YACS::HMI::EditionSalomeNode Class Reference
#include <EditionSalomeNode.hxx>
Inheritance diagram for YACS::HMI::EditionSalomeNode:
Collaboration diagram for YACS::HMI::EditionSalomeNode:
Public Slots
virtual void fillComponentPanel ()
virtual void fillContainerPanel ()
virtual void changeInstance (int index)
virtual void changeContainer (int index)
virtual void changeHost (int index)
virtual void onApply ()
virtual void onCancel ()
- Public Slots inherited from YACS::HMI::EditionElementaryNode
virtual void onPortIndexChanged (int index)
virtual void onCommitData (QWidget *editor)
 EditionSalomeNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionSalomeNode ()
virtual void synchronize ()
- Public Member Functions inherited from YACS::HMI::EditionElementaryNode
 EditionElementaryNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionElementaryNode ()
virtual void setEditablePorts (bool isEditable)
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
PropertyEditor * _propeditor
FormComponent * _wComponent
FormContainerDecorator * _wContainer
QHBoxLayout * _hbl_method
QLabel * _la_method
QLineEdit * _le_method
YACS::ENGINE::ServiceNode * _servNode
- Protected Attributes inherited from YACS::HMI::EditionElementaryNode
SubjectElementaryNode * _subElemNode
QTabWidget * _twPorts
TablePortsEdition * _tvInPorts
TablePortsEdition * _tvOutPorts
ValueDelegate * _valueDelegate
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
- Protected Member Functions inherited from YACS::HMI::EditionElementaryNode
virtual bool hasInputPorts ()
virtual bool hasOutputPorts ()
virtual void createTablePorts (QLayout *layout)
Definition at line 47 of file EditionSalomeNode.hxx.
◆ EditionSalomeNode()
EditionSalomeNode::EditionSalomeNode ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 43 of file EditionSalomeNode.cxx.
46 : EditionElementaryNode(subject, parent, name)
47{
48 // SubjectServiceNode *ssn = dynamic_cast<SubjectServiceNode*>(_subject);
49 // YASSERT(ssn);
52 // --- create property editor panel
54 _wid->gridLayout1->addWidget(_propeditor);
55
56 // --- create container and component panels
57
59 _wid->gridLayout1->addWidget(_wContainer);
60
61 connect(_wContainer, SIGNAL(resourceMousePressed()), this, SLOT(fillContainerPanel()));
62 connect(_wContainer, SIGNAL(resourceActivated(int)), this, SLOT(changeHost(int)));
63 connect(_wContainer, SIGNAL(containerToggled(bool)), this, SLOT(fillContainerPanel()));
64 // --- to update display of current selection
65
66 _wComponent = new FormComponent(this);
67 _wid->gridLayout1->addWidget(_wComponent);
68
69 connect(_wComponent->cb_instance, SIGNAL(mousePressed()),
70 this, SLOT(fillComponentPanel()));
71 connect(_wComponent->cb_instance, SIGNAL(activated(int)),
72 this, SLOT(changeInstance(int)));
73
74 connect(_wComponent->cb_container, SIGNAL(mousePressed()),
75 this, SLOT(fillContainerPanel()));
76 connect(_wComponent->cb_container, SIGNAL(activated(int)),
77 this, SLOT(changeContainer(int)));
78
79 connect(_wComponent->tb_component, SIGNAL(toggled(bool)),
80 this, SLOT(fillComponentPanel())); // --- to update display of current selection
81 connect(_wComponent->tb_component, SIGNAL(toggled(bool)),
82 this, SLOT(fillContainerPanel())); // --- to update display of current selection
83
84 // --- method
85
86 _hbl_method = new QHBoxLayout();
87 _la_method = new QLabel(this);
88 _hbl_method->addWidget(_la_method);
89 _le_method = new QLineEdit(this);
90 _hbl_method->addWidget(_le_method);
91 _wid->gridLayout1->addLayout(_hbl_method, _wid->gridLayout1->rowCount(), 0, 1, 1);
92 _la_method->setText("Method:");
93
94 _le_method->setText((_servNode->getMethod()).c_str());
95 _le_method->setReadOnly(true);
96
97 // --- fill component panel
98
100
101 createTablePorts(_wid->gridLayout1);
102}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
WidEditItem * _wid
virtual std::string getMethod()
Definition: ServiceNode.hxx:51
virtual Container * getContainer()
Return the associated container.
virtual void createTablePorts(QLayout *layout)
EditionElementaryNode(Subject *subject, QWidget *parent=0, const char *name=0)
virtual void changeInstance(int index)
virtual void changeContainer(int index)
virtual void changeHost(int index)
A class to edit properties of a subject.
References _hbl_method, _la_method, _le_method, _propeditor, _servNode, YACS::HMI::EditionElementaryNode::_subElemNode, YACS::HMI::ItemEditionBase::_subject, _wComponent, _wContainer, FormEditItem::_wid, changeContainer(), changeHost(), changeInstance(), YACS::HMI::EditionElementaryNode::createTablePorts(), fillComponentPanel(), fillContainerPanel(), YACS::ENGINE::ServiceNode::getContainer(), YACS::ENGINE::ServiceNode::getMethod(), YACS::HMI::SubjectNode::getNode(), and YASSERT.
