YACS::HMI::EditionNode Class Reference
#include <EditionNode.hxx>
Inheritance diagram for YACS::HMI::EditionNode:
Collaboration diagram for YACS::HMI::EditionNode:
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual void synchronize ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
virtual void onApply ()
virtual void onCancel ()
static void setEventMap ()
Definition at line 33 of file EditionNode.hxx.
◆ EditionNode()
EditionNode::EditionNode ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 35 of file EditionNode.cxx.
38 : ItemEdition(subject, parent, name)
39{
40 DEBTRACE("EditionNode::EditionNode");
41 if (QtGuiContext::getQtCurrent()->isEdition())
42 _wid->le_name->setReadOnly(false);
43
44 _subjectNode = dynamic_cast<SubjectNode*>(_subject);
46
47 _le_fullName = 0;
48 if (!dynamic_cast<SubjectProc*>(_subject))
49 {
50 _le_fullName = new QLineEdit(this);
51 _le_fullName->setToolTip("Full name of the node in schema");
52 _le_fullName->setReadOnly(true);
53 _wid->gridLayout1->addWidget(_le_fullName);
54
56 _le_fullName->setText((proc->getChildName(_subjectNode->getNode())).c_str());
57 }
58}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
WidEditItem * _wid
Definition: Proc.hxx:44
Definition: EditionNode.hxx:47
Definition: EditionNode.hxx:48
Definition: guiContext.hxx:50
ItemEdition(Subject *subject, QWidget *parent=0, const char *name=0)
References _le_fullName, YACS::HMI::ItemEditionBase::_subject, _subjectNode, FormEditItem::_wid, DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::GuiContext::getProc(), YACS::HMI::QtGuiContext::getQtCurrent(), and YASSERT.
◆ ~EditionNode()
EditionNode::~EditionNode ( )
Definition at line 60 of file EditionNode.cxx.
61{
62}
◆ update()
void EditionNode::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::ItemEdition.
Reimplemented in YACS::HMI::EditionBloc, YACS::HMI::EditionForEachLoop, YACS::HMI::EditionLoop, YACS::HMI::EditionOptimizerLoop, YACS::HMI::EditionProc, YACS::HMI::EditionSalomeNode, YACS::HMI::EditionSwitch, and YACS::HMI::EditionWhile.
Definition at line 64 of file EditionNode.cxx.
65{
66 DEBTRACE("EditionNode::update ");
67 ItemEdition::update(event, type, son);
69 switch (event)
70 {
71 case RENAME:
72 if (_le_fullName)
73 _le_fullName->setText((proc->getChildName(_subjectNode->getNode())).c_str());
74 break;
75 default:
76 ;
77 }
78}
References _le_fullName, _subjectNode, DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::GuiContext::getProc(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::RENAME, and YACS::HMI::ItemEdition::update().
Referenced by gui.graph.MyCanvas::customEvent(), YACS::HMI::EditionForEachLoop::update(), YACS::HMI::EditionLoop::update(), YACS::HMI::EditionOptimizerLoop::update(), YACS::HMI::EditionSalomeNode::update(), YACS::HMI::EditionScript::update(), and YACS::HMI::EditionWhile::update().
◆ _le_fullName
QLineEdit* YACS::HMI::EditionNode::_le_fullName
Definition at line 47 of file EditionNode.hxx.
Referenced by EditionNode(), and update().
◆ _subjectNode
