YACS::HMI::EditionProc Class Reference
#include <EditionProc.hxx>
Inheritance diagram for YACS::HMI::EditionProc:
Collaboration diagram for YACS::HMI::EditionProc:
Public Slots
virtual void onLevelChange (int index)
virtual void onApply ()
virtual void onCancel ()
 EditionProc (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionProc ()
virtual void synchronize ()
- Public Member Functions inherited from YACS::HMI::EditionBloc
 EditionBloc (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionBloc ()
- Public Member Functions inherited from YACS::HMI::EditionNode
 EditionNode (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionNode ()
virtual ~ItemEdition ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
QTextEdit * _statusLog
std::string _errorLog
std::string _modifLog
- Protected Attributes inherited from YACS::HMI::EditionBloc
PropertyEditor * _propeditor
- Protected Attributes inherited from YACS::HMI::EditionNode
QLineEdit * _le_fullName
SubjectNode * _subjectNode
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 33 of file EditionProc.hxx.
◆ EditionProc()
EditionProc::EditionProc ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 38 of file EditionProc.cxx.
41 : EditionBloc(subject, parent, name)
42{
43 DEBTRACE("EditionProc::EditionProc");
44 _statusLog = new QTextEdit(this);
45 _wid->gridLayout1->addWidget(_statusLog);
46 _errorLog = "";
47 _modifLog = "";
48
49 if (!QtGuiContext::getQtCurrent()->isEdition())
50 {
51 QHBoxLayout* hbox = new QHBoxLayout();
52 QLabel* la = new QLabel("Shutdown level:",this);
53 QComboBox* cb = new QComboBox(this);
54 cb->addItem("0",0 );
55 cb->addItem("1",1 );
56 cb->addItem("2",2 );
57 cb->addItem("3",3 );
58 int level=1;
59 if (QtGuiContext::getQtCurrent()->getGuiExecutor())
61 DEBTRACE(level);
62 cb->setCurrentIndex(level);
63 connect(cb, SIGNAL(currentIndexChanged(int)), this, SLOT(onLevelChange(int)));
64 hbox->addWidget(la);
65 hbox->addWidget(cb);
66 _wid->gridLayout1->addLayout(hbox,4,0);
67 }
68}
WidEditItem * _wid
EditionBloc(Subject *subject, QWidget *parent=0, const char *name=0)
Definition: EditionBloc.cxx:31
virtual void onLevelChange(int index)
YACS::HMI::GuiExecutor * getGuiExecutor()
References _errorLog, _modifLog, _statusLog, FormEditItem::_wid, DEBTRACE, YACS::HMI::QtGuiContext::getGuiExecutor(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::GuiExecutor::getShutdownLevel(), and onLevelChange().
◆ ~EditionProc()
EditionProc::~EditionProc ( )
Definition at line 70 of file EditionProc.cxx.
71{
72 DEBTRACE("EditionProc::~EditionProc");
73}
References DEBTRACE.
◆ onLevelChange
void EditionProc::onLevelChange ( int  index)
virtualslot
Definition at line 155 of file EditionProc.cxx.
156{
157 DEBTRACE("EditionProc::onLevelChange " << index);
158 if (QtGuiContext::getQtCurrent()->getGuiExecutor())
160}
void setShutdownLevel(int level)
Definition: GuiExecutor.hxx:92
References DEBTRACE, YACS::HMI::QtGuiContext::getGuiExecutor(), YACS::HMI::QtGuiContext::getQtCurrent(), and YACS::HMI::GuiExecutor::setShutdownLevel().
Referenced by EditionProc().
◆ synchronize()
void EditionProc::synchronize ( )
used in derived nodes for synchronisation with schema model.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 106 of file EditionProc.cxx.
