YACS::HMI::SubjectComponent Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectComponent:
Collaboration diagram for YACS::HMI::SubjectComponent:
 SubjectComponent (YACS::ENGINE::ComponentInstance *component, Subject *parent)
virtual ~SubjectComponent ()
virtual void setContainer ()
virtual bool associateToContainer (SubjectContainerBase *subcont)
virtual SubjectReference * attachService (SubjectServiceNode *service)
virtual void detachService (SubjectServiceNode *service)
virtual void moveService (SubjectReference *reference)
virtual void removeSubServiceFromSet (SubjectServiceNode *service)
virtual void notifyServicesChange (GuiEvent event, int type, Subject *son)
virtual std::pair< std::string, int > getKey ()
bool hasServices ()
YACS::ENGINE::ComponentInstance * getComponent () const
virtual TypeOfElem getType ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
void registerUndoDestroy ()
bool isDestructible ()
virtual ~Observer ()
Public Attributes
SubjectReference * _subRefContainer
int _id
YACS::ENGINE::ComponentInstance * _compoInst
std::set< SubjectServiceNode * > _subServiceSet
std::map< SubjectServiceNode *, SubjectReference * > _subReferenceMap
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
Friends
class SubjectNode
Definition at line 461 of file guiObservers.hxx.
◆ SubjectComponent()
SubjectComponent::SubjectComponent ( YACS::ENGINE::ComponentInstance *  component,
Subject *  parent
Definition at line 4202 of file guiObservers.cxx.
4203 : Subject(parent), _compoInst(component)
4204{
4206 _subRefContainer = 0;
4207 _subServiceSet.clear();
4208 _subReferenceMap.clear();
4209}
Subject(Subject *parent=0)
References _compoInst, _subRefContainer, _subReferenceMap, _subServiceSet, and YACS::ENGINE::RefCounter::incrRef().
◆ ~SubjectComponent()
SubjectComponent::~SubjectComponent ( )
Definition at line 4211 of file guiObservers.cxx.
4212{
4213 Proc* aProc = GuiContext::getCurrent()->getProc();
4214 if ( aProc )
4215 {
4218 }
4220}
const std::string & getInstanceName() const
Definition: Proc.hxx:44
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
Definition: guiContext.hxx:67
std::map< YACS::ENGINE::ComponentInstance *, YACS::HMI::SubjectComponent * > _mapOfSubjectComponent
Definition: guiContext.hxx:74
Definition: guiContext.hxx:50
References _compoInst, YACS::HMI::GuiContext::_mapOfSubjectComponent, YACS::ENGINE::Proc::componentInstanceMap, YACS::ENGINE::RefCounter::decrRef(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComponentInstance::getInstanceName(), and YACS::HMI::GuiContext::getProc().
◆ associateToContainer()
bool SubjectComponent::associateToContainer ( SubjectContainerBase *  subcont)
Definition at line 4311 of file guiObservers.cxx.
4312{
4313 DEBTRACE("SubjectComponent::associateToContainer " << getName() << " " << subcont->getName());
4316 if (command->execute())
4317 {
4318 if (!GuiContext::getCurrent()->isLoading()) // do not register command when loading a schema
4319 GuiContext::getCurrent()->getInvoc()->add(command);
4320 else delete command;
4321 return true;
4322 }
4323 else delete command;
4324 return false;
4325}
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:51
void add(Command *command)
Definition: commands.cxx:156
virtual std::string getName()
References _compoInst, YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComponentInstance::getInstanceName(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectContainerBase::getName(), and getName().
Referenced by YACS::HMI::SchemaDirContainersItem::addComponentItem(), YACS::HMI::EditionComponent::changeContainer(), and YACS::HMI::EditionSalomeNode::changeContainer().
◆ attachService()
SubjectReference * SubjectComponent::attachService ( SubjectServiceNode *  service)
◆ clean()
void SubjectComponent::clean ( Command *  command = 0)
Definition at line 4222 of file guiObservers.cxx.
4223{
4224 if (_askRegisterUndo)
4225 {
4226 _askRegisterUndo = false;
4228 }
4229 localclean(command);
4230 Subject::clean(command);
4231}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::Subject::clean(), localclean(), and YACS::HMI::Subject::registerUndoDestroy().
◆ detachService()
void SubjectComponent::detachService ( SubjectServiceNode *  service)
Definition at line 4337 of file guiObservers.cxx.
4338{
4339 DEBTRACE("SubjectComponent::detachService");
4340 YASSERT(_subReferenceMap.count(service));
4341 SubjectReference *reference = _subReferenceMap[service];
4342 update(REMOVECHILDREF, SALOMENODE, reference);
4343 _subServiceSet.erase(service);
4344 _subReferenceMap.erase(service);
4345 service->removeSubRefComponent();
4346 erase(reference);
4347}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual void removeSubRefComponent()
static void erase(Subject *sub, Command *command=0, bool post=false)
References _subReferenceMap, _subServiceSet, DEBTRACE, YACS::HMI::Subject::erase(), YACS::HMI::REMOVECHILDREF, YACS::HMI::SubjectServiceNode::removeSubRefComponent(), YACS::HMI::SALOMENODE, YACS::HMI::Subject::update(), and YASSERT.
