28#include <QActionGroup>
31#include <QInputDialog>
47PropertyEditor::PropertyEditor(
Subject* subject,
QWidget *parent):
QWidget(parent),_subject(subject),_editing(false)
50 for (
int i=0;
i<v.size(); ++
i)
55 _removeAction=
new QAction(QIcon(
"icons:icon_minus.png"),
"Remove Property",
this);
56 _addAction=
new QAction(QIcon(
"icons:icon_plus.png"),
"Add Property",
this);
61 headers <<
"Name" <<
"Value";
62 _table->setHorizontalHeaderLabels(headers);
63 _table->verticalHeader()->hide();
64 _table->setSelectionMode(QAbstractItemView::SingleSelection);
66 connect(
_table, SIGNAL(itemChanged(QTableWidgetItem *)),
this, SLOT(
onItemChanged(QTableWidgetItem *)));
69 QHBoxLayout* hboxLayout =
new QHBoxLayout();
70 hboxLayout->setMargin(0);
71 QToolButton* tb_options =
new QToolButton();
72 tb_options->setCheckable(
true);
74 icon.addFile(
"icons:icon_down.png");
75 icon.addFile(
"icons:icon_up.png", QSize(), QIcon::Normal, QIcon::On);
76 tb_options->setIcon(icon);
77 hboxLayout->addWidget(tb_options);
80 QLabel* label=
new QLabel(
"Properties ");
85 hboxLayout->addWidget(label);
89 QToolButton* button=
new QToolButton();
91 button->setPopupMode(QToolButton::InstantPopup);
92 _bar->addWidget(button);
94 button=
new QToolButton();
96 _bar->addWidget(button);
97 hboxLayout->addWidget(
_bar);
99 QVBoxLayout *layout =
new QVBoxLayout;
100 layout->setMargin(0);
101 layout->addLayout(hboxLayout);
102 layout->addWidget(
_table);
123 DEBTRACE(
"PropertyEditor::onRemoveProperty");
124 QList<QTableWidgetItem *> litems=
_table->selectedItems();
127 QTableWidgetItem *item =litems.first();
140 DEBTRACE(
"PropertyEditor::onAddProperty " << action->text().toStdString());
142 QString text=action->text();
143 if(text ==
"Other ...")
145 text = QInputDialog::getText(
this, tr(
"New Property"),tr(
"Name:"), QLineEdit::Normal,
"", &ok);
146 if (!ok || text.isEmpty())
152 QMessageBox::warning ( 0,
"Property already defined",
"Property already defined");
157 int row=
_table->rowCount();
158 _table->setRowCount(row+1);
160 QTableWidgetItem *newItem =
new QTableWidgetItem(text);
161 newItem->setFlags(newItem->flags() & ~Qt::ItemIsEditable);
162 _table->setItem(row,0, newItem);
164 newItem =
new QTableWidgetItem();
165 _table->setItem(row,1, newItem);
188 DEBTRACE(
"PropertyEditor::update " );
190 QTableWidgetItem *newItem;
195 for (std::map<std::string, std::string>::iterator it = props.begin(); it != props.end(); ++it)
197 _table->setRowCount(row+1);
198 QTableWidgetItem *newItem =
new QTableWidgetItem(it->first.c_str());
199 newItem->setFlags(newItem->flags() & ~Qt::ItemIsEditable);
200 _table->setItem(row,0, newItem);
202 newItem =
new QTableWidgetItem(it->second.c_str());
203 _table->setItem(row,1, newItem);
215 DEBTRACE(
"PropertyEditor::updateMenu " );
216 QMenu* menu=
new QMenu;
219 QActionGroup* actGroup=
new QActionGroup(
this);
220 connect(actGroup, SIGNAL(triggered(QAction*)),
this, SLOT(
onAddProperty(QAction*)));
229 menu->addAction(anAction);
231 anAction= actGroup->addAction(
"Other ...");
232 menu->addAction(anAction);
233 anAction->setData(QVariant(
241 DEBTRACE(
"PropertyEditor::setProperties " );
242 QTableWidgetItem *item;
245 std::map<std::string,std::string> props;
246 for (
int i = 0;
i <
_table->rowCount(); ++
i)
249 name=item->data(Qt::DisplayRole).toString().toStdString();
251 value=item->data(Qt::DisplayRole).toString().toStdString();
261 DEBTRACE(
"PropertyEditor::on_tb_options_toggled " << checked);
virtual void onItemChanged(QTableWidgetItem *item)
Qt slot to change the value of a property item in the table.
virtual void onRemoveProperty()
Qt slot to remove the selected item in the table.
virtual void onAddProperty(QAction *action)
Qt slot to add a property item in the table.
virtual ~PropertyEditor()
void update()
Update the property items with their values in the subject.
QStringList _propertyNames
QStringList _knownProperties
void updateMenu()
Update the menu used to add properties with the already set properties.
void setProperties()
Update the subject properties with the values stored in the table.
virtual void on_tb_options_toggled(bool checked)
virtual bool setProperties(std::map< std::string, std::string > properties)
virtual std::vector< std::string > knownProperties()
virtual std::map< std::string, std::string > getProperties()
