#include <commandsProc.hxx>
| CommandSetComponentInstanceProperties (std::string compoinstance, std::map< std::string, std::string > properties) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _compoinstance |
| std::map< std::string, std::string > | _properties |
| std::map< std::string, std::string > | _oldProp |
| bool | _oldAnon |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 591 of file commandsProc.hxx.
| CommandSetComponentInstanceProperties::CommandSetComponentInstanceProperties | ( | std::string | compoinstance, |
| std::map< std::string, std::string > | properties | ||
Definition at line 3297 of file commandsProc.cxx.
protectedvirtual |
Definition at line 3305 of file commandsProc.cxx.
References _compoinstance.
protectedvirtual |
Definition at line 3311 of file commandsProc.cxx.
References _compoinstance, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectComponent, _oldAnon, _oldProp, _properties, YACS::ENGINE::Proc::componentInstanceMap, DEBTRACE, testCppPluginInvokation::ex, YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), gui.CONNECTOR::ref(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::Subject::update(), and YASSERT.
protectedvirtual |
Definition at line 3340 of file commandsProc.cxx.
References _compoinstance, YACS::HMI::GuiContext::_lastErrorMessage, YACS::HMI::GuiContext::_mapOfSubjectComponent, _oldAnon, _oldProp, YACS::ENGINE::Proc::componentInstanceMap, DEBTRACE, testCppPluginInvokation::ex, YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), gui.CONNECTOR::ref(), setErrorMsg(), YACS::HMI::SETVALUE, YACS::HMI::Subject::update(), and YASSERT.
protected |
Definition at line 600 of file commandsProc.hxx.
protected |
Definition at line 603 of file commandsProc.hxx.
Referenced by localExecute(), and localReverse().
protected |
Definition at line 602 of file commandsProc.hxx.
Referenced by CommandSetComponentInstanceProperties(), localExecute(), and localReverse().
protected |
Definition at line 601 of file commandsProc.hxx.
Referenced by localExecute().
