YACS::HMI::ItemEditionBase Class Reference
#include <ItemEdition.hxx>
Inheritance diagram for YACS::HMI::ItemEditionBase:
Collaboration diagram for YACS::HMI::ItemEditionBase:
virtual ~ItemEditionBase ()
virtual void synchronize ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 36 of file ItemEdition.hxx.
◆ ItemEditionBase()
ItemEditionBase::ItemEditionBase ( Subject *  subject)
get name and strings for type of item and category
Definition at line 68 of file ItemEdition.cxx.
69 : GuiObserver(), _subject(subject)
70{
71 _subject->attach(this);
72 _stackId = -1;
74 _type = "Unknown";
75 _category = "Unknown";
77 if (SubjectNode * sub = dynamic_cast<SubjectNode*>(_subject))
78 {
79 _category = "Node";
80 _type = invoc->getTypeName(invoc->getTypeOfNode(sub->getNode()));
81 }
82 else if (SubjectDataPort * sub = dynamic_cast<SubjectDataPort*>(_subject))
83 {
84 _category = "Port";
85 _type = invoc->getTypeName(invoc->getTypeOfPort(sub->getPort()));
86 }
87 else if (SubjectLink * sub = dynamic_cast<SubjectLink*>(_subject))
88 {
89 _category = "Link";
90 _type = "Link";
91 }
92 else if (SubjectControlLink * sub = dynamic_cast<SubjectControlLink*>(_subject))
93 {
94 _category = "ControlLink";
95 _type = "Control Link";
96 }
97 else if (SubjectDataType * sub = dynamic_cast<SubjectDataType*>(_subject))
98 {
99 _category = "Data";
100 switch (sub->getTypeCode()->kind())
101 {
102 case YACS::ENGINE::Double: _type = "Double"; break;
103 case YACS::ENGINE::Int: _type = "Int"; break;
104 case YACS::ENGINE::String: _type = "String"; break;
105 case YACS::ENGINE::Bool: _type = "Bool"; break;
106 case YACS::ENGINE::Objref: _type = "Objref"; break;
107 case YACS::ENGINE::Sequence: _type = "Sequence"; break;
108 case YACS::ENGINE::Array: _type = "Array"; break;
109 case YACS::ENGINE::Struct: _type = "Struct"; break;
110 default: _type = "None or Unknown";
111 }
112 }
113 else if (SubjectComponent * sub = dynamic_cast<SubjectComponent*>(_subject))
114 {
115 _category = "Component";
116 _type = "Salome Component";
117 }
118 else if (SubjectContainerBase * sub = dynamic_cast<SubjectContainerBase*>(_subject))
119 {
120 _category = "Container";
121 _type = sub->getLabelForHuman();
122 }
123}
Definition: guiContext.hxx:51
static std::string getTypeName(TypeOfElem type)
static TypeOfElem getTypeOfPort(YACS::ENGINE::DataPort *port)
static TypeOfElem getTypeOfNode(YACS::ENGINE::Node *node)
virtual std::string getName()
virtual void attach(GuiObserver *obs)
References _category, _name, _stackId, _subject, _type, YACS::ENGINE::Array, YACS::HMI::Subject::attach(), YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::HMI::GuiContext::getInvoc(), YACS::HMI::Subject::getName(), YACS::HMI::QtGuiContext::getQtCurrent(), YACS::HMI::ProcInvoc::getTypeName(), YACS::HMI::ProcInvoc::getTypeOfNode(), YACS::HMI::ProcInvoc::getTypeOfPort(), YACS::ENGINE::Int, YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, and YACS::ENGINE::Struct.
◆ ~ItemEditionBase()
ItemEditionBase::~ItemEditionBase ( )
Definition at line 125 of file ItemEdition.cxx.
126{
127}
◆ getSubject()
Subject * ItemEditionBase::getSubject ( )
Definition at line 142 of file ItemEdition.cxx.
143{
144 return _subject;
145}
References _subject.
◆ select()
void ItemEditionBase::select ( bool  isSelected)
Reimplemented from YACS::HMI::GuiObserver.
Reimplemented in YACS::HMI::EditionInputPort, YACS::HMI::EditionOutputPort, and YACS::HMI::ItemEdition.
Definition at line 129 of file ItemEdition.cxx.
130{
131 DEBTRACE("ItemEditionBase::select " << isSelected);
132}
References DEBTRACE.
◆ synchronize()
◆ update()
◆ _category
std::string YACS::HMI::ItemEditionBase::_category
Definition at line 50 of file ItemEdition.hxx.
Referenced by ItemEditionBase().
◆ _name
◆ _stackId
int YACS::HMI::ItemEditionBase::_stackId
Definition at line 47 of file ItemEdition.hxx.
Referenced by YACS::HMI::ItemEdition::ItemEdition(), and ItemEditionBase().
◆ _subject
Subject* YACS::HMI::ItemEditionBase::_subject
Definition at line 46 of file ItemEdition.hxx.
Referenced by YACS::HMI::EditionComponent::changeContainer(), YACS::HMI::EditionSalomeNode::changeContainer(), YACS::HMI::EditionSalomeNode::changeInstance(), YACS::HMI::EditionBloc::EditionBloc(), YACS::HMI::EditionComponent::EditionComponent(), YACS::HMI::EditionDataLink::EditionDataLink(), YACS::HMI::EditionElementaryNode::EditionElementaryNode(), YACS::HMI::EditionInputPort::EditionInputPort(), YACS::HMI::EditionNode::EditionNode(), YACS::HMI::EditionOutputPort::EditionOutputPort(), YACS::HMI::EditionPyFunc::EditionPyFunc(), YACS::HMI::EditionSalomeNode::EditionSalomeNode(), YACS::HMI::EditionScript::EditionScript(), YACS::HMI::EditionComponent::fillContainerPanel(), YACS::HMI::EditionContainer::getContainer(), getSubject(), YACS::HMI::ItemEdition::ItemEdition(), ItemEditionBase(), YACS::HMI::ItemEdition::onApply(), YACS::HMI::EditionWhile::onConditionEdited(), YACS::HMI::EditionSwitch::onModifySelect(), YACS::HMI::EditionForEachLoop::onNbBranchesEdited(), YACS::HMI::EditionOptimizerLoop::onNbBranchesEdited(), YACS::HMI::EditionLoop::onNbStepsEdited(), YACS::HMI::EditionInputPort::select(), YACS::HMI::EditionOutputPort::select(), YACS::HMI::ItemEdition::setEdited(), YACS::HMI::EditionElementaryNode::synchronize(), YACS::HMI::EditionForEachLoop::synchronize(), YACS::HMI::EditionLoop::synchronize(), YACS::HMI::EditionOptimizerLoop::synchronize(), YACS::HMI::EditionSwitch::synchronize(), YACS::HMI::EditionWhile::synchronize(), YACS::HMI::EditionForEachLoop::update(), YACS::HMI::EditionLoop::update(), YACS::HMI::EditionOptimizerLoop::update(), YACS::HMI::EditionSwitch::update(), YACS::HMI::EditionWhile::update(), YACS::HMI::ItemEdition::update(), and YACS::HMI::ItemEdition::~ItemEdition().
◆ _type
std::string YACS::HMI::ItemEditionBase::_type
Definition at line 49 of file ItemEdition.hxx.
