YACS::HMI::CommandAddComponentFromCatalog Class Reference
#include <commandsProc.hxx>
Inheritance diagram for YACS::HMI::CommandAddComponentFromCatalog:
Collaboration diagram for YACS::HMI::CommandAddComponentFromCatalog:
 CommandAddComponentFromCatalog (YACS::ENGINE::Catalog *catalog, std::string position, std::string compo, std::string service)
 Command ()
virtual bool execute ()
 Reverse action: undo. More...
virtual std::string dump ()
bool isNormalReverse ()
virtual bool localExecute ()
virtual bool localReverse ()
YACS::ENGINE::Catalog * _catalog
std::string _position
std::string _compo
std::string _service
std::string _nameInProc
bool _createdInstance
bool _normalReverse
Definition at line 738 of file commandsProc.hxx.
◆ CommandAddComponentFromCatalog()
CommandAddComponentFromCatalog::CommandAddComponentFromCatalog ( YACS::ENGINE::Catalog *  catalog,
std::string  compo,
std::string  service
Definition at line 4201 of file commandsProc.cxx.
4205 : Command(), _catalog(catalog), _position(position), _compo(compo), _service(service)
4206{
4207 DEBTRACE("CommandAddComponentFromCatalog::CommandAddComponentFromCatalog " << position << " " << compo << " " << service);
4208 _nameInProc="";
4209 _createdInstance = false;
4210}
References _createdInstance, _nameInProc, and DEBTRACE.
◆ dump()
std::string CommandAddComponentFromCatalog::dump ( )
Definition at line 4212 of file commandsProc.cxx.
4213{
4214 string ret = "CommandAddComponentFromCatalog " + _position + " " + _compo + " " + _service;
4215 return ret;
4216}
References _compo, _position, and _service.
◆ localExecute()
bool CommandAddComponentFromCatalog::localExecute ( )
Definition at line 4218 of file commandsProc.cxx.
4219{
4220 DEBTRACE("CommandAddComponentFromCatalog::localExecute");
4221 try
4222 {
4223 DEBTRACE("_nameInProc: " << _nameInProc);
4224 Proc* proc = GuiContext::getCurrent()->getProc();
4225 Node* node = proc;
4226 if (!_position.empty()) node = proc->getChildByName(_position);
4227 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
4229 SubjectServiceNode *ssnode = dynamic_cast<SubjectServiceNode*>(snode);
4230 YASSERT(ssnode);
4231 if (_catalog->_componentMap.count(_compo))
4232 {
4234 if (compodef->_serviceMap.count(_service))
4235 {
4236 Proc* proc = GuiContext::getCurrent()->getProc();
4237 ComponentInstance *instance =ssnode->_serviceNode->getComponent();
4238 YASSERT(instance);
4239 SubjectComponent* subCompo = 0;
4240 _createdInstance = false;
4241 if(!GuiContext::getCurrent()->_mapOfSubjectComponent.count(instance))
4242 {
4243 _createdInstance = true;
4244 //automatic rename of the component instance by the proc on first execute
4245 DEBTRACE("name given to proc:" << _nameInProc);
4246 proc->addComponentInstance(instance,_nameInProc, true);
4247 _nameInProc= instance->getInstanceName();
4248 DEBTRACE("name given by proc:" << _nameInProc);
4250 }
4251 else
4252 subCompo = GuiContext::getCurrent()->_mapOfSubjectComponent[instance];
4253 YASSERT(subCompo);
4254 ssnode->addSubjectReference(subCompo);
4255 YASSERT(! ssnode->_subRefComponent);
4256 ssnode->_subRefComponent = subCompo->attachService(ssnode);
4257 }
4258 }
4259 return true;
4260 }
4261 catch (Exception& ex)
4262 {
4263 DEBTRACE("CommandAddComponentFromCatalog::localExecute() : " << ex.what());
4264 setErrorMsg(ex);
4265 return false;
4266 }
4267}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
std::map< std::string, ComponentDefinition * > _componentMap
Definition: Catalog.hxx:50
Base class for component definition.
std::map< std::string, ServiceNode * > _serviceMap
const std::string & getInstanceName() const
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
virtual void addComponentInstance(ComponentInstance *inst, const std::string &name="", bool resetCtr=false)
Add a ComponentInstance into componentInstanceMap.
Definition: Proc.cxx:526
virtual ComponentInstance * getComponent()
Return the associated component instance.
