YACS::HMI::EditionComponent Class Reference
#include <EditionComponent.hxx>
Inheritance diagram for YACS::HMI::EditionComponent:
Collaboration diagram for YACS::HMI::EditionComponent:
Public Slots
virtual void fillContainerPanel ()
virtual void changeContainer (int index)
virtual void onApply ()
virtual void onCancel ()
 EditionComponent (Subject *subject, QWidget *parent=0, const char *name=0)
virtual ~EditionComponent ()
virtual ~ItemEdition ()
virtual void synchronize ()
virtual ~FormEditItem ()
virtual ~ItemEditionBase ()
 GuiObserver ()
virtual ~GuiObserver ()
int getNbSubjects ()
bool isDestructible ()
PropertyEditor * _propeditor
ComboBox * _cb_container
bool _isEdited
bool _haveScript
WidEditItem * _wid
Subject * _subject
int _stackId
std::string _type
std::string _category
bool _destructible
static void setEventMap ()
Definition at line 32 of file EditionComponent.hxx.
◆ EditionComponent()
EditionComponent::EditionComponent ( Subject *  subject,
QWidget *  parent = 0,
const char *  name = 0
Definition at line 36 of file EditionComponent.cxx.
39 : ItemEdition(subject, parent, name)
40{
41
42 QHBoxLayout* hboxLayout = new QHBoxLayout();
43 hboxLayout->setSizeConstraint(QLayout::SetDefaultConstraint);
44 QLabel* la_container = new QLabel("Container:");
45 hboxLayout->addWidget(la_container);
46 _cb_container = new ComboBox();
47 hboxLayout->addWidget(_cb_container);
48 _wid->gridLayout1->addLayout(hboxLayout, 3, 0, 1, 1);
50 _wid->gridLayout1->addWidget(_propeditor);
51
52 connect(_cb_container, SIGNAL(mousePressed()),
53 this, SLOT(fillContainerPanel()));
54 connect(_cb_container, SIGNAL(activated(int)),
55 this, SLOT(changeContainer(int)));
56
58}
WidEditItem * _wid
virtual void changeContainer(int index)
ItemEdition(Subject *subject, QWidget *parent=0, const char *name=0)
A class to edit properties of a subject.
References _cb_container, _propeditor, YACS::HMI::ItemEditionBase::_subject, FormEditItem::_wid, changeContainer(), and fillContainerPanel().
◆ ~EditionComponent()
EditionComponent::~EditionComponent ( )
Definition at line 60 of file EditionComponent.cxx.
61{
62}
◆ changeContainer
void EditionComponent::changeContainer ( int  index)
virtualslot
Definition at line 92 of file EditionComponent.cxx.
93{
94 string contName = _cb_container->itemText(index).toStdString();
95 DEBTRACE(contName);
96 SubjectComponent *scompo=dynamic_cast<SubjectComponent*>(_subject);
97 ComponentInstance *compoInst = scompo->getComponent();
98
100
101 if (proc->containerMap.count(contName)==0)
102 {
103 DEBTRACE("-------------> not found : " << contName);
104 return;
105 }
106 Container *newContainer =proc->containerMap[contName];
108 scompo->associateToContainer(scnt);
109 scompo->select(true);
110}
Definition: Proc.hxx:44
Definition: Proc.hxx:91
Definition: guiContext.hxx:67
std::map< YACS::ENGINE::Container *, YACS::HMI::SubjectContainerBase * > _mapOfSubjectContainer
Definition: guiContext.hxx:75
Definition: guiContext.hxx:50
YACS::ENGINE::ComponentInstance * getComponent() const
virtual bool associateToContainer(SubjectContainerBase *subcont)
virtual void select(bool isSelected)
References _cb_container, YACS::HMI::GuiContext::_mapOfSubjectContainer, YACS::HMI::ItemEditionBase::_subject, YACS::HMI::SubjectComponent::associateToContainer(), YACS::ENGINE::Proc::containerMap, DEBTRACE, YACS::HMI::SubjectComponent::getComponent(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), and YACS::HMI::Subject::select().
Referenced by EditionComponent().
◆ fillContainerPanel
void EditionComponent::fillContainerPanel ( )
virtualslot
Definition at line 74 of file EditionComponent.cxx.
75{
77 _cb_container->clear();
78 std::map<string,Container*>::const_iterator it = proc->containerMap.begin();
79 for(; it != proc->containerMap.end(); ++it)
80 _cb_container->addItem( QString((*it).first.c_str()));
81
82 SubjectComponent *scompo=dynamic_cast<SubjectComponent*>(_subject);
83 ComponentInstance *compoInst = scompo->getComponent();
84 Container * cont = compoInst->getContainer();
85 if (cont)
86 {
87 int index = _cb_container->findText(cont->getName().c_str());
88 _cb_container->setCurrentIndex(index);
89 }
90}
virtual std::string getName() const
Definition: Container.hxx:81
References _cb_container, YACS::HMI::ItemEditionBase::_subject, YACS::ENGINE::Proc::containerMap, YACS::HMI::SubjectComponent::getComponent(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Container::getName(), and YACS::HMI::GuiContext::getProc().
Referenced by EditionComponent(), and update().
◆ update()
void EditionComponent::update ( GuiEvent  event,
int  type,
Subject *  son
when loading a schema, creation of all edition widgets is time and memory consuming, so, widget edition creation is differed until user select an item in tree or 2D vue.
Reimplemented from YACS::HMI::ItemEdition.
Definition at line 64 of file EditionComponent.cxx.
65{
66 DEBTRACE("EditionComponent::update " <<eventName(event) << " " << type);
67 if(event == SETVALUE)
69
70 if(event == ADDREF || event == ASSOCIATE)
72}
void update()
Update the property items with their values in the subject.
References _propeditor, YACS::HMI::ADDREF, YACS::HMI::ASSOCIATE, DEBTRACE, YACS::HMI::GuiObserver::eventName(), fillContainerPanel(), YACS::HMI::SETVALUE, and YACS::HMI::PropertyEditor::update().
Referenced by gui.graph.MyCanvas::customEvent().
◆ _cb_container
ComboBox* YACS::HMI::EditionComponent::_cb_container
Definition at line 43 of file EditionComponent.hxx.
Referenced by changeContainer(), EditionComponent(), and fillContainerPanel().
◆ _propeditor
PropertyEditor* YACS::HMI::EditionComponent::_propeditor
Definition at line 42 of file EditionComponent.hxx.