◆ ~EditionSalomeNode()
EditionSalomeNode::~EditionSalomeNode ( )
Definition at line 104 of file EditionSalomeNode.cxx.
105{
106}
◆ changeContainer
void EditionSalomeNode::changeContainer ( int  index)
virtualslot
Definition at line 218 of file EditionSalomeNode.cxx.
219{
220 string contName = _wComponent->cb_container->itemText(index).toStdString();
221 DEBTRACE(contName);
223 Container *oldContainer = compoInst->getContainer();
224
225 Container *newContainer = 0;
227 if (proc->containerMap.count(contName))
228 newContainer = proc->containerMap[contName];
229 if (!newContainer)
230 {
231 DEBTRACE("-------------> not found : " << contName);
232 return;
233 }
234 YASSERT(GuiContext::getCurrent()->_mapOfSubjectContainer.count(newContainer));
235 SubjectContainerBase *scnt(GuiContext::getCurrent()->_mapOfSubjectContainer[newContainer]);
236
237 SubjectServiceNode *ssn(dynamic_cast<SubjectServiceNode*>(_subject));
238 SubjectComponent *sco(dynamic_cast<SubjectComponent*>(ssn->getSubjectReference()->getReference()));
239 YASSERT(sco);
240 sco->associateToContainer(scnt);
241}
Definition: Proc.hxx:44
Definition: Proc.hxx:91
virtual ComponentInstance * getComponent()
Return the associated component instance.
Definition: guiContext.hxx:67
Definition: guiContext.hxx:50
References _servNode, YACS::HMI::ItemEditionBase::_subject, _wComponent, YACS::HMI::SubjectComponent::associateToContainer(), YACS::ENGINE::Proc::containerMap, DEBTRACE, YACS::ENGINE::ServiceNode::getComponent(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::SubjectReference::getReference(), YACS::HMI::SubjectServiceNode::getSubjectReference(), and YASSERT.
Referenced by EditionSalomeNode().
◆ changeHost
void EditionSalomeNode::changeHost ( int  index)
virtualslot
Definition at line 243 of file EditionSalomeNode.cxx.
244{
245 string hostName = _wContainer->getHostName(index);
246 DEBTRACE(hostName);
247}
std::string getHostName(int index) const
References _wContainer, DEBTRACE, and FormContainerDecorator::getHostName().
◆ changeInstance
void EditionSalomeNode::changeInstance ( int  index)
virtualslot
Definition at line 199 of file EditionSalomeNode.cxx.
200{
201 string instName = _wComponent->cb_instance->itemText(index).toStdString();
203 ComponentInstance *newCompoInst = 0;
204 ComponentInstance *oldCompoInst = _servNode->getComponent();
205 if (proc->componentInstanceMap.count(instName))
206 newCompoInst = proc->componentInstanceMap[instName];
207 else DEBTRACE("-------------> not found : " << instName);
208
209 if (newCompoInst && (newCompoInst != oldCompoInst))
210 {
211 YASSERT(GuiContext::getCurrent()->_mapOfSubjectComponent.count(newCompoInst));
212 SubjectServiceNode *ssn = dynamic_cast<SubjectServiceNode*>(_subject);
214 Message mess;
215 }
216}
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
std::map< YACS::ENGINE::ComponentInstance *, YACS::HMI::SubjectComponent * > _mapOfSubjectComponent
Definition: guiContext.hxx:74
virtual bool associateToComponent(SubjectComponent *subcomp)
References YACS::HMI::GuiContext::_mapOfSubjectComponent, _servNode, YACS::HMI::ItemEditionBase::_subject, _wComponent, YACS::HMI::SubjectServiceNode::associateToComponent(), YACS::ENGINE::Proc::componentInstanceMap, DEBTRACE, YACS::ENGINE::ServiceNode::getComponent(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), and YASSERT.
◆ fillComponentPanel
void EditionSalomeNode::fillComponentPanel ( )
virtualslot
must be updated when associate service to component instance, or when the list of available component instances changes.
Definition at line 150 of file EditionSalomeNode.cxx.
151{
153 if (compoInst)
154 {
155 _wComponent->le_name ->setText(compoInst->getCompoName().c_str());
157
158 _wComponent->cb_instance->clear();
159 map<string,ComponentInstance*>::const_iterator it = proc->componentInstanceMap.begin();
160 for(; it != proc->componentInstanceMap.end(); ++it)
161 {
162 ComponentInstance *inst=(*it).second;
163 QString compoName = inst->getCompoName().c_str();
164 if (! QString::compare(compoInst->getCompoName().c_str(), compoName)) // if same component name
165 //instanceMap[inst->getInstanceName()] = inst;
166 _wComponent->cb_instance->addItem( QString(inst->getInstanceName().c_str()));
167 }
168
169 int index = _wComponent->cb_instance->findText(compoInst->getInstanceName().c_str());
170 //DEBTRACE("~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ " << index);
171 _wComponent->cb_instance->setCurrentIndex(index);
172 }
173}
const std::string & getInstanceName() const
References _servNode, _wComponent, YACS::ENGINE::Proc::componentInstanceMap, YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::ServiceNode::getComponent(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComponentInstance::getInstanceName(), and YACS::HMI::GuiContext::getProc().