Referenced by YACS::HMI::CommandAddComponentFromCatalog::localReverse().
◆ getComponent()
◆ getKey()
std::pair< std::string, int > SubjectComponent::getKey ( )
Definition at line 4275 of file guiObservers.cxx.
4276{
4277 std::pair<std::string, int> key = std::pair<std::string, int>(_compoInst->getCompoName(), _compoInst->getNumId());
4278 return key;
4279}
References _compoInst, YACS::ENGINE::ComponentInstance::getCompoName(), and YACS::ENGINE::ComponentInstance::getNumId().
◆ getName()
◆ getProperties()
std::map< std::string, std::string > SubjectComponent::getProperties ( )
Definition at line 4395 of file guiObservers.cxx.
4396{
4397 return _compoInst->getProperties();
4398}
std::map< std::string, std::string > getProperties() const
References _compoInst, and YACS::ENGINE::PropertyInterface::getProperties().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectComponent::getType ( )
Definition at line 482 of file guiObservers.hxx.
482{return COMPONENT;}
References YACS::HMI::COMPONENT.
Referenced by YACS::HMI::SubjectContainerBase::localclean().
◆ hasServices()
bool YACS::HMI::SubjectComponent::hasServices ( )
◆ localclean()
void SubjectComponent::localclean ( Command *  command = 0)
Definition at line 4233 of file guiObservers.cxx.
4234{
4235 DEBTRACE("SubjectComponent::localClean " << this);
4236 Proc* aProc = GuiContext::getCurrent()->getProc();
4237 if ( aProc )
4238 {
4239 std::map<Node*, SubjectNode*>::iterator it = GuiContext::getCurrent()->_mapOfSubjectNode.begin();
4240 std::list<SubjectNode*> services;
4241 for ( ; it!=GuiContext::getCurrent()->_mapOfSubjectNode.end(); it++ )
4242 {
4243 if(ServiceNode* service=dynamic_cast<ServiceNode*>((*it).first))
4244 {
4245 if ( service->getComponent() == _compoInst )
4246 {
4247 services.push_back((*it).second);
4248 }
4249 }
4250 }
4251 while(!services.empty())
4252 {
4253 SubjectNode* son=services.front();
4254 services.pop_front();
4255 Subject* parent=son->getParent();
4256// parent->update(REMOVE,son->getType(),son);
4257 parent->erase(son);
4258 parent->update(REMOVE,0,0);
4259 }
4260
4261 Container* container = _compoInst->getContainer();
4262 if (!container) return;
4263 SubjectContainerBase *subContainer(0);
4264 YASSERT(GuiContext::getCurrent()->_mapOfSubjectContainer.count(container));
4265 subContainer = GuiContext::getCurrent()->_mapOfSubjectContainer[container];
4266 subContainer->removeSubComponentFromSet(this);
4267 }
4268}
std::map< YACS::ENGINE::Container *, YACS::HMI::SubjectContainerBase * > _mapOfSubjectContainer
Definition: guiContext.hxx:75
Definition: guiContext.hxx:70
virtual Subject * getParent()
References _compoInst, YACS::HMI::GuiContext::_mapOfSubjectContainer, YACS::HMI::GuiContext::_mapOfSubjectNode, DEBTRACE, YACS::HMI::Subject::erase(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::REMOVE, YACS::HMI::SubjectContainerBase::removeSubComponentFromSet(), YACS::HMI::Subject::update(), and YASSERT.
Referenced by clean().
◆ moveService()
void SubjectComponent::moveService ( SubjectReference *  reference)
Definition at line 4349 of file guiObservers.cxx.
4350{
4351 DEBTRACE("SubjectComponent::moveService");
4352 SubjectComponent* oldcomp = dynamic_cast<SubjectComponent*>(reference->getParent());
4353 YASSERT(oldcomp);
4354
4355 SubjectServiceNode* service = dynamic_cast<SubjectServiceNode*>(reference->getReference());
4356 oldcomp->removeSubServiceFromSet(service);
4357 _subServiceSet.insert(service);
4358 _subReferenceMap[service] = reference;
4359 oldcomp->update(CUT, SALOMENODE, reference);
4360 reference->reparent(this);
4361 update(PASTE, SALOMENODE, reference);
4362 if (!oldcomp->hasServices())
4363 Subject::erase(oldcomp);
4364}
virtual void removeSubServiceFromSet(SubjectServiceNode *service)
virtual void reparent(Subject *parent)
virtual Subject * getReference() const
References _subReferenceMap, _subServiceSet, YACS::HMI::CUT, DEBTRACE, YACS::HMI::Subject::erase(), YACS::HMI::Subject::getParent(), YACS::HMI::SubjectReference::getReference(), hasServices(), YACS::HMI::PASTE, removeSubServiceFromSet(), YACS::HMI::SubjectReference::reparent(), YACS::HMI::SALOMENODE, YACS::HMI::Subject::update(), and YASSERT.