107{
108 DEBTRACE("EditionProc::synchronize");
110 Logger* logger = 0;
111 string statusLog = "";
112
113 if (!QtGuiContext::getQtCurrent()->isEdition())
114 return;
115 if (!proc->isValid())
116 {
117 _errorLog = "--- YACS schema is not valid ---\n\n";
118 _errorLog += proc->getErrorReport();
120 }
121 else
122 {
123 // --- Check consistency
124 LinkInfo info(LinkInfo::ALL_DONT_STOP);
125 _errorLog="";
126 try
127 {
128 proc->checkConsistency(info);
129 if (info.areWarningsOrErrors())
130 _errorLog += info.getGlobalRepr();
131 else
132 {
133 _errorLog += "--- No Validity Errors ---\n";
134 _errorLog += "--- No Consistency Errors ---\n";
135 }
136 }
137 catch (Exception &ex)
138 {
139 _errorLog = "--- YACS schema has consistency errors ---\n\n";
140 _errorLog += ex.what();
141 }
143 }
144 // --- Add initial logger info
145 logger = proc->getLogger("parser");
146 if (!logger->isEmpty())
147 {
148 _errorLog += "--- Original file import log ---\n";
149 _errorLog += logger->getStr();
150 }
151 statusLog = _modifLog + _errorLog;
152 _statusLog->setText(statusLog.c_str());
153}
virtual std::string getErrorReport()
returns a string that contains an error report if the node is in error
void checkConsistency(LinkInfo &info) const
Class that deal with list of semantics links for high level analysis.
Definition: LinkInfo.hxx:83
Class for logging error messages.
Definition: Logger.hxx:38
virtual bool isEmpty()
Definition: Logger.cxx:96
virtual std::string getStr()
Definition: Logger.cxx:85
virtual int isValid()
indicates if the node is valid (returns 1) or not (returns 0)
Definition: Node.cxx:730
Definition: Proc.hxx:44
virtual Logger * getLogger(const std::string &name)
Definition: Proc.cxx:431
Definition: guiContext.hxx:50
References _errorLog, _modifLog, _statusLog, YACS::ENGINE::LinkInfo::areWarningsOrErrors(), YACS::ENGINE::ComposedNode::checkConsistency(), DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getErrorReport(), YACS::ENGINE::LinkInfo::getGlobalRepr(), YACS::ENGINE::Proc::getLogger(), YACS::HMI::GuiContext::getProc(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::ENGINE::Logger::getStr(), YACS::ENGINE::Logger::isEmpty(), and YACS::ENGINE::Node::isValid().
Referenced by update().
◆ update()
void EditionProc::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::EditionBloc.
Definition at line 75 of file EditionProc.cxx.
76{
77 DEBTRACE("EditionProc::update " << GuiObserver::eventName(event));
78 EditionBloc::update(event, type, son);
79 string statusLog = "";
80 switch (event)
81 {
82 case EDIT:
83 if (QtGuiContext::getQtCurrent()->_setOfModifiedSubjects.empty())
84 _modifLog = "";
85 else
86 _modifLog = "--- some elements are modified and not taken into account. Confirmation or annulation required ---\n";
87 case UPDATE:
89 break;
90 case UPDATEPROGRESS:
91 {
92 if(type != YACS::FINISHED)break;
93 if (!QtGuiContext::getQtCurrent()) break;
94 if (!QtGuiContext::getQtCurrent()->getGuiExecutor()) break;
97 _statusLog->setText(QString::fromStdString(_errorLog));
98 break;
99 }
100 default:
101 ;
102 }
103
104}
Definition: EditionBloc.cxx:44
virtual void synchronize()
std::string getErrorReport(YACS::ENGINE::Node *node)
@ FINISHED
Definition: define.hxx:70
References _errorLog, _modifLog, _statusLog, DEBTRACE, YACS::HMI::EDIT, YACS::HMI::GuiObserver::eventName(), YACS::FINISHED, YACS::HMI::GuiExecutor::getErrorReport(), YACS::HMI::QtGuiContext::getGuiExecutor(), YACS::HMI::GuiContext::getProc(), YACS::HMI::QtGuiContext::getQtCurrent(), synchronize(), YACS::HMI::EditionBloc::update(), YACS::HMI::UPDATE, and YACS::HMI::UPDATEPROGRESS.
Referenced by gui.graph.MyCanvas::customEvent().
◆ _errorLog
std::string YACS::HMI::EditionProc::_errorLog
Definition at line 52 of file EditionProc.hxx.
Referenced by EditionProc(), synchronize(), and update().
◆ _modifLog
std::string YACS::HMI::EditionProc::_modifLog
Definition at line 53 of file EditionProc.hxx.
◆ _statusLog
QTextEdit* YACS::HMI::EditionProc::_statusLog
Definition at line 51 of file EditionProc.hxx.
