YACS::HMI::SubjectServiceNode Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectServiceNode:
Collaboration diagram for YACS::HMI::SubjectServiceNode:
 SubjectServiceNode (YACS::ENGINE::ServiceNode *serviceNode, Subject *parent)
virtual ~SubjectServiceNode ()
virtual void setComponentFromCatalog (YACS::ENGINE::Catalog *catalog, std::string compo, std::string service)
virtual void setComponent ()
virtual bool associateToComponent (SubjectComponent *subcomp)
virtual void removeSubRefComponent ()
virtual void removeSubjectReference ()
virtual SubjectReference * getSubjectReference ()
- Public Member Functions inherited from YACS::HMI::SubjectElementaryNode
 SubjectElementaryNode (YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
virtual ~SubjectElementaryNode ()
virtual void recursiveUpdate (GuiEvent event, int type, Subject *son)
virtual SubjectDataPort * addInputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addOutputPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addIDSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual SubjectDataPort * addODSPort (YACS::ENGINE::Catalog *catalog, std::string type, std::string name)
virtual bool OrderDataPorts (SubjectDataPort *portToMove, int isUp)
virtual void removePort (SubjectDataPort *port)
virtual void loadChildren ()
virtual void saveLinks ()
virtual void restoreLinks ()
- Public Member Functions inherited from YACS::HMI::SubjectNode
 SubjectNode (YACS::ENGINE::Node *node, Subject *parent)
virtual ~SubjectNode ()
virtual bool reparent (Subject *parent)
virtual bool copy (Subject *parent)
virtual YACS::ENGINE::Node * getNode ()
void registerUndoDestroy ()
SubjectControlLink * addSubjectControlLink (SubjectControlLink *sub)
void removeSubjectControlLink (SubjectControlLink *sub)
std::list< SubjectLink * > getSubjectLinks () const
std::list< SubjectControlLink * > getSubjectControlLinks () const
std::list< SubjectInputPort * > getSubjectInputPorts () const
std::list< SubjectOutputPort * > getSubjectOutputPorts () const
std::list< SubjectInputDataStreamPort * > getSubjectInputDataStreamPorts () const
std::list< SubjectOutputDataStreamPort * > getSubjectOutputDataStreamPorts () const
virtual void removeExternalLinks ()
virtual void removeExternalControlLinks ()
virtual bool putInComposedNode (std::string name, std::string type, bool toSaveRestoreLinks=true)
virtual int isValid ()
void setExecState (int execState)
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadLinks ()
bool isDestructible ()
virtual TypeOfElem getType ()
virtual ~Observer ()
YACS::ENGINE::ServiceNode * _serviceNode
SubjectReference * _subjectReference
SubjectReference * _subRefComponent
- Protected Attributes inherited from YACS::HMI::SubjectElementaryNode
YACS::ENGINE::ElementaryNode * _elementaryNode
- Protected Attributes inherited from YACS::HMI::SubjectNode
YACS::ENGINE::Node * _node
std::list< SubjectInputPort * > _listSubjectInputPort
std::list< SubjectOutputPort * > _listSubjectOutputPort
std::list< SubjectInputDataStreamPort * > _listSubjectIDSPort
std::list< SubjectOutputDataStreamPort * > _listSubjectODSPort
std::list< SubjectControlLink * > _listSubjectControlLink
int _execState
std::list< YACS::ENGINE::OutGate * > loutgate
std::list< YACS::ENGINE::InGate * > singate
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataLinks
std::vector< std::pair< YACS::ENGINE::OutPort *, YACS::ENGINE::InPort * > > dataflowLinks
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
Friends
class CommandAssociateServiceToComponent
class CommandAddComponentFromCatalog
- Static Public Member Functions inherited from YACS::HMI::SubjectNode
static bool tryCreateLink (SubjectNode *subOutNode, SubjectNode *subInNode)
- Protected Member Functions inherited from YACS::HMI::SubjectNode
virtual SubjectInputPort * addSubjectInputPort (YACS::ENGINE::InputPort *port, std::string name="")
virtual SubjectOutputPort * addSubjectOutputPort (YACS::ENGINE::OutputPort *port, std::string name="")
virtual SubjectInputDataStreamPort * addSubjectIDSPort (YACS::ENGINE::InputDataStreamPort *port, std::string name="")
virtual SubjectOutputDataStreamPort * addSubjectODSPort (YACS::ENGINE::OutputDataStreamPort *port, std::string name="")
virtual void notifyObserver (YACS::ENGINE::Node *object, const std::string &event)
Definition at line 732 of file guiObservers.hxx.