Definition: guiContext.hxx:67
std::map< YACS::ENGINE::ComponentInstance *, YACS::HMI::SubjectComponent * > _mapOfSubjectComponent
Definition: guiContext.hxx:74
Definition: guiContext.hxx:70
YACS::HMI::SubjectProc * getSubjectProc()
Definition: guiContext.hxx:52
Definition: guiContext.hxx:50
virtual SubjectReference * attachService(SubjectServiceNode *service)
SubjectComponent * addSubjectComponent(YACS::ENGINE::ComponentInstance *compo)
SubjectReference * _subRefComponent
YACS::ENGINE::ServiceNode * _serviceNode
virtual void addSubjectReference(Subject *ref)
References _catalog, _compo, YACS::ENGINE::Catalog::_componentMap, _createdInstance, YACS::HMI::GuiContext::_mapOfSubjectComponent, YACS::HMI::GuiContext::_mapOfSubjectNode, _nameInProc, _position, _service, YACS::ENGINE::ComponentDefinition::_serviceMap, YACS::HMI::SubjectServiceNode::_serviceNode, YACS::HMI::SubjectServiceNode::_subRefComponent, YACS::ENGINE::Proc::addComponentInstance(), YACS::HMI::SubjectProc::addSubjectComponent(), YACS::HMI::SubjectServiceNode::addSubjectReference(), YACS::HMI::SubjectComponent::attachService(), DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ServiceNode::getComponent(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::ComponentInstance::getInstanceName(), YACS::HMI::GuiContext::getProc(), YACS::HMI::GuiContext::getSubjectProc(), setErrorMsg(), and YASSERT.
◆ localReverse()
bool CommandAddComponentFromCatalog::localReverse ( )
Definition at line 4269 of file commandsProc.cxx.
4270{
4271 DEBTRACE("CommandAddComponentFromCatalog::localReverse");
4272 try
4273 {
4274 Proc* proc = GuiContext::getCurrent()->getProc();
4275 Node* node = proc;
4276 if (!_position.empty()) node = proc->getChildByName(_position);
4277 YASSERT(GuiContext::getCurrent()->_mapOfSubjectNode.count(node));
4279 SubjectServiceNode *ssnode = dynamic_cast<SubjectServiceNode*>(snode);
4280 YASSERT(ssnode);
4281
4282 DEBTRACE("_nameInProc: " << _nameInProc);
4285 YASSERT(GuiContext::getCurrent()->_mapOfSubjectComponent.count(compo));
4287
4288 subCompo->detachService(ssnode);
4289 if (subCompo->hasServices())
4290 throw YACS::Exception("Component instance with services attached, not removed");
4291 Container *cont = compo->getContainer();
4292 YASSERT(GuiContext::getCurrent()->_mapOfSubjectContainer.count(cont));
4294 subcont->detachComponent(subCompo);
4295 //remove componentInstance from proc, from context
4296 if (_createdInstance)
4297 {
4299 proc->removeComponentInstance(compo);
4300 }
4301 DEBTRACE("_nameInProc: " << _nameInProc);
4302 return true;
4303 }
4304 catch (Exception& ex)
4305 {
4306 DEBTRACE("CommandAddComponentFromCatalog::localReverse() : " << ex.what());
4307 setErrorMsg(ex);
4308 return false;
4309 }
4310}
virtual void removeComponentInstance(ComponentInstance *inst)
Remove a componentInstance from the componentInstanceMap.
Definition: Proc.cxx:566
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
std::map< YACS::ENGINE::Container *, YACS::HMI::SubjectContainerBase * > _mapOfSubjectContainer
Definition: guiContext.hxx:75
virtual void detachService(SubjectServiceNode *service)
virtual void detachComponent(SubjectComponent *component)
References _createdInstance, YACS::HMI::GuiContext::_mapOfSubjectComponent, YACS::HMI::GuiContext::_mapOfSubjectContainer, YACS::HMI::GuiContext::_mapOfSubjectNode, _nameInProc, _position, YACS::ENGINE::Proc::componentInstanceMap, DEBTRACE, YACS::HMI::SubjectContainerBase::detachComponent(), YACS::HMI::SubjectComponent::detachService(), testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getProc(), YACS::HMI::SubjectComponent::hasServices(), YACS::ENGINE::Proc::removeComponentInstance(), setErrorMsg(), and YASSERT.
◆ _catalog
YACS::ENGINE::Catalog* YACS::HMI::CommandAddComponentFromCatalog::_catalog
Definition at line 749 of file commandsProc.hxx.
Referenced by localExecute().
◆ _compo
std::string YACS::HMI::CommandAddComponentFromCatalog::_compo
Definition at line 751 of file commandsProc.hxx.
◆ _createdInstance
bool YACS::HMI::CommandAddComponentFromCatalog::_createdInstance
Definition at line 754 of file commandsProc.hxx.
Referenced by CommandAddComponentFromCatalog(), localExecute(), and localReverse().
◆ _nameInProc
std::string YACS::HMI::CommandAddComponentFromCatalog::_nameInProc
Definition at line 753 of file commandsProc.hxx.
◆ _position
std::string YACS::HMI::CommandAddComponentFromCatalog::_position
Definition at line 750 of file commandsProc.hxx.
◆ _service
std::string YACS::HMI::CommandAddComponentFromCatalog::_service
Definition at line 752 of file commandsProc.hxx.
