase::_stackId, YACS::HMI::ItemEditionBase::_subject, YACS::HMI::ItemEditionBase::_type, FormEditItem::_wid, DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getStackedWidget(), onApply(), onCancel(), onModifyName(), setEdited(), and YASSERT.
Referenced by update().
◆ ~ItemEdition()
ItemEdition::~ItemEdition ( )
◆ filterName()
std::string ItemEdition::filterName ( const std::string &  name)
Definition at line 242 of file ItemEdition.cxx.
243{
244 string nameFiltered;
245 nameFiltered = "";
246 for (int i= 0; i< name.size(); i++)
247 {
248 unsigned char a = (unsigned char)(name[i]);
249 if ( ((a >= '0') && (a <= '9'))
250 || ((a >= 'A') && (a <= 'Z'))
251 || ((a >= 'a') && (a <= 'z'))
252 || ( a == '_'))
253 nameFiltered += a;
254 }
255 DEBTRACE(name << " " << nameFiltered);
256 return nameFiltered;
257}
References gui.CONNECTOR::a, DEBTRACE, and yacsorb.CORBAEngineTest::i.
Referenced by YACS::HMI::NameEditor::GetStrValue(), onApply(), and YACS::HMI::NameEditor::setData().
◆ onApply
void ItemEdition::onApply ( )
virtualslot
Definition at line 214 of file ItemEdition.cxx.
215{
216 DEBTRACE("onApply");
217 string name = _wid->le_name->text().toStdString();
218 name = filterName(name);
219 bool nameEdited = false;
220 if (name != _name)
221 {
222 nameEdited = true;
223 bool ret = _subject->setName(name);
224 if (ret)
225 {
226 nameEdited = false;
227 _name = name;
228 }
229 }
230 DEBTRACE(_isEdited << " " << nameEdited);
231 _isEdited = nameEdited;
233}
static std::string filterName(const std::string &name)
virtual bool setName(std::string name)
References _isEdited, YACS::HMI::ItemEditionBase::_name, YACS::HMI::ItemEditionBase::_subject, FormEditItem::_wid, DEBTRACE, filterName(), setEdited(), and YACS::HMI::Subject::setName().
Referenced by ItemEdition(), YACS::HMI::EditionContainer::onApply(), and YACS::HMI::EditionElementaryNode::onApply().
◆ onCancel
void ItemEdition::onCancel ( )
virtualslot
Definition at line 235 of file ItemEdition.cxx.
236{
237 DEBTRACE("onCancel");
238 _wid->le_name->setText(_name.c_str());
239 setEdited(false);
240}
References YACS::HMI::ItemEditionBase::_name, FormEditItem::_wid, DEBTRACE, and setEdited().
Referenced by ItemEdition(), YACS::HMI::EditionContainer::onCancel(), and YACS::HMI::EditionElementaryNode::onCancel().
◆ onModifyName
void ItemEdition::onModifyName ( const QString &  text)
virtualslot
Definition at line 259 of file ItemEdition.cxx.
260{
261 if (_name != text.toStdString()) setEdited(true);
262}
References YACS::HMI::ItemEditionBase::_name, and setEdited().
Referenced by ItemEdition().
◆ select()
void ItemEdition::select ( bool  isSelected)
Reimplemented from YACS::HMI::ItemEditionBase.
Reimplemented in YACS::HMI::EditionInputPort, and YACS::HMI::EditionOutputPort.
Definition at line 198 of file ItemEdition.cxx.
199{
200 DEBTRACE("ItemEdition::select " << isSelected);
201 if (isSelected)
202 {
203 synchronize();
204 QtGuiContext::getQtCurrent()->getStackedWidget()->setCurrentWidget(this);
205 }
206}
virtual void synchronize()
References DEBTRACE, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getStackedWidget(), and synchronize().
◆ setEdited()
void ItemEdition::setEdited ( bool  isEdited)
Definition at line 264 of file ItemEdition.cxx.