◆ SubjectServiceNode()
SubjectServiceNode::SubjectServiceNode ( YACS::ENGINE::ServiceNode *  serviceNode,
Subject *  parent
Definition at line 2346 of file guiObservers.cxx.
2347 : SubjectElementaryNode(serviceNode, parent), _serviceNode(serviceNode)
2348{
2350 _subRefComponent = 0;
2351}
SubjectElementaryNode(YACS::ENGINE::ElementaryNode *elementaryNode, Subject *parent)
References _subjectReference, and _subRefComponent.
◆ ~SubjectServiceNode()
SubjectServiceNode::~SubjectServiceNode ( )
Definition at line 2353 of file guiObservers.cxx.
2354{
2355 DEBTRACE("SubjectServiceNode::~SubjectServiceNode " << getName());
2357 if (!instance) return;
2358 if (GuiContext::getCurrent()->_mapOfSubjectComponent.count(instance))
2359 {
2361 if (!scomp->hasServices())
2363 }
2364}
virtual ComponentInstance * getComponent()
Return the associated component instance.
Definition: guiContext.hxx:67
std::map< YACS::ENGINE::ComponentInstance *, YACS::HMI::SubjectComponent * > _mapOfSubjectComponent
Definition: guiContext.hxx:74
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
virtual std::string getName()
void addPostErase(Subject *sub)
References YACS::HMI::GuiContext::_mapOfSubjectComponent, _serviceNode, YACS::HMI::SubjectProc::addPostErase(), DEBTRACE, YACS::ENGINE::ServiceNode::getComponent(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::SubjectNode::getName(), YACS::HMI::GuiContext::getSubjectProc(), and YACS::HMI::SubjectComponent::hasServices().
◆ addSubjectReference()
void SubjectServiceNode::addSubjectReference ( Subject *  ref)
Definition at line 2495 of file guiObservers.cxx.
2496{
2497 DEBTRACE("Subject::addSubjectReference " << getName() << " " << ref->getName());
2498 SubjectReference *son = new SubjectReference(ref, this);
2499 _subjectReference = son;
2500 update(ADDREF, 0, son);
2501}
Definition: CONNECTOR.py:120
References _subjectReference, YACS::HMI::ADDREF, DEBTRACE, YACS::HMI::SubjectNode::getName(), gui.CONNECTOR::ref(), and YACS::HMI::SubjectNode::update().
Referenced by YACS::HMI::CommandAddComponentFromCatalog::localExecute(), and setComponent().
◆ associateToComponent()
bool SubjectServiceNode::associateToComponent ( SubjectComponent *  subcomp)
Definition at line 2479 of file guiObservers.cxx.
2480{
2481 DEBTRACE("SubjectServiceNode::associateToComponent " << getName() << " " << subcomp->getName());
2482 SubjectReference* oldSReference = _subjectReference;
2485 new CommandAssociateServiceToComponent(aName, subcomp->getName());
2486 if (command->execute())
2487 {
2488 GuiContext::getCurrent()->getInvoc()->add(command);
2489 return true;
2490 }
2491 else delete command;
2492 return false;
2493}
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
friend class CommandAssociateServiceToComponent
References _serviceNode, _subjectReference, YACS::HMI::Invocator::add(), CommandAssociateServiceToComponent, DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectNode::getName(), YACS::HMI::SubjectComponent::getName(), and YACS::HMI::GuiContext::getProc().
Referenced by YACS::HMI::EditionSalomeNode::changeInstance().
◆ clean()
void SubjectServiceNode::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectElementaryNode.