Referenced by YACS::HMI::CommandAssociateServiceToComponent::localExecute(), YACS::HMI::CommandAssociateServiceToComponent::localReverse(), and YACS::HMI::SubjectServiceNode::setComponent().
◆ notifyServicesChange()
void SubjectComponent::notifyServicesChange ( GuiEvent  event,
int  type,
Subject *  son
Definition at line 4373 of file guiObservers.cxx.
4374{
4375 DEBTRACE("SubjectComponent::notifyServicesChange");
4376 set<SubjectServiceNode*>::iterator it = _subServiceSet.begin();
4377 for(; it != _subServiceSet.end(); ++it)
4378 {
4379 (*it)->update(event, type, son);
4380 }
4381}
References _subServiceSet, and DEBTRACE.
Referenced by YACS::HMI::CommandAssociateComponentToContainer::localExecute(), YACS::HMI::CommandAssociateComponentToContainer::localReverse(), and setContainer().
◆ removeSubServiceFromSet()
void SubjectComponent::removeSubServiceFromSet ( SubjectServiceNode *  service)
Definition at line 4366 of file guiObservers.cxx.
4367{
4368 DEBTRACE("SubjectComponent::removeSubServiceFromSet " << getName() << " " << service->getName());
4369 _subServiceSet.erase(service);
4370 _subReferenceMap.erase(service);
4371}
References _subReferenceMap, _subServiceSet, DEBTRACE, YACS::HMI::SubjectNode::getName(), and getName().
Referenced by YACS::HMI::SubjectServiceNode::localclean(), and moveService().
◆ setContainer()
void SubjectComponent::setContainer ( )
When loading scheme from file, get the container associated to the component, if any, and create the corresponding subject.
Definition at line 4290 of file guiObservers.cxx.
4291{
4292 DEBTRACE("SubjectComponent::setContainer " << getName());
4293 Container* container = _compoInst->getContainer();
4294 if (container)
4295 {
4296 SubjectContainerBase *subContainer;
4297 if (GuiContext::getCurrent()->_mapOfSubjectContainer.count(container))
4298 subContainer = GuiContext::getCurrent()->_mapOfSubjectContainer[container];
4299 else
4300 subContainer =
4302 addSubjectReference(subContainer);
4303 if (_subRefContainer)
4304 subContainer->moveComponent(_subRefContainer);
4305 else
4306 _subRefContainer = subContainer->attachComponent(this);
4308 }
4309}
virtual std::string getName() const
Definition: Container.hxx:81
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
virtual void notifyServicesChange(GuiEvent event, int type, Subject *son)
virtual void moveComponent(SubjectReference *reference)
virtual SubjectReference * attachComponent(SubjectComponent *component)
SubjectContainerBase * addSubjectContainer(YACS::ENGINE::Container *cont, std::string name="")
virtual void addSubjectReference(Subject *ref)
References _compoInst, YACS::HMI::GuiContext::_mapOfSubjectContainer, _subRefContainer, YACS::HMI::SubjectProc::addSubjectContainer(), YACS::HMI::Subject::addSubjectReference(), YACS::HMI::ASSOCIATE, YACS::HMI::SubjectContainerBase::attachComponent(), YACS::HMI::CONTAINER, DEBTRACE, YACS::ENGINE::ComponentInstance::getContainer(), YACS::HMI::GuiContext::getCurrent(), getName(), YACS::ENGINE::Container::getName(), YACS::HMI::GuiContext::getSubjectProc(), YACS::HMI::SubjectContainerBase::moveComponent(), and notifyServicesChange().
◆ setProperties()
bool SubjectComponent::setProperties ( std::map< std::string, std::string >  properties)
Definition at line 4383 of file guiObservers.cxx.
4384{
4386 if (command->execute())
4387 {
4388 GuiContext::getCurrent()->getInvoc()->add(command);
4389 return true;
4390 }
4391 else delete command;
4392 return false;
4393}
References YACS::HMI::Invocator::add(), YACS::HMI::Command::execute(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), and getName().
◆ SubjectNode
friend class SubjectNode
friend
Definition at line 464 of file guiObservers.hxx.
◆ _compoInst
◆ _id
int YACS::HMI::SubjectComponent::_id
Definition at line 485 of file guiObservers.hxx.
◆ _subRefContainer
◆ _subReferenceMap
std::map<SubjectServiceNode*,SubjectReference*> YACS::HMI::SubjectComponent::_subReferenceMap
◆ _subServiceSet
std::set<SubjectServiceNode*> YACS::HMI::SubjectComponent::_subServiceSet