265{
266 DEBTRACE("ItemEdition::setEdited " << isEdited);
267 if (isEdited)
268 {
271 if (QtGuiContext::getQtCurrent()->getSubjectProc())
273 }
274 else
275 {
278 if (QtGuiContext::getQtCurrent()->_setOfModifiedSubjects.empty() && QtGuiContext::getQtCurrent()->getSubjectProc())
280 }
281
284 if (schemaItem)
285 {
286 QModelIndex index = schemaItem->modelIndex();
287 model->setData(index, QVariant()); // just to emit dataChanged signal
288 }
289
290 _wid->pb_apply->setEnabled(isEdited);
291 _wid->pb_cancel->setEnabled(isEdited);
292}
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
std::map< YACS::HMI::Subject *, YACS::HMI::SchemaItem * > _mapOfSchemaItem
std::set< YACS::HMI::Subject * > _setOfModifiedSubjects
Definition: SchemaItem.cxx:253
virtual bool setData(const QModelIndex &index, const QVariant &value, int role=Qt::EditRole)
References YACS::HMI::QtGuiContext::_mapOfSchemaItem, YACS::HMI::QtGuiContext::_setOfModifiedSubjects, YACS::HMI::ItemEditionBase::_subject, FormEditItem::_wid, DEBTRACE, YACS::HMI::EDIT, YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::QtGuiContext::getSchemaModel(), YACS::HMI::GuiContext::getSubjectProc(), YACS::HMI::SchemaItem::modelIndex(), YACS::HMI::SchemaModel::setData(), YACS::HMI::Subject::update(), and YACS::HMI::SubjectNode::update().
Referenced by ItemEdition(), onApply(), onCancel(), YACS::HMI::EditionPyFunc::onFuncNameModified(), FormAdvParamContainer::onModified(), FormContainerBase::onModified(), onModifyName(), YACS::HMI::EditionScript::onScriptModified(), and setName().
◆ setName()
void ItemEdition::setName ( std::string  name)
Definition at line 208 of file ItemEdition.cxx.
209{
210 _name = name;
211 setEdited(false);
212}
◆ synchronize()
◆ update()
void ItemEdition::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented in YACS::HMI::EditionBloc, YACS::HMI::EditionComponent, YACS::HMI::EditionContainer, YACS::HMI::EditionDataLink, YACS::HMI::EditionForEachLoop, YACS::HMI::EditionLoop, YACS::HMI::EditionNode, YACS::HMI::EditionOptimizerLoop, YACS::HMI::EditionProc, YACS::HMI::EditionSalomeNode, YACS::HMI::EditionSwitch, and YACS::HMI::EditionWhile.
Definition at line 298 of file ItemEdition.cxx.
299{
300 DEBTRACE("ItemEdition::update " <<eventName(event) << " " << type);
301 if (QtGuiContext::getQtCurrent()->isLoading())
302 {
303 // --- create only EditionProc while loading to store status
304 if (event == NEWROOT)
305 ItemEdition *item = new EditionProc(son,
306 QtGuiContext::getQtCurrent()->getStackedWidget(),
307 son->getName().c_str());
308 return;
309 }
310
311 ItemEdition *item = 0;
312 switch (event)
313 {
314 case NEWROOT:
315 item = new EditionProc(son,
316 QtGuiContext::getQtCurrent()->getStackedWidget(),
317 son->getName().c_str());
318 break;
319 case ADD:
320 switch (type)
321 {
323 item = new EditionProc(son,
324 QtGuiContext::getQtCurrent()->getStackedWidget(),
325 son->getName().c_str());
326 break;
327 case YACS::HMI::BLOC:
328 item = new EditionBloc(son,
329 QtGuiContext::getQtCurrent()->getStackedWidget(),
330 son->getName().c_str());
331 break;
333 item = new EditionForEachLoop(son,
334 QtGuiContext::getQtCurrent()->getStackedWidget(),
335 son->getName().c_str());
336 break;
338 item = new EditionOptimizerLoop(son, QtGuiContext::getQtCurrent()->getStackedWidget(),
339 son->getName().c_str());
340 break;
342 item = new EditionLoop(son,
343 QtGuiContext::getQtCurrent()->getStackedWidget(),
344 son->getName().c_str());
345 break;
347 item = new EditionWhile(son,
348 QtGuiContext::getQtCurrent()->getStackedWidget(),
349 son->getName().c_str());
350 break;
352 item = new EditionSwitch(son,
353 QtGuiContext::getQtCurrent()->getStackedWidget(),
354 son->getName().c_str());
355 break;
357 item = new EditionScript(son,
358 QtGuiContext::getQtCurrent()->getStackedWidget(),
359 son->getName().c_str());
360 break;
362 item = new EditionPyFunc(son,
363 QtGuiContext::getQtCurrent()->getStackedWidget(),
