YACS::HMI::SubjectInputPort Class Reference
#include <guiObservers.hxx>
Inheritance diagram for YACS::HMI::SubjectInputPort:
Collaboration diagram for YACS::HMI::SubjectInputPort:
 SubjectInputPort (YACS::ENGINE::InputPort *port, Subject *parent)
virtual ~SubjectInputPort ()
virtual bool setValue (std::string value)
virtual TypeOfElem getType ()
- Public Member Functions inherited from YACS::HMI::SubjectDataPort
 SubjectDataPort (YACS::ENGINE::DataPort *port, Subject *parent)
virtual ~SubjectDataPort ()
virtual YACS::ENGINE::DataPort * getPort ()
void addSubjectLink (SubjectLink *subject)
void removeSubjectLink (SubjectLink *subject)
std::list< SubjectLink * > getListOfSubjectLink ()
void setExecValue (std::string value)
std::string getExecValue ()
void registerUndoDestroy ()
 Subject (Subject *parent=0)
virtual ~Subject ()
virtual void loadChildren ()
virtual void loadLinks ()
bool isDestructible ()
virtual ~Observer ()
YACS::ENGINE::InputPort * _inputPort
- Protected Attributes inherited from YACS::HMI::SubjectDataPort
YACS::ENGINE::DataPort * _dataPort
std::string _execValue
Subject * _parent
bool _destructible
bool _askRegisterUndo
std::string _progress
- Static Public Member Functions inherited from YACS::HMI::SubjectDataPort
static bool tryCreateLink (SubjectDataPort *subOutport, SubjectDataPort *subInport, bool control=true)
Definition at line 227 of file guiObservers.hxx.
◆ SubjectInputPort()
SubjectInputPort::SubjectInputPort ( YACS::ENGINE::InputPort *  port,
Subject *  parent
Definition at line 3731 of file guiObservers.cxx.
3732 : SubjectDataPort(port, parent), _inputPort(port)
3733{
3734 Node *node = _inputPort->getNode();
3735 if (ForLoop* forloop = dynamic_cast<ForLoop*>(node))
3736 {
3737 if (_inputPort->getName() == "nsteps") _destructible = false;
3738 }
3739 else if (WhileLoop* whileloop = dynamic_cast<WhileLoop*>(node))
3740 {
3741 if (_inputPort->getName() == "condition") _destructible = false;
3742 }
3743 else if (Switch* aSwitch = dynamic_cast<Switch*>(node))
3744 {
3745 if (_inputPort->getName() == "select") _destructible = false;
3746 }
3747 else if (ForEachLoopGen* foreach = dynamic_cast<ForEachLoopGen*>(node))
3748 {
3749 if (_inputPort->getName() == "nbBranches") _destructible = false;
3750 }
3751 else if (OptimizerLoop* optil = dynamic_cast<OptimizerLoop*>(node))
3752 {
3753 if (_inputPort->getName() == "nbBranches") _destructible = false;
3754 }
3755 else if (SplitterNode* split = dynamic_cast<SplitterNode*>(node))
3756 {
3757 if (_inputPort->getName() == "SmplsCollection") _destructible = false;
3758 }
3759
3760}
std::string getName() const
Definition: DataPort.hxx:55
Class for for loop node.
Definition: ForLoop.hxx:33
Base class for all nodes.
Definition: Node.hxx:70
Node * getNode() const
Definition: Port.hxx:46
Definition: Switch.hxx:85
Class for a while loop.
Definition: WhileLoop.hxx:39
SubjectDataPort(YACS::ENGINE::DataPort *port, Subject *parent)
References YACS::HMI::Subject::_destructible, _inputPort, YACS::ENGINE::DataPort::getName(), and YACS::ENGINE::Port::getNode().
◆ ~SubjectInputPort()
SubjectInputPort::~SubjectInputPort ( )
Definition at line 3762 of file guiObservers.cxx.
3763{
3764 DEBTRACE("SubjectInputPort::~SubjectInputPort " << getName());
3765}
virtual std::string getName()
References DEBTRACE, and YACS::HMI::SubjectDataPort::getName().
◆ clean()
void SubjectInputPort::clean ( Command *  command = 0)
Reimplemented from YACS::HMI::SubjectDataPort.
Definition at line 3767 of file guiObservers.cxx.
3768{
3769 if (_askRegisterUndo)
3770 {
3771 _askRegisterUndo = false;
3773 }
3774 localclean(command);
3775 SubjectDataPort::clean(command);
3776}
References YACS::HMI::Subject::_askRegisterUndo, YACS::HMI::SubjectDataPort::clean(), localclean(), and YACS::HMI::SubjectDataPort::registerUndoDestroy().
◆ getType()
virtual TypeOfElem YACS::HMI::SubjectInputPort::getType ( )
Definition at line 235 of file guiObservers.hxx.
235{return INPUTPORT;}
References YACS::HMI::INPUTPORT.
◆ localclean()
void SubjectInputPort::localclean ( Command *  command = 0)
Definition at line 3778 of file guiObservers.cxx.
3779{
3780 DEBTRACE("SubjectInputPort::localClean ");
3781 if (_parent)
3782 {
3783 SubjectElementaryNode* elem = dynamic_cast<SubjectElementaryNode*>(_parent);
3784 if (elem) elem->removePort(this);
3785 }
3786}
virtual void removePort(SubjectDataPort *port)
References YACS::HMI::Subject::_parent, DEBTRACE, and YACS::HMI::SubjectElementaryNode::removePort().
Referenced by clean().
◆ setValue()
bool SubjectInputPort::setValue ( std::string  value)
Generic method do nothing. Implementation in SubjectInputPort and SubjectOutputPort.
Definition at line 3788 of file guiObservers.cxx.
3789{
3790 DEBTRACE("SubjectInputPort::setValue " << value);
3791 Proc *proc = GuiContext::getCurrent()->getProc();
3792 CommandSetInPortValue *command =
3793 new CommandSetInPortValue(proc->getChildName(getPort()->getNode()), getName(), value);
3794 if (command->execute())
3795 {
3796 GuiContext::getCurrent()->getInvoc()->add(command);
3797 return true;
3798 }
3799 else delete command;
3800 return false;
3801}
Definition: Proc.hxx:44
virtual bool execute()
the command is executed a first time after its registration for undo redo, then on redo
Definition: commands.cxx:51
Definition: guiContext.hxx:67
Definition: guiContext.hxx:51
Definition: guiContext.hxx:50
void add(Command *command)
Definition: commands.cxx:156
virtual YACS::ENGINE::DataPort * getPort()
References YACS::HMI::Invocator::add(), DEBTRACE, YACS::HMI::Command::execute(), YACS::ENGINE::ComposedNode::getChildName(), YACS::HMI::GuiContext::getCurrent(), YACS::HMI::GuiContext::getInvoc(), YACS::HMI::SubjectDataPort::getName(), YACS::HMI::SubjectDataPort::getPort(), and YACS::HMI::GuiContext::getProc().
◆ _inputPort
YACS::ENGINE::InputPort* YACS::HMI::SubjectInputPort::_inputPort
Definition at line 237 of file guiObservers.hxx.
Referenced by SubjectInputPort().
