YACS::HMI::SubjectInputDataStreamPort Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectInputDataStreamPort:
Collaboration diagram for YACS::HMI::SubjectInputDataStreamPort:
 SubjectInputDataStreamPort (YACS::ENGINE::InputDataStreamPort *port, Subject *parent)
virtual ~SubjectInputDataStreamPort ()
virtual TypeOfElem getType ()
void registerUndoDestroy ()
- Public Member Functions inherited from YACS::HMI::SubjectDataPort
 SubjectDataPort (YACS::ENGINE::DataPort *port, Subject *parent)
virtual ~SubjectDataPort ()
virtual YACS::ENGINE::DataPort * getPort ()
void addSubjectLink (SubjectLink *subject)
void removeSubjectLink (SubjectLink *subject)
std::list< SubjectLink * > getListOfSubjectLink ()
virtual bool setValue (std::string value)
void setExecValue (std::string value)
std::string getExecValue ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::InputDataStreamPort * _inputDataStreamPort
- Protected Attributes inherited from YACS::HMI::SubjectDataPort
YACS::ENGINE::DataPort * _dataPort
std::string _execValue
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectDataPort
static bool tryCreateLink (SubjectDataPort *subOutport, SubjectDataPort *subInport, bool control=true)
Definition at line 253 of file guiObservers.hxx.
◆ SubjectInputDataStreamPort()
SubjectInputDataStreamPort::SubjectInputDataStreamPort ( YACS::ENGINE::InputDataStreamPort *  port,
Subject *  parent
Definition at line 3857 of file guiObservers.cxx.
3859 : SubjectDataPort(port, parent), _inputDataStreamPort(port)
3860{
3861}
SubjectDataPort(YACS::ENGINE::DataPort *port, Subject *parent)
◆ ~SubjectInputDataStreamPort()
SubjectInputDataStreamPort::~SubjectInputDataStreamPort ( )
Definition at line 3863 of file guiObservers.cxx.
3864{
3865 DEBTRACE("SubjectInputDataStreamPort::~SubjectInputDataStreamPort " << getName());
3866}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectDataPort::getName().
◆ clean()
void SubjectInputDataStreamPort::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectDataPort.
Definition at line 3900 of file guiObservers.cxx.
3901{
3902 if (_askRegisterUndo)
3903 {
3904 _askRegisterUndo = false;
3906 }
3907 localclean(command);
3908 SubjectDataPort::clean(command);
3909}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectDataPort::clean(), localclean(), and registerUndoDestroy().
◆ getProperties()
std::map< std::string, std::string > SubjectInputDataStreamPort::getProperties ( )
Definition at line 3868 of file guiObservers.cxx.
3869{
3871}
std::map< std::string, std::string > getProperties() const
References _inputDataStreamPort, and YACS::ENGINE::DataStreamPort::getProperties().
Referenced by registerUndoDestroy().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectInputDataStreamPort::getType ( )
Definition at line 263 of file guiObservers.hxx.
263{return INPUTDATASTREAMPORT;}
@ INPUTDATASTREAMPORT
References YACS::HMI::INPUTDATASTREAMPORT.
◆ knownProperties()
std::vector< std::string > SubjectInputDataStreamPort::knownProperties ( )
Definition at line 3873 of file guiObservers.cxx.
3874{
3875 std::vector<std::string> props;
3876 props.push_back("StorageLevel");
3877 //props.push_back("DependencyType");
3878 props.push_back("DateCalSchem");
3879 props.push_back("Alpha");
3880 props.push_back("DeltaT");
3881 props.push_back("InterpolationSchem");
3882 props.push_back("ExtrapolationSchem");
3883 return props;
3884}
◆ localclean()
void SubjectInputDataStreamPort::localclean ( Command *  command = 0)
Definition at line 3911 of file guiObservers.cxx.
3912{
3913 DEBTRACE("SubjectInputDataStreamPort::localClean ");
3914}
References DEBTRACE.
Referenced by clean().
◆ registerUndoDestroy()
void SubjectInputDataStreamPort::registerUndoDestroy ( )
Definition at line 3916 of file guiObservers.cxx.
3917{
3918 DEBTRACE("SubjectInputDataStreamPort::registerUndoDestroy");
3920 map<string,string> properties = getProperties();
3921 if (properties.empty())
3922 return;
3923 Proc *proc = GuiContext::getCurrent()->getProc();
3924 SubjectNode *sno = dynamic_cast<SubjectNode*>(getParent());
3925 YASSERT(sno);
3926 Node *node = sno->getNode();
3927 string nodeName = proc->getChildName(node);
3928 string portName = getName();
3929 Command *command = new CommandSetDSPortProperties(nodeName, portName, true, properties);
3930 GuiContext::getCurrent()->getInvoc()->add(command);
3931}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Base class for all nodes.
Definition: Node.hxx:70
Definition: Proc.hxx:44
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
virtual std::map< std::string, std::string > getProperties()
virtual Subject * getParent()
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::SubjectNode::getNode(), YACS::HMI::Subject::getParent(), YACS::HMI::GuiContext::getProc(), getProperties(), YACS::HMI::SubjectDataPort::registerUndoDestroy(), and YASSERT.
◆ setProperties()
bool SubjectInputDataStreamPort::setProperties ( std::map< std::string, std::string >  properties)
Definition at line 3886 of file guiObservers.cxx.
3887{
3888 Proc *proc = GuiContext::getCurrent()->getProc();
3890 new CommandSetDSPortProperties(proc->getChildName(getPort()->getNode()), getName(), true, properties);
3891 if (command->execute())
3892 {
3893 GuiContext::getCurrent()->getInvoc()->add(command);
3894 return true;
3895 }
3896 else delete command;
3897 return false;
3898}
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
virtual YACS::ENGINE::DataPort * getPort()
References YACS::HMI::Invocator::add(), YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::SubjectDataPort::getPort(), and YACS::HMI::GuiContext::getProc().
◆ _inputDataStreamPort
YACS::ENGINE::InputDataStreamPort* YACS::HMI::SubjectInputDataStreamPort::_inputDataStreamPort
Definition at line 266 of file guiObservers.hxx.
Referenced by getProperties().