Reimplemented in YACS::HMI::SubjectCORBANode, YACS::HMI::SubjectCppNode, YACS::HMI::SubjectSalomeNode, YACS::HMI::SubjectSalomePythonNode, and YACS::HMI::SubjectXmlNode.
Definition at line 2366 of file guiObservers.cxx.
2367{
2368 if (_askRegisterUndo)
2369 {
2370 _askRegisterUndo = false;
2372 }
2373 localclean(command);
2375}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectElementaryNode::clean(), localclean(), and YACS::HMI::SubjectNode::registerUndoDestroy().
Referenced by YACS::HMI::SubjectCORBANode::clean(), YACS::HMI::SubjectCppNode::clean(), YACS::HMI::SubjectSalomeNode::clean(), YACS::HMI::SubjectSalomePythonNode::clean(), and YACS::HMI::SubjectXmlNode::clean().
◆ getSubjectReference()
SubjectReference * SubjectServiceNode::getSubjectReference ( )
Definition at line 2503 of file guiObservers.cxx.
2504{
2505 return _subjectReference;
2506}
References _subjectReference.
Referenced by YACS::HMI::EditionSalomeNode::changeContainer().
◆ localclean()
void SubjectServiceNode::localclean ( Command *  command = 0)
Definition at line 2377 of file guiObservers.cxx.
2378{
2379 DEBTRACE("SubjectServiceNode::localClean ");
2380 if (_subRefComponent)
2381 {
2382 SubjectComponent *scomp = dynamic_cast<SubjectComponent*>(_subRefComponent->getParent());
2383 if (scomp)
2384 scomp->removeSubServiceFromSet(this);
2385 }
2387 {
2388// update( REMOVE, REFERENCE, _subjectReference );
2391 }
2392 if (_subRefComponent)
2393 {
2395 _subRefComponent = 0;
2396 }
2397}
virtual void removeSubServiceFromSet(SubjectServiceNode *service)
static void erase(Subject *sub, Command *command=0, bool post=false)
virtual Subject * getParent()
References _subjectReference, _subRefComponent, DEBTRACE, YACS::HMI::Subject::erase(), YACS::HMI::Subject::getParent(), and YACS::HMI::SubjectComponent::removeSubServiceFromSet().
Referenced by clean().
◆ removeSubjectReference()
virtual void YACS::HMI::SubjectServiceNode::removeSubjectReference ( )
Definition at line 745 of file guiObservers.hxx.
745{ _subjectReference = 0; };
◆ removeSubRefComponent()
virtual void YACS::HMI::SubjectServiceNode::removeSubRefComponent ( )
Definition at line 744 of file guiObservers.hxx.
744{ _subRefComponent = 0; };
References _subRefComponent.
Referenced by YACS::HMI::SubjectComponent::detachService().
◆ setComponent()
void SubjectServiceNode::setComponent ( )
When loading scheme from file, get the component associated to the node, if any, and create the corresponding subject.
Definition at line 2427 of file guiObservers.cxx.