364 son->getName().c_str());
365 break;
368 item = new EditionSalomeNode(son,
369 QtGuiContext::getQtCurrent()->getStackedWidget(),
370 son->getName().c_str());
371 break;
373 item = new EditionPresetNode(son,
374 QtGuiContext::getQtCurrent()->getStackedWidget(),
375 son->getName().c_str());
376 break;
378 item = new EditionOutNode(son,
379 QtGuiContext::getQtCurrent()->getStackedWidget(),
380 son->getName().c_str());
381 break;
383 item = new EditionStudyInNode(son,
384 QtGuiContext::getQtCurrent()->getStackedWidget(),
385 son->getName().c_str());
386 break;
388 item = new EditionStudyOutNode(son,
389 QtGuiContext::getQtCurrent()->getStackedWidget(),
390 son->getName().c_str());
391 break;
394 item = new EditionInputPort(son,
395 QtGuiContext::getQtCurrent()->getStackedWidget(),
396 son->getName().c_str());
397 break;
400 item = new EditionOutputPort(son,
401 QtGuiContext::getQtCurrent()->getStackedWidget(),
402 son->getName().c_str());
403 break;
405 item = new EditionContainer(son,QtGuiContext::getQtCurrent()->getStackedWidget(),son->getName().c_str());
406 break;
408 item = new EditionComponent(son,
409 QtGuiContext::getQtCurrent()->getStackedWidget(),
410 son->getName().c_str());
411
412 break;
414 item = new EditionDataType(son,
415 QtGuiContext::getQtCurrent()->getStackedWidget(),
416 son->getName().c_str());
417 break;
425 item = new ItemEdition(son,
426 QtGuiContext::getQtCurrent()->getStackedWidget(),
427 son->getName().c_str());
428 break;
429 default:
430 DEBTRACE("ItemEdition::update() ADD, type not handled:" << type);
431 }
432 break;
433 case ADDLINK:
434 switch (type)
435 {
437 item = new EditionDataLink(son,
438 QtGuiContext::getQtCurrent()->getStackedWidget(),
439 son->getName().c_str());
440 break;
441 default:
442 DEBTRACE("ItemEdition::update() ADDLINK, type not handled:" << type);
443 }
444 break;
445 case ADDCONTROLLINK:
446 switch (type)
447 {
449 item = new EditionControlLink(son,
450 QtGuiContext::getQtCurrent()->getStackedWidget(),
451 son->getName().c_str());
452 break;
453 default:
454 DEBTRACE("ItemEdition::update() ADDCONTROLLINK, type not handled:" << type);
455 }
456 break;
457 case RENAME:
459 _wid->le_name->setText(_name.c_str());
460 break;
461 case SYNCHRO:
462 synchronize();
463 break;
464// default:
465// DEBTRACE("ItemEdition::update(), event not handled: " << eventName(event));
466 }
467}
ItemEdition(Subject *subject, QWidget *parent=0, const char *name=0)
virtual std::string getName()
@ OUTPUTDATASTREAMPORT
@ INPUTDATASTREAMPORT
References YACS::HMI::ItemEditionBase::_name, YACS::HMI::ItemEditionBase::_subject, FormEditItem::_wid, YACS::HMI::ADD, YACS::HMI::ADDCONTROLLINK, YACS::HMI::ADDLINK, YACS::HMI::BLOC, YACS::HMI::COMPONENT, YACS::HMI::CONTAINER, YACS::HMI::CONTROLLINK, YACS::HMI::CORBANODE, YACS::HMI::CPPNODE, YACS::HMI::DATALINK, YACS::HMI::DATATYPE, DEBTRACE, YACS::HMI::DFTODSFORLOOPNODE, YACS::HMI::DSTODFFORLOOPNODE, YACS::HMI::GuiObserver::eventName(), YACS::HMI::FOREACHLOOP, YACS::HMI::FORLOOP, YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::INPUTDATASTREAMPORT, YACS::HMI::INPUTPORT, ItemEdition(), YACS::HMI::NEWROOT, YACS::HMI::OPTIMIZERLOOP, YACS::HMI::OUTNODE, YACS::HMI::OUTPUTDATASTREAMPORT, YACS::HMI::OUTPUTPORT, YACS::HMI::PRESETNODE, YACS::HMI::PYFUNCNODE, YACS::HMI::PYTHONNODE, YACS::HMI::REFERENCE, YACS::HMI::RENAME, YACS::HMI::SALOMENODE, YACS::HMI::SALOMEPROC, YACS::HMI::SALOMEPYTHONNODE, YACS::HMI::SPLITTERNODE, YACS::HMI::STUDYINNODE, YACS::HMI::STUDYOUTNODE, YACS::HMI::SWITCH, YACS::HMI::SYNCHRO, synchronize(), YACS::HMI::WHILELOOP, and YACS::HMI::XMLNODE.
Referenced by gui.graph.MyCanvas::customEvent(), YACS::HMI::EditionInputPort::select(), YACS::HMI::EditionOutputPort::select(), YACS::HMI::SchemaItem::select(), YACS::HMI::EditionContainer::update(), and YACS::HMI::EditionNode::update().
◆ _haveScript
bool YACS::HMI::ItemEdition::_haveScript
◆ _isEdited