Referenced by EditionSalomeNode(), synchronize(), and update().
◆ fillContainerPanel
void EditionSalomeNode::fillContainerPanel ( )
virtualslot
Definition at line 175 of file EditionSalomeNode.cxx.
176{
177 DEBTRACE("EditionSalomeNode::fillContainerPanel");
179 if (compoInst)
180 {
182
183 _wComponent->cb_container->clear();
184 map<string,Container*>::const_iterator it = proc->containerMap.begin();
185 for(; it != proc->containerMap.end(); ++it)
186 _wComponent->cb_container->addItem( QString((*it).first.c_str()));
187
188 Container * cont = compoInst->getContainer();
189 if (cont)
190 {
191 int index = _wComponent->cb_container->findText(cont->getName().c_str());
192 _wComponent->cb_container->setCurrentIndex(index);
193 _wContainer->FillPanel(cont);
194 }
195 }
196}
void FillPanel(YACS::ENGINE::Container *container)
virtual std::string getName() const
Definition: Container.hxx:81
References _servNode, _wComponent, _wContainer, YACS::ENGINE::Proc::containerMap, DEBTRACE, FormContainerDecorator::FillPanel(), YACS::ENGINE::ServiceNode::getComponent(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Container::getName(), and YACS::HMI::GuiContext::getProc().
◆ onApply
void EditionSalomeNode::onApply ( )
virtualslot
Definition at line 249 of file EditionSalomeNode.cxx.
250{
251 DEBTRACE("EditionSalomeNode::onApply");
252 bool edited = true;
253 if (_wContainer->onApply())
254 edited = false;
255 _isEdited = _isEdited || edited;
257}
References YACS::HMI::ItemEdition::_isEdited, _wContainer, DEBTRACE, YACS::HMI::EditionElementaryNode::onApply(), and FormContainerDecorator::onApply().
◆ onCancel
void EditionSalomeNode::onCancel ( )
virtualslot
◆ synchronize()
void EditionSalomeNode::synchronize ( )
◆ update()
void EditionSalomeNode::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionNode.
Definition at line 108 of file EditionSalomeNode.cxx.
109{
110 DEBTRACE("EditionSalomeNode::update ");
111 EditionElementaryNode::update(event, type, son);
112 SubjectReference* subref= 0;
113 switch (event)
114 {
115 case ADDREF:
116 DEBTRACE("ADDREF");
117 subref = dynamic_cast<SubjectReference*>(son);
118 YASSERT(subref);
119 DEBTRACE(subref->getName() << " " << subref->getReference()->getName());
122 break;
123
124 case ASSOCIATE:
125 DEBTRACE("ASSOCIATE");
127 break;
128
129 case SETVALUE:
131 break;
132
133 default:
134 ;
135 }
136}
Definition: EditionNode.cxx:64
void update()
Update the property items with their values in the subject.
virtual Subject * getReference() const
References _propeditor, YACS::HMI::ADDREF, YACS::HMI::ASSOCIATE, DEBTRACE, fillComponentPanel(), fillContainerPanel(), YACS::HMI::Subject::getName(), YACS::HMI::SubjectReference::getName(), YACS::HMI::SubjectReference::getReference(), YACS::HMI::SETVALUE, YACS::HMI::PropertyEditor::update(), YACS::HMI::EditionNode::update(), and YASSERT.
Referenced by gui.graph.MyCanvas::customEvent().
◆ _hbl_method
QHBoxLayout* YACS::HMI::EditionSalomeNode::_hbl_method
Definition at line 72 of file EditionSalomeNode.hxx.
◆ _la_method
QLabel* YACS::HMI::EditionSalomeNode::_la_method
Definition at line 73 of file EditionSalomeNode.hxx.
◆ _le_method
QLineEdit* YACS::HMI::EditionSalomeNode::_le_method
Definition at line 74 of file EditionSalomeNode.hxx.
◆ _propeditor
PropertyEditor* YACS::HMI::EditionSalomeNode::_propeditor
Definition at line 69 of file EditionSalomeNode.hxx.
Referenced by EditionSalomeNode(), and update().
◆ _servNode
YACS::ENGINE::ServiceNode* YACS::HMI::EditionSalomeNode::_servNode
◆ _wComponent
FormComponent* YACS::HMI::EditionSalomeNode::_wComponent
◆ _wContainer
FormContainerDecorator* YACS::HMI::EditionSalomeNode::_wContainer