2428{
2429 DEBTRACE("SubjectServiceNode::setComponent");
2431 if (instance)
2432 {
2433 Proc* proc = GuiContext::getCurrent()->getProc();
2434 string compo = instance->getCompoName();
2435 SubjectComponent* subCompo = 0;
2436 if (! GuiContext::getCurrent()->_mapOfSubjectComponent.count(instance))
2437 {
2438 DEBTRACE("SubjectServiceNode::setComponent : create subject for compo = " << compo.c_str());
2439 if(proc->componentInstanceMap.count(instance->getInstanceName())==0)
2440 {
2441 std::cerr << "PROBLEM : ComponentInstance should be registered in proc, add it " << instance->getInstanceName() << std::endl;
2442 proc->componentInstanceMap[instance->getInstanceName()] = instance;
2443 Container* cont=instance->getContainer();
2444 //check if the associated container is consistent with containerMap
2445 if(cont)
2446 if (proc->containerMap.count(cont->getName()) == 0)
2447 {
2448 //container exists but is not in containerMap. Clone it, it's probably the result of copy paste from outside the proc
2449 Container* newcont(cont->cloneAlways());
2450 proc->containerMap[cont->getName()]=newcont;
2451 instance->setContainer(newcont);
2452 GuiContext::getCurrent()->getSubjectProc()->addSubjectContainer(newcont, newcont->getName());
2453 }
2454 else
2455 {
2456 if(cont != proc->containerMap[cont->getName()])
2457 {
2458 //the associated container is not the same as the one in containerMap: use the containerMap one
2459 instance->setContainer(proc->containerMap[cont->getName()]);
2460 }
2461 }
2462 }
2464 }
2465 else
2466 {
2467 DEBTRACE("SubjectServiceNode::setComponent : get already created subject for compo = " <<compo.c_str());
2468 subCompo = GuiContext::getCurrent()->_mapOfSubjectComponent[instance];
2469 }
2470 YASSERT(subCompo);
2471 addSubjectReference(subCompo);
2472 if (_subRefComponent)
2473 subCompo->moveService(_subRefComponent);
2474 else
2475 _subRefComponent = subCompo->attachService(this);
2476 }
2477}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
virtual bool setContainer(Container *cont)
const std::string & getInstanceName() const
virtual std::string getName() const
Definition: Container.hxx:81
virtual Container * cloneAlways() const =0
Definition: Proc.hxx:44
Definition: Proc.hxx:91
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
virtual SubjectReference * attachService(SubjectServiceNode *service)
virtual void moveService(SubjectReference *reference)
SubjectContainerBase * addSubjectContainer(YACS::ENGINE::Container *cont, std::string name="")
SubjectComponent * addSubjectComponent(YACS::ENGINE::ComponentInstance *compo)
virtual void addSubjectReference(Subject *ref)
References YACS::HMI::GuiContext::_mapOfSubjectComponent, _serviceNode, _subRefComponent, YACS::HMI::SubjectProc::addSubjectComponent(), YACS::HMI::SubjectProc::addSubjectContainer(), addSubjectReference(), YACS::HMI::SubjectComponent::attachService(), YACS::ENGINE::Container::cloneAlways(), YACS::ENGINE::Proc::componentInstanceMap, YACS::ENGINE::Proc::containerMap, DEBTRACE, YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::ServiceNode::getComponent(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComponentInstance::getInstanceName(), YACS::ENGINE::Container::getName(), YACS::HMI::GuiContext::getProc(), YACS::HMI::GuiContext::getSubjectProc(), YACS::HMI::SubjectComponent::moveService(), YACS::ENGINE::ComponentInstance::setContainer(), and YASSERT.
◆ setComponentFromCatalog()
void SubjectServiceNode::setComponentFromCatalog ( YACS::ENGINE::Catalog *  catalog,
std::string  compo,
std::string  service
When cloning a service node from a catalog, create the component associated to the node, if not already existing, and create the corresponding subject.
Definition at line 2404 of file guiObservers.cxx.
2407{
2408 DEBTRACE("SubjectServiceNode::setComponentFromCatalog " << compo);
2409
2410 Proc* proc = GuiContext::getCurrent()->getProc();
2411 string position = proc->getChildName(_node);
2414 position,
2415 compo,
2416 service);
2417 if (command->execute())
2418 GuiContext::getCurrent()->getInvoc()->add(command);
2419 else delete command;
2420 return;
2421}
friend class CommandAddComponentFromCatalog
References YACS::HMI::SubjectNode::_node, YACS::HMI::Invocator::add(), CommandAddComponentFromCatalog, DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), and YACS::HMI::GuiContext::getProc().
◆ CommandAddComponentFromCatalog
friend
Definition at line 735 of file guiObservers.hxx.
Referenced by setComponentFromCatalog().
◆ CommandAssociateServiceToComponent
Definition at line 734 of file guiObservers.hxx.
Referenced by associateToComponent().
◆ _serviceNode
YACS::ENGINE::ServiceNode* YACS::HMI::SubjectServiceNode::_serviceNode
◆ _subjectReference
SubjectReference* YACS::HMI::SubjectServiceNode::_subjectReference
◆ _subRefComponent
