#include <commandsProc.hxx>
| CommandSetDSPortProperties (std::string node, std::string port, bool isInport, std::map< std::string, std::string > properties) | |
Public Member Functions inherited from YACS::HMI::Command | |
| Command () | |
| virtual bool | execute () |
| the command is executed a first time after its registration for undo redo, then on redo More... | |
| virtual bool | reverse (bool isNormal=true) |
| Reverse action: undo. More... | |
| virtual bool | executeSubOnly () |
| execute only sub commands in a reverse action More... | |
| virtual std::string | dump () |
| std::string | recursiveDump (int level=0) |
| void | addSubCommand (Command *command) |
| bool | isNormalReverse () |
| virtual bool | localExecute () |
| virtual bool | localReverse () |
| virtual bool | localExecute ()=0 |
| virtual bool | localReverse ()=0 |
Protected Attributes | |
| std::string | _nodeName |
| std::string | _portName |
| bool | _isInport |
| std::map< std::string, std::string > | _properties |
| std::map< std::string, std::string > | _oldProp |
Protected Attributes inherited from YACS::HMI::Command | |
| std::vector< Command * > | _subCommands |
| bool | _normalReverse |
Definition at line 606 of file commandsProc.hxx.
| CommandSetDSPortProperties::CommandSetDSPortProperties | ( | std::string | node, |
| std::string | port, | ||
| bool | isInport, | ||
| std::map< std::string, std::string > | properties | ||
Definition at line 3437 of file commandsProc.cxx.
protectedvirtual |
Definition at line 3445 of file commandsProc.cxx.
protectedvirtual |
Definition at line 3453 of file commandsProc.cxx.
References _isInport, _nodeName, _oldProp, _portName, _properties, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getInputDataStreamPort(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::HMI::GuiContext::getProc(), YACS::ENGINE::DataStreamPort::getProperties(), setErrorMsg(), and YACS::ENGINE::DataStreamPort::setProperties().
protectedvirtual |
Definition at line 3477 of file commandsProc.cxx.
References _isInport, _nodeName, _oldProp, _portName, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getChildByName(), YACS::HMI::GuiContext::getCurrent(), YACS::ENGINE::Node::getInputDataStreamPort(), YACS::ENGINE::Node::getOutputDataStreamPort(), YACS::HMI::GuiContext::getProc(), setErrorMsg(), and YACS::ENGINE::DataStreamPort::setProperties().
protected |
Definition at line 617 of file commandsProc.hxx.
protected |
Definition at line 615 of file commandsProc.hxx.
protected |
Definition at line 619 of file commandsProc.hxx.
Referenced by CommandSetDSPortProperties(), localExecute(), and localReverse().
protected |
Definition at line 616 of file commandsProc.hxx.
protected |
Definition at line 618 of file commandsProc.hxx.
Referenced by localExecute().
